Kinda, it is hard to explain and understand this in words lol. It sounds like you are saying the opposite of what I am doing basically.
I use the cell that connects the positive to the TA pad as the one to power the MCU AND LED as it is better to have ground running through the light then positive. So the other side of that cell (which is ground) connects to the body of the light AND to the rest of the 4s series. The body ground then connects to the MCU to give it a 1s voltage across it.
The other 3 cells keep going in series like normal and ground to the pad with the line of vias which connect ONLY to the FET and 7135. Thus giving them a full 4s voltage across them to positive.
So I am really peeling off 1s and letting the other 3s go to the LED.
So, if I understand this for a 4S setup, 3S is going into GRND and 4S is going into VCC? The 3S is from the ground ring, and 4S is on the TA pad. That should work. Is this correct?
1S is the potential difference. I think if you take 4 cells in series, connect/measure between the 1st cell and 2nd, (1st cell has the batt+ exposed), you are actually at 3S+, not 1S negative.
Oopsie - we keep crossing posts, me, with my editing...
Maybe a picture would help? This is how I understand it, I don’t know why it wouldn’t work, though I am still skeptical for some reason. (and technically this isn’t totally correct, obviously the LEDs go through the FET to get to the Batt-, but by “Driver” I mean “MCU”)
1s is going through the body to the ground ring on the driver. The other 3s is going to the contact pad on the driver that feeds the FET (the one with the line of vias).
All I'm saying is 16V - 12V is 4V, so that's what the MCU is seeing - tapping in between the 3rd and 4th cell (going from negative to positive) gives you 12V. The + end of the 4th cell is 16V. I can't see it any other way from the pics in posts 259 and 260. So in relation to earth ground, 12V would be going through the body, I would think?
In a 2S2P, only 4V would be going through the body?
I think some of the confusion is about the order of the cells. I am calling the 1st cell the one on the far left of my diagram.
The body of the light carries 4.2v through it, just like a normal SRK as that single cell is all that is passing through the body.
The other 3 cells only connect to the contact plate in the tail and to the driver contact pads, which feeds into the FET on cell # 4 (the one on the far right).
I discussed this with an EE friend here @work. His concern was the gate voltage compared to the source voltage coming to the FET. He reviewed the specs on the SIR800DP: N-channel, Vgs rated at +/- 12V.
Have you tried this on the bench yet? Were you planning on using one of our standard FET's? Have you looked into the voltage delta between the gate and source of the FET?
I am sure there are more options as well but the NXP is already proven and would work fine. I honestly notice very little difference in the real world between it and the sir800.
For the NXP, yes, it won't blow up anything with a range of 20V, but the source to the FET is -12V compared to the MCU's supplied gate voltage to the FET, so even for the NXP, the FET will be always be on. This is what my friend is saying.
When the MCU is not sending any voltage to the FET gate, It is an open circuit correct? I am not sure how the FET would turn on with an open circuit on the gate?
When the MCU sends the voltage output to the FET would it not turn on anyways?
Honestly I am not seeing how this setup is any different than using an LDO? Either way the gate sees +4v and the source is –12v?
The source is -12V, while the gate is 0 to 4V, therefore when the MCU outputs what it thinks is zero, the FET sees it as +12V, because to the FET, the -12V is it's ground. So when you think you set the gate to 0, it's really a 12V difference over the source input to the FET, so, the FET is always on.
That's the way I understand it. Think it makes sense.
Yes, it makes sense on one hand, IF the circuit was set to 0v by the MCU. The way I understand it though is that when the MCU turns the FET off the circuit is open with no connection at all. Thus how does the FET get energized if there is not a complete circuit?
Even in a zener modded 2s setup there is a 4.1v difference between the source and the gate, this is more than enough to energize the FET if what you are saying is true. Yet zener modded driver work fine?
With a zener, I think the source and MCU are both getting the same ground reference, so the MCU's gate is in the 0V to 4V range compared to the source. Batt+ of 8V goes direct to the LED, so to the FET, it's on the drain side. Dunno, I could be wrong here...
Yes, if the MCU sets PWM of 0 means an open circuit, guess you are right - should have no turn on effect to the FET.
Concerning the SIR800DP, it's been discussed and researched several times here on BLF - I don't need any more convincing. I got a few SIR400DP's that are even better. For single LED usage, probably not much benefit, but for high amps, it runs cooler, better.
There is actually an easy fix to this come to think of it, I simply run the 1s V+ through the body of the light. Then the ground will be the same but the V+ will be what the MCU needs and the FET will not see more then the 1s difference in voltage.
I didn’t want to put the V+ through the body but come to think of it there is no reason we can’t.
