The last picture (gif) is obviously crap or faked. The camera was likely set to auto-exposure, and the exposure time or other settings are completely different between the two images.
I completely disregard that gif image, unless the settings are detailed in full. Don’t believe it. And given that the photographer doesn’t know how to operate a camera, I wouldn’t be surprised if he also doesn’t know how to set the flashlights to max.
It sure looks to me like the E11 is wider in the beamshot.
Anyway, my point was that nothing in the gif can be believed, without seeing the exif data from the image (and believing that the photographer isn’t faking something else, which I’m not even sure of, given the more believable beamshot comparison picture).
That gif is from review done by kj75, who does a lot of very competent reviews. There is always a possibility of mistake of course, but faking is definitely out of the question in this case.
Well, maybe he knows his flashlights. But it doesn’t appear he knows how to use the manual settings on his camera.
I suppose it’s possible he got a bum E11 light, or a bum battery. But given the huge difference in his gif, compared to side-by-side beamshots, I think he left the camera on auto. Or perhaps he let the camera blow out some of the highlights or something. Anyway, something is definitely off about it.
Can anyone who has the 2 lights comment on the difference in throw between them …… I would have thought the Mi7 with the XP-L Hi would have a tighter hotspot and longer throw but I know that’s not the only contributing factor …. mainly interested in if one has a much better throw than the other???
I agree something looks very odd about this image, but the spill of Mi7 is wider on the beamshot comparison image also, so that itself is not the problem.
He says all camera settings are always on manual and always the same for every review. He also says the two images were shot one after another both with fresh batteries.
Okay, looking at the beamshots again, yes, I agree the Mi7 spill is wider, however it is very faint.
In any case, I think the gif images are very misleading. They imply the Mi7 is far brighter than the E11, which just isn’t the case. If he really did keep all the camera’s settings the same, then the scene topography is misleading the viewer. i.e., the scene is chosen to give a bonus to a light with a large, faint, spill.
I just thought about something else. What is the distance between camera and the flashlight mount? If it isn’t negligible, that would explain why flashlight with wider spill looks so much better in the image.
On AA (Eneloop Pro) batteries, E11 produces about 300 lumens for 60 minutes, while Mi7 produces about 160 lumens for 80 minutes. For the first 2-3 minutes E11 even produces 400 lumens.
I am a terrible photographer, and so I set all the parameters as indicated in the pics.
I can barely answer for my pics, can’t make judgement from pics took from other people.
Wanted a little more throw from my floody E11 so… for my first ever mod;
Using gasoline I de-domed the cool white led, now it has a warm tint… looks to be about 4500k. Have a cool white XP-L HI incoming, but kinda liking this tint.
Smoothed the reflector - green fine grit Scotch Brite pad to remove electroplating, 1200 - 4000 - 8000 grit 3M wet/dry sandpaper and a high speed drill, then Pinnacle Crystal Clear metal polished it with a Dremel.
Any way you could talk me through how to do this ? I ordered mine 3 days ago and hit the cool white by mistake rather then the NW … generally I prefer torches with more throw as well so this might sort 2 things at once … better throw and better tint???
I probably wouldn’t play with the reflector as wouldn’t have a clue what I was doing but of I could de-dome to give a tad more throw and better tint I’d probably give it a try!!!
Installed XP-L HI V2 6500K, and for better beam focus I fashioned a thin < 1mm spacer to fit under it’s reflector gasket. Now it projects a defined 11” to 12” hot spot at 10 feet.
I’m pretty happy with the result, what do you think?
