LiitoKala 26650-50A 5000mah 26650 - great first impressions
Yep, in fact it is $3.40 higher than the last 4 I just bought & received. I got 4 for $19.59 at GB. :slight_smile:
Hello!
Excerpt of a report about my findings on internal resistance for these batteries, published last wednesday 2016/09/07 here (e-cigarette-forum):
0K. Just to let you know I've done some smartass battery IR testing on the sixpack. With a LiitoKala Lii-100 charger (pumping close to 1'05A, maybe ≈1'047A, no lab equipment sorry), my standard multimeter and this mV accurate voltmeter:
Well, the voltmeter drains 10+mA (I think the eBay ad claimed 11mA).
All the cells have shown 23ish mV load/no load deltas (measured with the wires under the flat top button, it shouldn't have any significant impact at this current though). The numbers look pretty good, 22-23mΩ of resistance for these cells. Clearly 20A continuous 26650 cells, with 5+Ah of capacity.
Just remembered…
Cheers ^:)
matches with my findings.dick smith esr reads .02
unbeatable price/performance on these cells!
esr
best thing is you get to build it.
Sorry for bumping this thread, but i had ordered the same liitokala 26650 from aliexpress to use in a flashlight.
The thing is that i need to put 4x26650 bateries in serie.
After the fact of ordering and receiving these batteries i read i cannot put them into series?
Or can i with the help of something like?: Assuming a coin wont work? :slight_smile:
I nice blob of a silver based solder will do better m8, ways ways better
Doesnt need to be silver based solder its not stainless, 60/40 is mustard. Just use some extra flux or scrape the top a bit if its oxidised or dirty
https://budgetlightforum.com/t/-/41572/8
Cheers ^:)
AliExpress is showing this product no longer available.
Tested the jaxman connector in my Opus and Liitokala charger and did not see resistance go up
http://s.aliexpress.com/qMZJ3aaq
(from AliExpress Android)
Nice thingy
But after testing the inside of my S70 and L6 tube I know the anodization is good and it is not conducting
So I choose magnet for connecting and when charging I put the magnet on the top cell before putting it in the charger so it becomes the bottom one and every charge their position changes (idk if it makes a difference it just feels good to do it like this)
I looked at the link you put,but it is a mess there.The prices differ 50% between them.Which are good and which not.
I decided to use non-protected batteries that can be used in series; there are quite a few to choose from that have a positive terminal suitable for vertical series connection.
I use the Liitokala batteries in my single cell 26650 flashlights.
Or you can get them where I get mine………… RIGHT HERE . Never a problem so far with 3 separate orders.
That Jaxman connector works great by the way……. :+1:
I look at the alphanumeric writings on these batteries,and I see that there are not the same in different sites.Do you know if some of them are better than others?
https://www.aliexpress.com/item-img/Free-Shipping-2PCS-LOT-Real-Capacity-3-7V-26650-5000mAh-15A-Continuous-Low-Internal-Resistance-Li/32584248563.html#
https://www.aliexpress.com/item/1PCS-LiitoKala-26650-50A-5000mah-26650-Li-ion-3-7v-Rechargeable-Battery-for-Flashlight-20A/32547294353.html?ws_ab_test=searchweb201556_7,searchweb201602_3_10057_10056_10065_10037_10068_10055_10054_10069_301_10059_10058_10032_418_10073_10017_10070_10060_10061_10052_10062_10053_10050_10051,searchweb201603_2&btsid=3349139b-67ab-4a17-a7ae-f0cdcd7cb13b
I had no problem ordering the batteries either, what I tried to write is that the Jaxman ‘connector’ is no longer available from AliExprees. :slight_smile:
My bad, I read it wrong. :person_facepalming:
Hopefully they will come up again, they do work real good. :wink:
Probably all the same.
I got all of mine at GearBest for right around $20 US for four of them and they all check out above advertised specs. :+1:
The LiitoKala 26650-50As can also be gotten at Banggood for a similar steal than at GearBest if you are wise to check out M4D M4X's deals.
Cheers ^:)
P.S.: in fact it becomes a slightly better deal, especially with 3+ units volume discounts.
[/quote]
[/quote]
Thank you teacher.
Hmm when I follow the link in my previous post I can add a jaxman connector to my cart so it seems available to me.
:smiley: maybe jaxman just likes me :smiley:
How are these Liitokala batteries with the Convoy L6?
Is it better to go with these or the short Keeppower 26650 5200mah?
