I didn’t say anything about the PWM frequency I was talking about the levels of the PWM.
Now you use the following values:
With them, the driver has the output power levels 0.2% / 1.5% / 12.5% / 25% / 46% / 48% / 100% (instead 0.1 / 1 / 10 / 20 / 35 / 50 / 100)
I propose to change the values on
With them, the power levels will be closer to stated values.
ToyKeeper, you did a brilliant software, thank you. I now use it in all my flashlights.
Oh, I had it closer to that initially… but then I measured the power draw on each mode and adjusted the PWM values until the power measurements matched the spec. The PWM-to-power-usage curve was less linear than I expected, and it was consistently non-linear on the drivers I tested.
I’ll measure again when I get a production light, and adjust the levels if they’re not right. Maybe even make a new slow-ramp testing mode which goes through each PWM level one at a time while I log the measurements, so I can graph the shape of the curve.
On drivers with a more linear response, the default PWM levels will be a bit weird.
10x would have to be stacked chips and a DIY job. Although honestly at that point you would be better off getting a host and swapping the driver for something more advanced.
First post…I’m wondering if anyone knows for sure if the KeepPower 3500 cells will fit this flashlight. I have read a few conflicting posts - either a tight fit or not fitting. This light is on the way and I’m wondering if this battery will work or if I should order a different battery (suggestions?). Thanks in advance.
I agree that the NCR18650GA is a great general purpose cell if you don’t need crazy high drain. Just keep in mind if you’re buying the protected version of that cell it may be too tight a fit. I have the EVVA protected version and it’s too fat for many of my Convoy lights. The unprotected version should fit fine though. KeepPower is slimmer than EVVA sometimes on the same base cell so they may be fine too. EVVA protected cells are sometimes double wrapped where KP are not.
With any modern driver that has LVP there is really no need to use protected batteries anymore. I have actually never owned or used a protected battery, but then i might be a tad more capable of knowing how to use them then some people.
If the clear C8 is bored the same as a regular C8, the battery should fit even if it is an over-wrapped protected. That is what I checked the C8 with, and while it is a snug fit…. it does fit. The EVVA protected fit also, snugly.
Like J-Dub74 said, there are several Convoy lights the over-wrapped cells will not fit because of the “fatter” diameter.
I always recommend protected cells to a person who has never used lithium’s before. Not because of what happens in a light, but what happens outside of the light. People are conditioned to Alkalines and stable rechargeable chemistries that you can just toss in a bin altogether and they won’t vent because of a “little short”. Also Many people will buy good batteries then put them in the terrible charger that came with their cheap light and just leave it plugged in all night while the charge never terminates. That kind of stuff. A name brand cell also gives them something to google if they decide to buy extras without asking me. That way they have a better chance of getting good batteries instead of just googling “18650”.
I also keep a few protected cells for myself . When I build a light the first time I power it on I use protected in case I have a short somewhere I didn’t realize, from tightening down the reflector or something. It saves me melted springs and burned traces. I also have a 4.35v protected cell I use to test chargers, like ones built into a light.
<—- don’t use protected cells.
<—- have melted down some springs in my time.
Some great ideas on how/when/why/where to use the protected cells. Several years ago, when I got my Solarforce S2200 MT-G2 flashlight, I bought protected AW’s for it. And those are pretty much the only ones I have. I got the first one of these lights shipped, and it came on the day my wife went into the hospital for surgery. (was I sitting in the hospital room with her, playing with my new light? You bet your a I was! )
I actually agree with much of both quotes here. Personally I don’t use protected cells for my own lights very often. I do get people into this hobby though and I always give them a bunch of info and set them up with one of the cheaper Xtar chargers and good protected cells in their “starter package”. They’re just much safer for the uninitiated. I also use them in the lights I give to my kids and even my wife.
Most all of my many 18650 batteries (except 2 ) are protected, probably because I got into 18650 lights first and thought that was the thing to do. Then after a while, enter the 26650 lights……… all of my 26650 cells (except 2) are not protected.
Go figure……….
But, like several have said above; when I give a light and charger to the uninformed…… I give them the important info about Li Ion cell along with a protected battery………. :+1:
