ENEDED
1 x cree xp-g3 version and 18650 tube please.
Thank you
Ok, a replacement lens from Fasttech just arrived. 22.7*2mm AR Coated.
The diameter is OK, but itā€™s too thick by 1mm. Iā€™ll need a 22.7mm x 1mm lens. Any ideas?
You have to preorder it yourself from BG.
Please check the first post for the link.
I will order 3 lights next week but unsure if i should get either Nichia 219B or CREE XP-G3
can someone help me pick ?
im like warm tint so Nichia is the right choice?
Both tints are pretty close in my opinion.
Choose 219B if you want high CRI.
Choose XP-G3 if you want higher lumens.
My lux meter cable broke right after my Imalent review test. I am still waiting for my new meter to come in. I have a quite a few new gears to work with this week. I will publish the results if I manage to fix my broken meter.
Any word on a warm tinted Nichia version (S41SW)? :innocent:
Iā€™ve been ogling this light for a week or so now.
Itā€™s calling my name and says: Buy me, buy me !
Bought 2 M01 SS Nicia and a A01 too lately (not arrived yet), maybe should have bought this S41S in stead, or just buy it alsoā€¦?
Will this clip fit the extension tube?
The extension tube seems to be suited for a clip.
The S41S comes with SS clip unless you need a spare.
Yes, youā€™re right, itā€™s just not in the pics of the S41S.
Thanks.
Holster for your Astrolux S41/S41S.
Freeme,
Sorry if itā€™s been asked already, but are the traces on the MCPCB set up properly this time vs the wrong way on the standard S41? ieā€¦ negative traces should be on the outside edge of the board?
2 x cree xp-g3 version S41S and 2 x18650 tubes please.
Thank you
Does the xpg3 have color options? 5000k? Does it pull 16A on a 18650? How much on a 18350? Is cr123 usable?
XPG3 should have 1000lm @ 3Am times 4 should be in the ballpark of 4000lm on turbo. Or more if you can pull more amperes considering the low vf at 4A, then 5600 emiter lumens is very possible. In reality at least 3000?
Iā€™m not purchasing until I know the answer to this.
Yes they are good now.
Thanks giorgo, but it still doesnā€™t say whether or not the board has been changed. All I see is a plastic washers added to the bottom of the screws.
Robert , if you look closely , leds has been reflowed on the opposite direction , and negative lead from the driver has been connected to the ā€œ+ā€ side (outside) of the LED board . :beer:
Ok, thanks. Couldnā€™t tell from the picture. I guess BG is reworking all the boards left over from the S41 instead of making new ones.
editā€¦ I do now see the wires have been swapped. My monitor is old
Price has shot up now.
