I think I made the request for the LiitoKala 26650-50As some time ago. HKJ said they weren't on his list…
Besides Mooch at the E-Cigarette Forum, I don't know of any other willing and/or capable of doing a decent review of 'em. My bet is, unless HKJ changes his review policy (which may be mediated), Mooch is our only chance for now.
These bad boys i bought mine from Fasttech so damn cheap and they perform well just a tad under my AW 14500 IMR cells but so much cheaper. i think they are the same as the Fandyfire 14500?
I would like to see reviews on 9 volt batteries.
I have been using a 9v nimh duracell ultra for some months.
Works fine but it requires a special charger. Luckily I moved from the classical cheap 9v charger that took a day to charge, and I am using an imax B6 at 0.1A. Now the charging is quicker and I get more runtime from the instrument.
I am getting a li-ion rechargeable 9v battery, a zenter s19 9v, that should allow me to have a lot more runtime and won’t require any special charger. In the eventual reviews, I’d like to know, if possible, if this model, or any other li ion rechargeable one, can be recharged while used.
EDIT: also, I’d like to know which nimh 9v battery tipe is best for which application (8.4, 9.6, 10.8…).
I have been ordering some 9V batteries from Conrad.
And thanks for the link to the updated battery fixture. I do not know if I will review it, but I have ordered some for my own use. I do not suppose they will melt as easily
I will include some LiIon in my 9V reviews. Teardowns will not be included in the reviews, but may be done at a later date.
I doubt the 9V with two cells in series has balancing, but I have not going to do a few months of cycle tests.
Cycle testing is easy enough to do, but it would require an extra DMM connected between the two cells to really see any unbalance and it takes a lot of time to cycle. 100 cycles on a 18650 cell is about 1 month testing time when keeping current reasonable (1A).
Whoa da -- it's here! The 20700. Didn't realize. so 12A max continuous. The capacity is look'n. Guess resistance is better than GA's, not as low as a 30Q, based on it's max 12A rating. We'll see if this makes a good percentage of our lights obsolete.
