If the clear C8 is bored the same as a regular C8, the battery should fit even if it is an over-wrapped protected. That is what I checked the C8 with, and while it is a snug fit…. it does fit. The EVVA protected fit also, snugly.
Like J-Dub74 said, there are several Convoy lights the over-wrapped cells will not fit because of the “fatter” diameter.
I always recommend protected cells to a person who has never used lithium’s before. Not because of what happens in a light, but what happens outside of the light. People are conditioned to Alkalines and stable rechargeable chemistries that you can just toss in a bin altogether and they won’t vent because of a “little short”. Also Many people will buy good batteries then put them in the terrible charger that came with their cheap light and just leave it plugged in all night while the charge never terminates. That kind of stuff. A name brand cell also gives them something to google if they decide to buy extras without asking me. That way they have a better chance of getting good batteries instead of just googling “18650”.
I also keep a few protected cells for myself . When I build a light the first time I power it on I use protected in case I have a short somewhere I didn’t realize, from tightening down the reflector or something. It saves me melted springs and burned traces. I also have a 4.35v protected cell I use to test chargers, like ones built into a light.
<—- don’t use protected cells.
<—- have melted down some springs in my time.
Some great ideas on how/when/why/where to use the protected cells. Several years ago, when I got my Solarforce S2200 MT-G2 flashlight, I bought protected AW’s for it. And those are pretty much the only ones I have. I got the first one of these lights shipped, and it came on the day my wife went into the hospital for surgery. (was I sitting in the hospital room with her, playing with my new light? You bet your a I was! )
I actually agree with much of both quotes here. Personally I don’t use protected cells for my own lights very often. I do get people into this hobby though and I always give them a bunch of info and set them up with one of the cheaper Xtar chargers and good protected cells in their “starter package”. They’re just much safer for the uninitiated. I also use them in the lights I give to my kids and even my wife.
Most all of my many 18650 batteries (except 2 ) are protected, probably because I got into 18650 lights first and thought that was the thing to do. Then after a while, enter the 26650 lights……… all of my 26650 cells (except 2) are not protected.
Go figure……….
But, like several have said above; when I give a light and charger to the uninformed…… I give them the important info about Li Ion cell along with a protected battery………. :+1:
Mak 88, I forgot to tell you this. The dimensions of the largest 18650 battery I tested in the C8 was 70mm x 19mm. It was a button top.
So the one you referenced should be just fine.
(The absolute largest cell my particular C8 would take would be about 19.1mm x 71mm )
Definitely. Especially outside the flashlight community, I’ve often found people really have no clue at all about batteries. A protected cell might not stop the abuse these cells are often subjected to, but they do at least prevent errors bad enough to hurt someone.
It’s still depressingly common to see people over-charging cells constantly, always leaving them in a charger which doesn’t actually terminate, so that it keeps going until the protection circuit kicks in at ~4.35V. I’ve even seen companies recommend this type of behavior with their products. Or charging a 3.4Ah cell at 3A, with the cell insulated inside a product with no way to shed heat.
In a flashlight I use unprotected cells but in my headlamp I always use protected ones. Something about strapping that much unprotected energy on my forehead…
Maybe I missed it but does anyone know if this new driver/firmware still retain the Low voltage protection function and Battery reverse protection function?
Thanks for the help and advice!
I meant to include in my post that I had received the battery and wanted to make sure it fits before I receive the flashlight. I wouldn’t mind getting unprotected in the future but the only experience I’ve had with rechargeable batteries have been some terrible AA’s prior to 2005 and eneloop style (stored in a powerpax caddy) for the past 2 years. Also picked up the Nitecore D2 charger.
Sure thing. I took it in the first place you had the battery and was trying to make sure it would fit your inbound C8.
Nothing wrong with protected batteries, don’t be in a rush to get unprotected till you get familiar & comfortable with Li Ion’s in general.
“Hey, if you ever want to get any more batteries, ASK ME.”
I’ve had people innocently ask me if they should get Bonfire or Housefire batteries, “because they’re 4000 mehs instead of the 3400 mehs you got me”. Just the look on my face usually screams “Noooooo!!!” without saying a word.
Good pernt; never thought of that.
I like protected Panny-Bs. Sue me. I use them with all premade drop-ins I bought (no idea what’s under the hood), and with non-105C drivers (diode + #×7135), because they don’t have LVP.
Those lights with 105Cs, no problem, I’ll throw in one of my Samsungs or LGs.
which I’ve been using pretty much extensively for, well, a long time. My i4 hasn’t seen daylight in about as long.
It’s a sloooooow charge, so it’ll go overnight and then some if you start from 2.8V or so, but so what? Most people I’d give these to, aren’t the kind of people who’d need <1hr charging. I even keep one in my bag so I can charge up at work, etc. Fits 71mm cells just fine, too. No problem with protected Panny-Bs.
And at 2bux a pop, I probably got like 10 at this point (some given away).
