You are right, it seems that you have contact with it. SinkPAD have this technology in USA, and we had done a couple of years ago. Recently used in a flashlight is very common.
Mini heat-pipes… thermal conductivity can be orders of magnitude better then diamond and should allow the LED to be soldered directly onto it if profiled correctly and pressed into a MCPCB.
Another thing to add to the list of things to try.
I do not know why, with your method the results are blank after insert picture. If “Text format” is “Advanced Post Editor”, using the “insert/image” ,it’s ok and I can see it.
[quote=aliang802]
Really? Then how can I do it? But I can see the picture I sent.
[/quote]
Where they are located (the images themselves)? Maybe you should try uploading them at some public image hosting, like Imgur.
[/quote]
Image is located in my 360 cloud disk. Curiously, I can see my picture on the forum, but you can't.
If that’s the case, it might be a permissions issue. Try logging yourself out of your 360 cloud disk and load this page again and see if you can see the pictures. I know I can’t see them.
Can’t see them either. When you do load them using the picture icon set image size to 100% rather than pixels x pixels. This automatically sets the size to match the page.
With all the not so subtle hints I keep getting from my girlfriend about something called an engagement ring (huh?), if I did that, I’d have to sleep with one eye open.
A couple of years ago one of our members(PilotPTK) with input from others here designed the 16mm copper sinkpad which they then produced so it’s been known of and used here extensively for some time. What I don’t understand is why sinkpad puts such narrow traces on their other boards.
