Please do not rush this product. If there’s anything we BLF’ers are good at is to quickly spot massive design/manufacturing flaws in highly anticipated flashlights.
Yes, and in a less fortunate case, non flashaholics can spot the flaw as well. Indeed, do not rush these products; they look too fine to have serious flaws…
I like getting a good deal and all, too. But let’s wait to see pricing before we start talking about discounts. Who knows, it could be a great price without any sort of discounts. And from what HaikeLite is saying, it won’t be much longer. For coming here and letting us make suggestions, I think the least we can do to show our appreciation is to not discredit their pricing (nor call their quality into question).
Final UI changed a little , Added hidden Strobe and SOS modes ; Press and held 1 seconds in any status to active.
Switch 1:
Single Click-on ; Single Click-off ;
Fast double-click Turbo (Double click switch 1 in any status to acess; easy to access)
Long-press to Strobe; Long-press again to SOS
Switch 2:
Low Low-Low-Mid -High (single click to change modes ; with last mode memory)
Hidden Moonlight 1 lumens (fast double click switch 2 to acess; easy to access)
Special modes always go back to previous memory mode by single click ; (Special modes can circle among special modes by double-click or long-press)
Memory mode: Low Low-Low-Mid -High + OFF
(We call Turbo/Moonlight/Strobe/SOS as special modes)
by Switch 2, Click+hold+flash signal to lockout the light; Repeat to unlock. Tailcap-lockout also available
Temperature stepdown added to HaikeLite thrower on Turbo mode; Turbo mode can last long time (around 15 minutes)before overheat and it gets cool again fast in 2-3 minutes
Gold-plating components changed to Silver-plating
Wire changed from 20 gauge to 18 gauge
Emitter drain on Turbo adjusted back to 6.5A .
7.5A gets hot too quick , even with the massive integrated head.
“XHP70 can output more lumens, the deep and thick cooling fins of this monster are designed for XHP70. Heat-sinking is amazing, on 7.5A turbo mode the big head part gets warm quick and never get too hot.I can hold the light in hand all the time.”
Can you also provide lumen values for the XHP70 with their respective runtime?
1. Double-click turbo is easy to access in any mode or off.
2. We have tested this turbo-momery UI already.
When we put turbo in modes with switch 2 and memorize turbo mode, It will be confused when people double-click in memorized turbo and find the brightness has no change.
Will be like this:
Single click-Turbo brightness-Double click—still Turbo brightness—Single click to previous memoried mode—Still turbo brightness
It means when you are in memorized turbo, you click four times , the brightness has no change. Isn’t it annoying?
Interesting... I thought about this same exact problem in my firmware. I have a double-click go to turbo (same as this), then if in turbo, a double-click will go to an intense strobe, ~18 Hz. It seem natural - increasing mode intensity with each double-click. Once in strobe, double-clicks don't work anymore.
I'm excited about this one! It has the size to do the XHP70 some justice. Advantages over the popular XHP70 throwers, being the ThorFire S70 and Convoy L6:
bigger reflector diameter = more throw. 88mm head diameter compared to 74/75 mm. The important metric: inner diameter of the reflector is 72 mm (62 mm for the S70, L6 - not sure, not published in specs or reviews I could find)
more amps on turbo - another big factor in output and throw
better power plant - four 18650's vs. two 26650
better dual switch setup. I've always believed 2 e-switch's, or a 2 stage e-switch is the best way to go
The ingredients are top tier, but we'll see how it cooks up.
I can see some obvious issues:
a 4 battery tube is wide and short, so the handling and balance will be important to judge. It's one of my main concerns from the photos.
style and look - I really like the L2 and L6 style, but there are trade-offs with thermal management and functionality, but I do like the knurling on the top of the bezel, which sets it apart from the S70 and L6
One light that it compare with at the same level is the AceBeam K60, having the same head diameter and battery configuration. But the K60 is lighter and somewhat longer.
This. I realize the XHP70 is capable of more lumens but if this is intended to be a thrower then I would think throw would take precedence over lumen output?
