One quick question.
Is Convoy C8 or other light this type with XPL HI V2 or V3 ( with standard driver that comes with flashlight ) enough for use Samsung ICR18650-26F with 5.2A or any other battery about 5A or it need some which is capable of delivering 10A or something between ?
The ICR18650-26F is enough. In stock form the highest powered Convoy C8 draws 2.8A from battery at highest mode. In other lights depend on driver. In an astrolux A6, S2 or S3 you need a high drain battery because these can draw 4-5A from battery if you bypass springs.
I think the C8 is called a C8 because it’s kind of a standard model across several manufacturers. It existed before Convoy did. Otherwise, I think the small/medium/large thing is probably correct. And then there’s the BD line, which I don’t know the reason for. Battery something, probably, since they have a charger built in.
I thought maybe BD comes from Dipper, such as the Dipper BD01 and Dipper BD02 found on banggood. Maybe BD means “Battery Dipper”, to indicate recharging capability?
I think J-Dub74 went with the L2 design for the L6 conveniently making the L stand for luxury
There should be a smaller L1? C8 model down the road.
BD series is not a Convoy design I thing. But could be wrong
S for small yeah that makes sense. The design of the tubes is also not that special it can be found on various branded lights.
AFAIK the L6 and maybe L2 are genuine Convoy designs and thus seeing a Panicfire light with same design in future would tell us it is Chinese borrowed
I would love to see that smaller L1 and a real brand line up from Convoy like Olight has for example.
Was curious why I could never find a convoy.com or anything, outlining which models were available, features/pix of each, etc., despite easily finding all sorts of Convoy lights at FT, GB, BG, MTN, etc.
All I noticed was that the S series was all tube-lights, the L series the bigger donks, and the M series somewhere in-between. No idea where the C8 fit in, and thought the C stood for Convoy.
The Samsung 26F will even run a direct drive FET style light, it just won’t give the absolute output a lower internal resistance cell is capable of. They’re decent cells though, and sometimes it’s nice to have a lesser cell to put in the A6 or X6 for loaning to a friend so it doesn’t get so hot if he abuses it.
Quick question about the clear C8… aside from CW/NW/WW, are there any other “tweaks” or options possible?
AR, want. DTP, want. NW XP-L HI, want. Everything else, want. Only tweak I’d want is a different driver, a 2.1A (6×7135) 1-mode. Oh, and a forward-clicky, mustmustmust have (willing to buy separately, no big deal, uhh, as long as the threads match).
I specifically need a super-thrower with no chance of flipping modes under any circumstances, and it needs to have momentary-on (hence the forward-clicky).
Now, I looked at the XinTD, and yes to the forward-clicky, but no XP-L HI (XM-L2 only, I believe), and not sure of the driver (it’s 8×7135, and I’m hoping it can be kept on indefinitely vs needing a cooling-off period).
Basically, I’d love to pick’n’choose from different menus, but…
Yeah, I have my own 2.1A 105Cs, but for once I’d like to be lazy and just buy one off the rack vs rolling my own. I got the host (real Convoy, type 2), bare XP-L HIs on the way, but just for once I want to not have to reflow and solder and reflash and do the usual grunt-work building my franken-8.
I’ve got 20mm 6×7135 drivers (no µC), but not 17mm. Not enough trace around the edge to shave down to 17mm. I’d be okay with a 2.1A 105C flashed to 1-mode-only (wfo), or have the µC’s PWM output hardwired always-on.
If I have to, franken-8 it is.
So, any chance of getting a forward-clicky, and 1-mode driver (iff it’ll run at 2.8A for long periods w/o cooking the LED)? Worse comes to worse I can desolder’n’remove 2 7135s.
The S2+ can be run at 2.8 A until the battery runs off without issues, but your hand may suffer a bit. I don’t believe that the bigger C8 could have worse thermal management than the S2+.
I own several BD lights that I bought directly from Simon on his Aliexpress store. Came in a Convoy box and was even labeled:
“Convoy
BD03” directly on the light.
I’ve seen them called “Big Dipper” but don’t recall if that was on a Convoy site or some other site. I believe that the BD line are all USB rechargeable, but I’m not certain.
Honestly, I tend to design very conservatively, so even though an LED can probably handle 5A+ and elevated temps for a while without bursting into flames, I try to at least keep things manageable for the LED regardless, if anything for better lumen-maintenance. (I’m one of those weirdos who uses AS5 as thread-lube screwing in a pill to the case.)
Hey, I had a ’98 for about a year, ran it full tilt all the time without a second thought, and was horrified when I discovered the hollow pill, so now it’s in pieces waiting for me to copper-fill the bugger somehow (and drive it at ~2A vs <1A). The floating star never transferred much heat to the case or the pill, and now I know it was because it was all bottled up in the LED. Eep!
So yeah, I’d rather let my hand tell me things are getting a little too toasty, vs not knowing the silent-scream of the poor little critter as it was suffering.
And I probably wouldn’t be keeping it on for too long in one burst anyway, but you never know when you might have to.
Lightbringer, I’m sure if you ask Simon when ordering you can get the 6*7135 you prefer. I think the C8 comes with a forward clicky, but you can also ask him to use one to make sure. With Bistro-Mini (or Biscotti) you can select mode 12 and forget about it. 100% all the time. The light will be coming with DTP, you will already have an AR lens, and you should be quite happy.
Simon loves flashlights like we do, ask him in the messaging screen before finalizing the order on AliExpress and he will get back to you, pretty sure he’ll fix the light up any way you like it and would probably even engage level 12 at 100% only for you so you would have it operating as you wish right out of the box.
This new C8 foes have coated glass and DTP star and XPL hi right?
Just choose your mode in Biscotti and it seems like you have the light you want!
The BD01 and 06 are almost the same light with these differences:
BD01 comes with two rubber rings under the tail spring to slip over 18650 cell so that can be used instead of 26650.
The BD01 is bigger
Tube and tail of them Lego
the 06 is easier to pocket and a bit cheaper.
I like the looks of the 01 more but use them both (working on reviews so while doing that do a charge cycle twice a day and they both charge excellent)
The BD01 has a ~50mm head as compared to the BD06 having a 42mm head. The crenelations on the 01 are smooth, more gentle where the crenelations on the 06 are sharp and more pronounced.
I know the charging indicator lights through the reflector on the 01, don’t think it does on the 06. What I mean is, with the BD01 when the light is charging you see the illumination inside the reflector cup, it comes through a clear centering ring around the emitter. Looks really cool, I don’t think the BD06 has this feature but I’ve not seen the 06.
The BD01 I also know to have a 7135 regulated driver, easily bumped for more power. While I THINK the 06 does as well, I haven’t seen that one.
