Both lights are very bright, but the TN42 is a bit brighter. If you can’t handle not having the brightest light, just buy the TN42 and spare us your attempts to justify your purchase.
I’ve discussed with friends here for some time how it’d be cool to actually go downrange and try to read something by the output of the flashlight at X range. Like, as I’ve posed, if a girl wrote her phone number on the inside of a matchbook cover could you read it with me shining the light from that range? So last night I had the wife assist me, we were on the phone with each other and organized the details between cars and such, and she could actually read by the light produced by the TN42 from a mile away. I turned it off and she was cast into darkness. Very noticeable difference in having the light on or off, she said. I had the light clamped onto my tripod, camera on top of the tripod, so it was stable and the target aim was repeatable.
But the situation there on our country road was not amicable toward me getting the shot with my camera. So, I scouted the area on Google Earth and found a new location. We went this afternoon and scouted the two sites in real time to make sure it was feasible. We’ll be shooting from across the lake, a mile between shores with zip between us. Tonight it might be raining, but this week for sure… new moon on Friday so each night from here out all week will be darker and darker. Last night was perfect because heavy storm clouds had all stars and moon blocked off. But it was very humid as well as other issues. I’m hoping that when this system moves out the air will be nice and clear and we’ll get the shots.
We plan to have 2 tripods, she’ll have my little Canon G1X with her to get a shot of the paper with text, as lit by the TN42 a mile away across the lake. I’ll have my Canon 7DMkII and EF 70-200mm f/2.8 L IS with the IS turned off for a more stable shot on the tripod. If all goes well, we’ll have the shot from both ends and definitively show a discernible text lit by an LED flashlight a mile away.
Hmmm, what if I could pull it off to have my wife shine a green laser at me across the lake, lining up the TN42 directly into that laser for spot-on accuracy?
I need a guy to help me, my wife doesn’t care enough to get it this right…
Astonishing to me that an LED can throw so far, especially a factory made light without modification. Someone has been paying attention, for sure!
I’m not sure there’s a “hot spot” left out at the mile mark. Remember that throw is calculated at having 1/4 lux at the maximum distance, or essentially the point where the lights output is equivalent to a full moon in brightness. So while it might indeed throw very far, it’s not like it’s still bright at that distance.
What I really like is how bright it is at 500-600 yards, or less. Sure, there are lights than put light out to 300-400 yds, even 500 or 600. But can you actually see the difference between a dog and a coyote under those beams? With this TN42, the sheer amount of power it still has at 500-600 yards makes it easy to identify cows in the herd, calves as compared to dogs or coyotes, or even if it’s a spotted skunk or one with two striped compared to one stripe. (we have 3 main kinds of skunks here.)
I can’t see a mile, but having this much power at half that far is very helpful!
I thought about calling them in on this. They’ve been planning on coming over for a while now, both have some new guns to shoot and I have a lot of new lights since the last time we hooked up. Not sure if rdrfronty is still interested in the lights, but he’d be happy to help…. after he got his hands all beat up with the cannon’s he prefer’s these days! lol
Not sure about the amp draw on the TN42 but my K70 draws 2.6A from 4x 18650 in series, and the LED is being driven so hard there is noticeable tint shift in turbo vs high, about ~700k cooler and it gets hot quicker than the nitecore TM16GT with 4 emitters. I don’t expect that XHP35 to last very long like this…
Judging by the beamshots I would say the K70 has more lumens and brighter spill but less throw, although the 150kcd difference is hardly noticeable in the unzoomed pictures.
I bypassed the springs in the carrier with 20ga Turnigy wires. It didn’t impact output any at all but should be making life a little easier on the cells… run time should be a bit longer. Still seing 702.5Kcd on the meter.
Question… I don’t want to spend a lot of time lining up the light for the one mile beamshot and have it start ramping down or anything (not sure how all that works on this light yet anyway) so what I’m thinking is to use the accessory clamp I have on my tripod to clamp the green laser, this will let me line up and true the stance of the tripod such that the clamp is pointing straight at our downrange target without even turning on the TN42. Removing the laser from the clamp and replacing it with the TN42 should still see direct linear output downrange. Does this make sense? Mind you, the green laser hot spot will be significant at one mile as well, most likely some 10’ in diameter at that range. I’ll be on the phone with my wife so she can help me line it up centered.
Here’s the clamp on my secondary tripod. This tripod will be downrange, I’ll be using a carbon fiber model capable of over 60 lbs weight attachment.
The clamp is an Impact (Impact is the name brand, Adorama.com) Double SuperClamp, model CC128, make to attach lighting and accessories to poles in photography. The set-up in this pic is how I normally take beamshots, Canon G1X at ISO1600 f/5.6 1/2 sec exposure with a 2 second timer and all manual focus settings.
