No J-Dub74 you say it wrong, IF we see a clone of the L series (so please make that L1 happen ) we buy a L at Simon of BG/GB/DX/FT with the Convoy name.
Holding the BD06 and no sharp edges.
And while charging it shows red or green just like the 01
The only real difference is head size.
About more pronounced edges, I am thinking of a test to kind of prove “pocket friendliness” but havent figured it out yet
It is good to think of something so I am devoting time on it
Sweet! The site didn’t go on about it as they did the 01 so I wasn’t sure. The bezel has much different crenelation on the 06 than the 01, 6 ridges instead of 5, and this on a smaller head so they are more compact, look to be more angular instead of flowing like on the 01.
I’ve had the 01 here, bumped output on it and fine tuned the beam profile a little, it’s really quite nice with a small bit of TLC to tweak it slightly.
I can attest to that. Bought a bunch of cheap C8 clones at too-good-to-be-true prices, intending to just use them as hosts. Yeah, too good to be true.
I’d gotten some before, pretty decent brass pills, XM-L (genuine or lookalike, dunno, but pretty good), pretty bright (>300lm, at least, from ceiling-bounce tests), not bad for an Amazon special…
These… pfft! Plastic reflector, cheap featherweight Al pill, XP-E sized LB emitter, maybe 80-100lm of angry-blue light, tops. With a decent brass pill from FT that fit fine, a real 4300K XP-E2, new driver, it throws pretty nicely, but still isn’t a light I’d put much faith in. Still got the plastic reflector (ordered 3 different types of Al reflectors from FT to see which’d fit best), but just adding up the costs of getting the cheapo host to do anything (decent pill, reflector, switch, etc.), it’s just plain not worth it. I’d rather just get the real Convoy host from FT that’s all ready to go with solid parts, not crap. Much less agg as well.
If they were to ever clone the L2/L6, you can bet it’d be rated 45,000lm (maybe 150-200lm tops in reality), be half the weight, have horrible purple-blue 7500K LB XP-E clones, and just be an embarrassment to flashlights everywhere.
So, got my new C8. Looks really nice. The glossy silver look is really catching.
However no matter what mode grouping I program the light to, no light is emitted in any configuration while in moonlight. Down to 1% everything is fine and on high it seems just as bright as my older C8s but no moonlight.
Not a huge deal, I can use it on a mode without moonlight, but just wanted to see if other people have/are experiencing the same issue.
Edit to help diagnose:
Tried with NCR18650B flat top, NCR18650GA raised flat top and EVVA protected NCR18650GA button top.
Programmed into configurations 2, 3, 8, 9 and same behavior. No light on moonlight.
Edit2 : Reprogrammed it back into a mode with moonlight and got the led to flicker on moonlight mode, eventually resting on a level that is indistinguishable from 1%. After a few cycles though, moonlight goes back to emitting no light at all. I actually have a second new C8 but left it on my desk at work without testing it. Eager to see if it has the same issue.
Hmm, curious observation msim. ToyKeeper has mad firmware skills, so I’ll bow out when she arrives. But until then…
I see Biscotti has moon defined as PWM level 1, but I’ve had trouble before with the LED not turning on until I started at 3 or sometimes 4. It seems like 1 just isn’t enough sometimes. I wonder if that’ll need bumped up.
TK doesn’t set a value of 1 out of 255 for moon with 8*7135 chips. Even one 7135 chip needs a value of about 3 or 4 maybe. So the dilemma most likely stems from the specific 7135’s on this driver not liking the absolute low value, it’s always a gamble, trying to get it as low as possible but still have it work on “all” the drivers. Really difficult to do.
Edit: I’m seeing values of 3,4,5,6,7,8,10,11… in the code for the 7135 driver. So 3 is the lowest and in some cases it’s not quite enough by a value of 1. If you set it that 1 or 2 higher, the vast majority complain it isn’t low enough. Set it low enough, a few get a driver that loses moon… whatareyagonnado?
Yeah Dale, dunno. I’ve been compiling a modified version of Biscotti today but haven’t had a chance to flash it to anything yet. The Biscotti source on launchpad has the following array of PWM values:
Every other line of PWM values (commented out) starts out at 3, indicating she usually does use 3 for moon. I think I typically stick to 4 to be safe. Not sure why this one starts at 1.
Dale, what repository are you looking at? I only see one active line of PWM values (line 82 here), and it starts out at 1. Does TK have another place she keeps code?
Hmmmmm, that is interesting.
Kinda like “damned if you do & damned if you don’t”. That is a tough place to be put in……… :weary: …
Personally I have a solution to that problem….
But, since it would not even be close to clearing the “PC Bar”; I will refrain from sharing it……… :smiling_imp: …
Possibly, but hopefully this is just a one-off situation. And while I like having the option of a moonlight mode… how often do you pick up a light the size of a C8 and say “I want an almost indiscernible amount of light from you!”?
This world takes all kinds of people! Some of us code all day long, some drive tractors, other save lives. We’ve all got an amazing role to play! (not to down play TK’s great work - code can be a work of art sometimes!)
TK sent me the code she was sending to Simon, I flashed it to a C8 for JDub as well as a different code set to a few other lights (mistakenly, sorry Jared!)
She very thoughtfully has the code set up for those who would like to tweak it to their own drivers, both FET and 7135 lines are present throughout, all one must do is choose which style they are using.
Please contact Simon through the store. I’ll mention it to him as well but I know he will want you to contact him directly. This is the first issue I’ve heard of but this is all completely new. Hopefully it’s just a fluke. Any problems will be resolved properly I’m sure. Simon would not ask you to “live with it”.
Good news, seems like it might in fact be a fluke. Just did a quick test of my 2nd new C8 that I had left at the office, and it doesn’t show that behavior at all. Moonlight seems to work just fine on my 2nd one.
