Test / Review: (OLD) Panasonic NCR 18650A 3100mAh batteries $11.96 Protected and $9.97 Unprotected (OLD)
If you say so.
M.
Hi bro,
Technically you are correct for your described need....but then the Crelant 7G5, Shadow TC6, SR51, BD-4, STL-V2, DBS 3SMs, CQG Magic Wand, Catapult, T40CS, V60C, TK35/50/60, Masterpiece Pro-1, multi 16340/18350 capable flashlights and many others can't be useless. Smile I have quite a number of these lights and others as well. We also use lights for commercial/professional use in another country, and for my use it's for pleasure.
Testing cells at 3A is only part of the whole story. How about for one of my flashlight, coz it discharges at 5 amps. 3A can't be useless.... Stuff from the commercial custom mods/Elektrolumens/Lambda regularly go above that even.
2 nights ago i was modding my HID, so i needed quite a number of hours of good light. The CQG extreme runtime (3 x 18650) proved quite useful. Running > 1 cell enables you not to gun the cell too hard.
There are also very good lights from Jetbeam/Sunwayman/Fenix/Xeno/Elzetta, expensive yes...that have XM-Ls or XP-Gs that do below 2A.
The factory has deceived us, we paid for performance PTC but instead it seems they have used fewer components in the PTCs.
We had some much trust in these protected batteries that we have contacted HKJ and send him for free our batteries to be tested. HKJ can confirm that. That is what we told some clients to be as our official report, where we were expecting very good results. And we wanted a top quality tester to do it.
The Panasonic NCR18650A cells are new and genuine and very good cells.
Our conclusion is that the protected cells are usable to currents up to 2A. Even better if the cells are used in a series where the current to the led is 3A because then the current taken from each cell is 1.5A. In these situations the protected cells will perform well. Without the PTC the cells will be able to sustain larger current, because the PTC will not block them.
We have said to Benckie that we would reward him if he would do the things we asked, in our first reply to him. That's why we refunded him, to actually make the time to do it and we thank him for doing the tests.
Not quite sure what you are on about dude.
As for discharging to 2.5v with a low current most chargers will not initiate a recharge.
Or am I not getting what this dude is on about either?
"What is real world for eveybody. I've seen Benckie putting a stop every time on 3V. What's real about that?. Many flashlights stop at 2.7V. So do I say it's real to ignore that I can have more runtime donw to 2.75V or 2.5V.
My Shadow TC6's driver is designed to cut at 5V. So yes, some 2.5V cells are be good for me, or others using this flashlight. I many times use it on low and medium so i need longer runtimes.
So from my point of view, I need tests done for 0.2A, 0.5A and 1A. That why I find 2100's test for the Panny useful. "quote"
You probably mean the PCB, that is the circuit at the back of the cell. The PTC is mounted inside the cell and in front, together with the CID.
I have already talked about the cells in this thread, but have not received them yet.
Look at the cut-off voltages tests done by 2100. I thank him again, for one of the most useful info ever.
Think about the CPF guys which like only moonlights and firefly modes, so there no need for invoking reality when the CPF has 130.000 members.
Well - I just tore the protection of one of mine.
I have quite a few chargers, the Trustfire TR-001, UF WF-188, a few cheapo chargers (from my lasers) and a hobby charger. All are ok, the lowest i have gone is 1.7V. (disclaimer - don't try that yourself! LOL! Sealed)
PS. Posted earlier in this thread, and also the Sky Ray 3800 thread, where i tested the runtimes of 2 x 2900mAh NCR18650 in a real world Sky Ray 3800. That one draws 2.6 amps and goes as far up as 4.2 amps, in reality. It has low-voltage cut for the driver so it's quite convenient to test.
yes but Redilast 3100 works fine!
The Xtar WP2 II can charge from below 2V. UltraFire WF-139 can do below 2.5V charging also. In HKJ's review you can see 2.25V
Bro! I see your "6 amps DRY". Try not to gun it that far up with fully charged batteries... hehe, not even at Yakutsk. No use, spoils your cells faster, etc... Gross overdriving is more for HIDs and incans. HIDs LOVE heat. (provided you don't care about longevity, but no issue of coz for flashaholics short playtimes).
M.
I have to admit, i "only" have a IMAX B6 so i am limited to 1A. Mainly that is for recharging my Pb because the stock ones take too long....i wasn't too keen on iChargers as they are over 70 bucks and i don't do RC. It's bad for regular Pb (non fancy AGM or what fancy types) of course to do above 0.3C but heck they are so cheap (15 bucks for a 7.2AH and yes it's a fresh one with ~ that capacity). From what i see on hobby sites, most entry level models have NiMH and Pb modes...so below 3V discharge is not an issue. Most flashlights do go below 3V per cell esp for 2 x 18650 lights and they don't dim much, if you don't believe my few tens of flashlights, check out HKJ, he probably has EVERYTHING in the market. LOL! Sealed
PS. I know there are some which do specifically Li only...but RC do make use if NiMH as well. If you ask Lambda, NiMH is not inferior to Li-ion.
There were a couple of good guys, i think DasFriek, who tests and includes graphs as they can log....wonder where are they. Some good guys like Agenthex has left too!
They are a good value charger, must have sold millions, but like you say only discharge at up to the standard budget charger 1A.
Have to get Benckie to do a discharge at 3A to 2.5v using a nickel program!!!
M.
Thanks! Yes, I mean PCB.
Hank,
Unless electrical physics has changed since I went to college, I think you mean two batteries in parrallel the amps from each cell will drop to 1/2 of the amps the LED pulls. Your example is for a constant current draw which works out as follows:
Ex. : Control 1 battery - 3V (I chose a round voltage for simplicity, think CR123) @3 amp
2 Batteries in series - 6V @ 3 amps each cell
2 Batteries in parrallel - 3V @ 1.5 amps each cell (3 amp total)
Now, you are correct if the you have a constant power draw by the LED. A series battery installation will give twice the voltage which would only require 1/2 the amperage to provide the same amount of power.
Yes, for example the Shadow TC6 needs two batteries. The current drawn by the driver is 2.6A-2.7A, and each battery will give half : 1.3A-1.35A
I'll test to 2.5 volt if people want me to, 2100 has tested to 2.6 volt at 1 amp, so I dont see the need but I will do it but I'll do it at 3 amp.
Like I said I don't see the need to go past 3 volt as for my stuff I have all cuts out or dims around there and my multi cell lights go into low mode around 6 to 6.6 volt under load, so that's the reason why I stop at 3v.
Most batteries have a recommended 2.75 maxium discharge or low voltage cut around there the diffrence between 3 volt and 2.75 volt is very very slight with most cells.
The protection units with these sells from hank will not go past 3 volt any way so I don't see the big deal that's been made about me not testing them to 2.5 volt, as for the none protect versions they have been tested many times.
I've spent long enough on these cells just for you guys to bitch, but to keep you guys happy I spend some more time on them
