The factory has deceived us, we paid for performance PTC but instead it seems they have used fewer components in the PTCs.
We had some much trust in these protected batteries that we have contacted HKJ and send him for free our batteries to be tested. HKJ can confirm that. That is what we told some clients to be as our official report, where we were expecting very good results. And we wanted a top quality tester to do it.
The Panasonic NCR18650A cells are new and genuine and very good cells.
Our conclusion is that the protected cells are usable to currents up to 2A. Even better if the cells are used in a series where the current to the led is 3A because then the current taken from each cell is 1.5A. In these situations the protected cells will perform well. Without the PTC the cells will be able to sustain larger current, because the PTC will not block them.
We have said to Benckie that we would reward him if he would do the things we asked, in our first reply to him. That's why we refunded him, to actually make the time to do it and we thank him for doing the tests.
As for discharging to 2.5v with a low current most chargers will not initiate a recharge.
Or am I not getting what this dude is on about either?
"What is real world for eveybody. I've seen Benckie putting a stop every time on 3V. What's real about that?. Many flashlights stop at 2.7V. So do I say it's real to ignore that I can have more runtime donw to 2.75V or 2.5V.
My Shadow TC6's driver is designed to cut at 5V. So yes, some 2.5V cells are be good for me, or others using this flashlight. I many times use it on low and medium so i need longer runtimes.
So from my point of view, I need tests done for 0.2A, 0.5A and 1A. That why I find 2100's test for the Panny useful. "quote"
I have quite a few chargers, the Trustfire TR-001, UF WF-188, a few cheapo chargers (from my lasers) and a hobby charger. All are ok, the lowest i have gone is 1.7V. (disclaimer - don't try that yourself! LOL! )
PS. Posted earlier in this thread, and also the Sky Ray 3800 thread, where i tested the runtimes of 2 x 2900mAh NCR18650 in a real world Sky Ray 3800. That one draws 2.6 amps and goes as far up as 4.2 amps, in reality. It has low-voltage cut for the driver so it's quite convenient to test.
Bro! I see your "6 amps DRY". Try not to gun it that far up with fully charged batteries... hehe, not even at Yakutsk. No use, spoils your cells faster, etc... Gross overdriving is more for HIDs and incans. HIDs LOVE heat. (provided you don't care about longevity, but no issue of coz for flashaholics short playtimes).
I have to admit, i "only" have a IMAX B6 so i am limited to 1A. Mainly that is for recharging my Pb because the stock ones take too long....i wasn't too keen on iChargers as they are over 70 bucks and i don't do RC. It's bad for regular Pb (non fancy AGM or what fancy types) of course to do above 0.3C but heck they are so cheap (15 bucks for a 7.2AH and yes it's a fresh one with ~ that capacity). From what i see on hobby sites, most entry level models have NiMH and Pb modes...so below 3V discharge is not an issue. Most flashlights do go below 3V per cell esp for 2 x 18650 lights and they don't dim much, if you don't believe my few tens of flashlights, check out HKJ, he probably has EVERYTHING in the market. LOL!
PS. I know there are some which do specifically Li only...but RC do make use if NiMH as well. If you ask Lambda, NiMH is not inferior to Li-ion.
There were a couple of good guys, i think DasFriek, who tests and includes graphs as they can log....wonder where are they. Some good guys like Agenthex has left too!
Unless electrical physics has changed since I went to college, I think you mean two batteries in parrallel the amps from each cell will drop to 1/2 of the amps the LED pulls. Your example is for a constant current draw which works out as follows:
Ex. : Control 1 battery - 3V (I chose a round voltage for simplicity, think CR123) @3 amp
2 Batteries in series - 6V @ 3 amps each cell
2 Batteries in parrallel - 3V @ 1.5 amps each cell (3 amp total)
Now, you are correct if the you have a constant power draw by the LED. A series battery installation will give twice the voltage which would only require 1/2 the amperage to provide the same amount of power.
I'll test to 2.5 volt if people want me to, 2100 has tested to 2.6 volt at 1 amp, so I dont see the need but I will do it but I'll do it at 3 amp.
Like I said I don't see the need to go past 3 volt as for my stuff I have all cuts out or dims around there and my multi cell lights go into low mode around 6 to 6.6 volt under load, so that's the reason why I stop at 3v.
Most batteries have a recommended 2.75 maxium discharge or low voltage cut around there the diffrence between 3 volt and 2.75 volt is very very slight with most cells.
The protection units with these sells from hank will not go past 3 volt any way so I don't see the big deal that's been made about me not testing them to 2.5 volt, as for the none protect versions they have been tested many times.
I've spent long enough on these cells just for you guys to bitch, but to keep you guys happy I spend some more time on them
Whats real about discharging at 0.2A, thats a all nigh test there, i dont have any lights that draw less then 1 amp, if you bothered to read post number 67 on this thread you will see i have already done the 0.5A test ! I can see 1 amp being useful, but any battery that gives the most mAh over 3 amp discharge will normaly give the most mAh and last longer for lower discharge test and you can work it out with simple math. Now if you wanted other test done why not ask........
I personaly dont find 2100's test of the panny useful as he is using a imax b6 charger with the maxium discharge of 1 amp with no data logging to back up his results, he has said in other post that the charger is out 0.2 volt to me when i question him and i know personaly the imax b6 and clones are not very good in nimh mode and the main charge leads are normaly out from 0.04 to 0.4 volts including the balance ports and 2100 has to use nimh mode to discharge lower then 3 volt. Im not have a dig at 2100 as hes a great bloke and great poster on this form im just stating it as i see it i dont mean no harm.
iChargers are good for lead acid batteries (PB) but only from 2 to 24 volt upto 10 amps or 250 watt for my icharger 106B+ if you run the iCharger from a PB battery you can do regeneration charges witch are very handy.
Where do you think my data charts come from ? i log using my icharger 106b+ connected to my computer for my battery tests i use logVeiw V2.7.4* with icharger 106B+ with the v3.14 firmware upgrade and then recalibrated the charger.
I use this program for my data log,s and for the data charts i post
I use the data tables instead of graphs becuse i find it simple and think it would be easy for other people to read and the data tables includes charge time updated every 2 seconds, voltage, watts, engery, mAh, plus induvidual cell voltage for upto 6 cells, internal temp of my charger, battery temperture, the chargers imput voltage from the power supply and so on and i can not get all that infomation on one graph.
I usualy only include the end of the charge cycle then hit the print screan button on the key board while the logVeiw program is running and opean on the screan of my computer, save the image in paint, then crop the image down with microsoft picture it! then up load the image to photobucket then post the image on the thread.
I cut out things like battery and charger tempture and induvidual cell voltage if im only doing one cell at a time to test.
Have I said anything about your 0.5A test? Have I said that you haven't done it? No
You don't have any lights that draw less than 1A. OK. Others have, including me.
I have already said that for my needs, 0.2A is useful, and for any person who uses low modes on a regular basis.
Look at HKJ tests and see that at 0.2A the capacity increases. At at 1A and 0.5A they end up with the same capacity. So doing the math is not something accurate in this case.
