Nice one - already (pre-)ordered.
Thank you for another great ReyLight,
Thanks for the nice reviews by DB Custom and Gunga.
The production has begun,you might pre-order here.
Price of the first 300 orders is ONLY 36$, from 301-800#, it is 39$, and 42$ after that. Don’t wait till the good offer is not available.
1.5*6mm tritium will be 6$/pc.
SPEC:
Material: Good quality brass
Emitter: Nichia 219C 4000K
Mode: Moon,Low,Mid,High (Start at moon with no memory)
Switch: Tail clicky
Weight:100g
1*AA/14500 battery
OP Reflector
Output:
0.2LM,5LM,30LM,110LM (AA)
0.3LM,12LM,200LM,390LM (14500)
Runtime:
30days,50h,4.5h,1h (AA)
20days,15h,2h,40min (14500)
The reviews showed a little difference, but nothing negative.
The proto clip was made by hand,it is not thick and strong enough, we’re making a molding to make better ones.
Estimeated leadtime is 30 days.
BangGood will do the packing and shipping.
2016-September-29
Click the following picture to go to my flickr album.
$36 is a steal on this little beauty! Well done!
This may be a dumb question but where do i order a trit?
It’s seen in the 1# post.
How do you affix the tritium vial on the torch?
Glue?
Preordered the torch and also ordered the vial from mixglo.
S1
Hi Rey, do you know, can the 4000K 90CRI 219C led that is in the Pineapple Brass be found somewhere for sale?
Hi Slayer. Recommended procedure is using norland optical epoxy. Mixglo.com sells it. Cure it under a 365nm uv lamp or direct sunshine.
Does the brass contain any lead?
Good tip. Now to decide if i want green or yellow.
Ordered one! Nice reviews, Dale and Gunga.
Anyone have those ice blue trits from Mixglo? Looks like a lighter color blue, and not what BangGood has - think'n BangGood has the darker blue. I only have the yellows and wondering how other colors compare. I see Mixglo has a nice table for brightness.
Mine is the ice blue but the iPhone auto white balance makes it look dark.
Ice blue is probably the brightest next to green. They’re pretty nice. I’ve been getting my trits from MixGlo for a while now, they are some very meticulous folks over there!
Thanks gunga !!
K, thanx (and Gunga). I'll probably be ordering from MixGlo then - definitely the ice blue, maybe couple greens. The bigger trits seem to be a better deal, but I don't have a place/use for them at this point.
I will sell it.
It is lead free.
Updated in #1 post.
I may of missed it somewhere Rey but are you engraving these?
