With my Canon G1X, Manual setting, 1/100th sec, varying f stops with each mode level, I get exactly ONE image. All modes.
Edit: For the smart alec’s out there, the one image has one single view of the flashlight, no ghosting, no secondary images. Flashlight waved back and forth while a 10 second timer counted down and snapped the shot.
And for the question about bumping output. The XHP-35 is a 12V emitter that is listed as having a max current of 2A. I have built one that is working at 3.13A but I know it’s got to be on the very edge of going POOF! Several other’s I know have had them fry at high 2.8-2.9A range.
Mine at 3.13A is making 2989 lumens, this TN42 is making 2463 lumens. So while there might be some small gains to be found, it would mostly be invisible to the naked eye. And since I don’t really relish messing up a proprietary driver on a new $200 light, I’m not playing around with it.
2463 lumens for 702.5Kcd and one mile throw suits me just FINE!
I don’t know what kind of flashlights y’all got that make those multi image exposures, but every light I try doesn’t show any of that. The little Thrunite Ti AAA, Convoy L6 XHP-70, MecArmy PT16, Solarforce S2200, Nitecore MH20GT, zanflare f1, SkyRayKing 9 emitter with Richards driver…. none show this multi-image effect at 1/100th of a second and waving the light side to side in front of the lens.
Hi Maiden666, great looking review with plenty of pics. Sorry I can’t read spanish.
I would say you review looks very profesional. Do you feel the TN42 has made much of a step forward over the K70?
Nice review and comparison, love the graphing charts.
It might be very important to note the K70 uses 4 series cells and as such, a Buck driver. The TN42 uses 2P2S and as such, a Boost driver. So the type of cell can probably matter more to the boost circuit than the Buck circuit, in other words, it would probably benefit the TN42 more to use better cells, the K70 wouldn’t show any marked increase for the top or premium cell.
This is me reasoning it out, I really don’t know 100%. What I do know is that my lightbox showed 2463 lumens from the TN42 using Samsung 30Q cells, and 702.5 Kcd throw on my lux meter. I have since proven that Kcd reading out by getting at-target photo’s of the light illuminating a target at one mile, so it’s not just numbers, it’s proven.
Also, for very fast PWM it might be hard to move the light fast enough to see the separate blinks. I just tried with a mtnelectronics FET driver light on low mode and saw a continuous streak.
For PWM over 10kHz it is probably very difficult to capture with a camera, but that’s when it usually doesn’t even bother anyone. I prefer moving the camera rather than the light.
I could set up my 1DsMkII on a tripod and darken the room and go to great lengths, use a shutter release, swing the light on a string from the ceiling, but I’m willing to concede that the little G1X got it right and there’s simply no visible PWM, even at 1/10th of a second shutter.
MakeCanon
ModelCanon PowerShot G1 X
Aperturef/4.5
Date & Time2016-09-30 10:26:27
Exposure Time1/10
Focal Length29.3 mm (35 mm equivalent: 104.5 mm)
ISO100
Dimensions2345 x 1565
Size0.8KB
I read thru the Maiden666 review on ForoLinternas as well. Comparing a CW to a NW is difficult - they will not match up well. I'm sure the bins of the XHP70 are different, lower for the NW. The TN32 product page here clearly says the NW is 10% lower, but that's probably just in lumens, - kcd is usually about double the loss of lumens, bringing the kcd spec down to 480 kcd.
So if Dale's TN32 is CW (think so), both Dale's and Maiden666 measured #'s are probably about dead-on matching.
Edit: So yes, if you add 10% to the NW output numbers it would come within about 60 lumens of my measurements. And I did use the premium Samsung 30Q cells, which might account for the rest of the difference. Providing we can assume the testing methods fall pretty close even if quite different by application. I find my P-Trap box to be very close to ANSI numbers of quality lights, this has proven out repeatedly over the past several years. So I trust it. FWIW, I had Chris at flashlightlens.com make me up an UCLp lens to put in my light box, after removing the silicone seal around the heavy plate glass that the brother’s R used when building it. It tested out virtually the same with the high grade UCLp lens. A testimony to the already well thought out build. I am back to using the glass plate for it’s durability. The big UCLp lens? Retrofitted to my 15,000 lumen TR-J20.
