Thrunite TN 42 ,a new record in Throw
472 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 9 hours 39 min ago
I did choose the CW for absolute power and throw. Smile
Edit: So yes, if you add 10% to the NW output numbers it would come within about 60 lumens of my measurements. And I did use the premium Samsung 30Q cells, which might account for the rest of the difference. Providing we can assume the testing methods fall pretty close even if quite different by application. I find my P-Trap box to be very close to ANSI numbers of quality lights, this has proven out repeatedly over the past several years. So I trust it. FWIW, I had Chris at flashlightlens.com make me up an UCLp lens to put in my light box, after removing the silicone seal around the heavy plate glass that the brother’s R used when building it. It tested out virtually the same with the high grade UCLp lens. A testimony to the already well thought out build. Wink I am back to using the glass plate for it’s durability. The big UCLp lens? Retrofitted to my 15,000 lumen TR-J20. Smile
EasyB
Last seen: 6 hours 31 min ago
I agree the numbers make sense: the NW TN42 has about 80-84% of the lumen output and Kcd of the CW version.
Tom E wrote:
The TN32 product page here clearly says the NW is 10% lower, but that’s probably just in lumens, – kcd is usually about double the loss of lumens, bringing the kcd spec down to 480 kcd.
But I’m not sure I understand this. If the reflector and LED type are the same, the beam intensity should scale directly with the lumen output.
DB Custom
DB Custom's picture
Pushing light downrange is an exponential factor, it takes 4 times the amount of light to reach twice as far. This is something photographer’s deal with all the time. Wink
bibihang
bibihang's picture
Last seen: 1 day 20 hours ago
DB Custom wrote:
100mm head, it’s big! Like, virtually the same size as a BTU Shocker…
That’s really a big head for a single emitter light like this!
So no surprise that it throws better than the K70 although with lower lumens output.
EasyB
Yes, but I wasn’t talking about the distance. I meant that if you dim a light to half its lumen output, its beam intensity (in cd) will also be half.
Stereodude
Last seen: 6 hours 24 min ago
DB Custom wrote:
It might be very important to note the K70 uses 4 series cells and as such, a Buck driver. The TN42 uses 2P2S and as such, a Boost driver. So the type of cell can probably matter more to the boost circuit than the Buck circuit, in other words, it would probably benefit the TN42 more to use better cells, the K70 wouldn’t show any marked increase for the top or premium cell.
Boost or Buck is irrelevant if the output is constant current and the drive circuity is competently designed. As long as the inductor is sized to switch enough current without going into saturation after the battery voltage sags, you’re pretty much set.
IMO, none of these lights should use cells in series if they need unprotected cells. Unprotected cells and series use is a dangerous recipe without a proper battery monitoring system. Of course all of these lights all lack such a system.
Tom E
Tom E's picture
Last seen: 14 hours 18 min ago
EasyB wrote:
DB Custom wrote:
Pushing light downrange is an exponential factor, it takes 4 times the amount of light to reach twice as far. This is something photographer's deal with all the time. ;)
Yes, but I wasn't talking about the distance. I meant that if you dim a light to half its lumen output, its beam intensity (in cd) will also be half.
I dunno, I just see it empirically (measured) more often than not. Are you sure that's what you measured in lumens vs kcd for a thrower?
Actually it's probably wayyy more complicated than what I said. All sorts of variables - our meters (cheap ones, like under $1000) I believe are calibrated better with CW tints than NW tints, so they tend to read NW's lower and probably in the high range of CW read higher on the meters. There's other factors. Just checked some of my numbers, and sometimes yes, kcd scales well with lumens, but other times I've gotten higher differences on kcd than lumens, percent wise, and I thought as much as 2X.
This is all part of the issues comparing two lights with different tints. Specs from the manufacturers that offer multiple tints are typically not providing the data points per tint, some do, most don't. Chances are they'll quote CW because of the better results.
DB Custom
DB Custom's picture
I can see that stereodude, which would make the Thrunite safer than the Acebeam on the sheer fact that it’s 2 cells in series instead of 4. You can put 2 cells in the carrier and run it, or use a second pair in series for extended run time. Can’t do that with the Acebeam.
I should try other cells and see if I get a noticeable or measureable difference in output, that should tell something about the circuitry, yes?
DB Custom
DB Custom's picture
I can measure a lower mode and extrapolate, but if you have half the lumens then no, you wouldn’t have half the candela. It’s that exponential issue again.
I’ll measure and see what shakes loose.
But, in photography terms… I’m standing on the sidelines at a football game, the punter is directly in front of me in the middle of the field… he’s 25 yards away. Easy flash shot. He punts 50 yds downfield to the sideline I’m standing on, I want to capture the opponent catching the punt, he’s exactly 50 yds from my position. Twice as far away. It’s going to take 4 times the amount of light to reach him for that shot. 4 times at twice the distance.
Candela is a measure of intensity in the center of the beam, so if you cut output in half…. I’ll measure it.
DB Custom
DB Custom's picture
Ok, today for sure this is not my cup of tea. So I’m gonna just tell you guys a few test results and I’m sure some one of you can figure the percentages easily enough…
The TN42, on level 3 of 4 (High) makes 1003.95 lumens and 46750 Candela
The TN42, on level 4 of 4 (Turbo) makes 2459.85 lumens and 702500 Candela
So what does this tell us?
(I have to say here, I’ve tested the candela on this light at least 4 separate times, with the cells at different charge levels two of those times and fresh or almost fresh the other two… every stinking time the meter tells me 2810 with a x100 setting. 28100 at 5M, for 702.5Kcd. Reliable, the most reliable I’ve seen to date)
maukka
maukka's picture
Last seen: 13 hours 52 min ago
Everything else being constant doubling the lumens doubles the lux/candela.
DB Custom
DB Custom's picture
Maukka, did you see my test results directly above your post? That doubling concept is obviously not true. I’m pretty sure that double 46.75 isn’t anywhere close to 702.5, even with the differential there.
EasyB
Dale, I can’t explain your result, but in Maiden666’s review the measured Kcd scales very well with measured lumens and this is generally what I have observed with my lights.
Stereodude
Testing the light’s output with cells at various states of charge would give you how good the circuitry is. Like fully charged, 75%, 50%, 25%. If they’re all the same the circuitry is very good at running constant current through the LED even as the cell voltage drops and the current draw from the batteries increases.
maukka
maukka's picture
Think of it this way:
If the intensity of the hotspot doubles when changing modes, the intensity in every part of the beam has to double too since the reflector and emitter are the same. Thus the total output doubles = the lumens double.
DB Custom
DB Custom's picture
Led-Rise’s calculator is misleading. You cannot directly convert lumens to lux. Lumens is a measure of total output, lux is the measure of intensity in the center of the hot spot. A floody 1500 lumen light creates very little lux, whereas a pencil beam thrower making 1500 lumens puts virtually all it’s lumens down the middle, into the hot spot, for far greater Lux.
A simple converter just can’t show that.
DB Custom
DB Custom's picture
Theory versus provenance. The numbers I just got from my meter are truth, without conjecture.
42% of the lumens is making less than 7% of the candela. That’s a simple fact. All the theories in the world can’t disprove it.
DB Custom
DB Custom's picture
Candela, downrange illuminance, isn’t all about the emitter and driver and reflector. It’s about the avaialable light spreading out in a cone as it travels downrange, very quickly losing it’s power.
Science is wonderful when in the lab or sitting at the desk, going out in the field and proving the science is an entirely different matter.
Y’all might be the scientists, I’m the guy out in the field taking pictures of real world results. And the results don’t agree with the science.
DB Custom
DB Custom's picture
Build a light, measure it’s lumens and candela. Then de-dome it. Measure lumens and lux again. You’d find that that the lumens dropped while the candela nearly doubled. Less lumens, more candela. Fact. There are more variables at play here than it would seem.
I’ve done this literally hundreds of times.
maukka
maukka's picture
Modifying the emitter is not keeping everything else constant.
DB Custom
DB Custom's picture
But, taking a lumens reading immediately after taking a lux reading on the same light, same cells, IS maintaining constants. And those number disagree with the representation of physics here.
I can’t argue with physics, unless the chapter and verse being quoted are wrong. Wink
By the way, who said we couldn’t send a man to the moon? And who is now planning to send men to Mars? Physics and it’s laws change as we learn, there are very few hard cold facts.
I’m not trying to convince anyone of anything. I’m the guy with the light in hand, the results from testing in front of me. It’s everyone else that’s scrambling trying to figure it all out. Fact is, at 42% of the output, the light is making less than 7% of the throw.
That does not support the theory that halving lumens also halves candela. So when the facts from testing don’t support the theory, it’s time to put new chalk on the board.
EasyB
Could you humor us and take the measurement again? On turbo there was 28100 lux at 5m. How many lux on high?
DB Custom
DB Custom's picture
The meter read 1830 on High, 28100 on Turbo. My meter has 3 places, it actually showed 183 to the power of 10 in High, errored in Turbo and I had to switch to the power of 100, where it showed 281.
I argue to understand, not necessarily to prove anyone wrong. I forget a lot. Widely known fact. So if I can argue myself to an understandable truth it is well worth all the verbage expended in the acquirement. Wink
Yes, it is entirely possible that I made a mistake taking the readings, so I will do it again. (I have been known to make the same mistake over and over, so bear with me. Silly ) I will go slower, double checking mode levels along the way, for extra care and authenticity.
mdeni
mdeni's picture
Last seen: 1 day 22 hours ago
Measure everything to the power of 100. You will find your mistake. Don’t change settings between readings.
DB Custom
DB Custom's picture
So there ya go, y’all are pretty much spot on. Within a couple percent. lol
I forget little things, like all of how the UI works. I forgot that when you press and hold from off the TN42 comes on in moon, then will cycle through 3 more levels LMH. BUT if you cycle it through again, there are only the 3 levels LMH, moon is only accessible from off. So I must have cycled it back through checking that I had the right mode after setting up the meter and was actually in Medium instead of High.
The numbers, carefully obtained…
High (Level 3 in the main UI) is making 1003.95 lumens (I got that correct in the light box) and 272Kcd for 1043.07M throw
Turbo (Double click in any mode when on) is making 2477.1 lumens and 702.5Kcd for 1676.31M throw.
Thank ya’ll for pushing me into finding where I went wrong. 41% of the lumens is making 39% of the lux, so it’s fairly linear if not quite exactly. The actual throw numbers are not linear, the candela reading pretty much is.
DB Custom
DB Custom's picture
Now I’m confused in the other direction. lol
Why is it that by the numbers, with the lumens at 41% and the lux at 39%, the throw is actually at 62%?
I’m gonna have to give up. When the time comes that you know you don’t know half of what you think you know but you really only know a quarter of what you thought you knew you know then it’s time to have a drink. Silly Seriously though, you hear about the football players that retire dang near a vegetable after so many concussions in their career? Or a boxer? Well, I’ve had more concussions and micro concussions in the past 16 years than a great many professional athlete and it’s catching up to me. Gonna be drooling and staring off into space before long, I can see it coming. (I’ll have a light to shine the way though, in case anything’s really out there.)
Thanks for bearing with me.
EasyB
Thanks for clearing that up that measurement, Dale.
You know, I find that I don’t really understand a concept until I’ve been utterly confused about it a few different times; it’s all part of the process.
DB Custom
DB Custom's picture
(listening to some tunes on new dual driver headphones from XiaoMi, GearBest. $17, these things sounds like Bose or something!)
Well, almost 17 years ago I started having issues with severe spasms, eventually diagnosed as a Conversion Disorder. Stress, both physical and emotional, causes me to have spasms that might just affect my arms, or my whole body, sometimes causing my head to shake side to side violently. It’s these last episodes that crash me, sometimes leaving me walking crooked for several days. Early years, it was daily or every other day. Nowaday’s it’s more sporadic but damage has been done and each time causes more. I once had a pec muscle torn for 2 years! And once I went to shake a bottle of ketchup at the table and it caused a partial vision loss for several minutes in my left eye.
I mod for relaxation, got into it because I needed a portable light to use to take macro ring shots at weddings. Couldn’t find a light that fit the bill and started trying to create one. Found that I liked the modding part of it and before you know it I’ve got more flashlights than most stores. lol
Gettting harder to wrap my mind around things, to remember details, names, virtually anything really. Sometimes what I DO remember may be way off base, leaving me arguing a false point but convicted in the knowledge I’m right. Hard to believe, I know, but it’s true. Silly And then I see that little detail I was missing, and the rest comes together and shows me I was on the wrong page. Whatareyagonnado? And such is life in the basement of Dr. Frankendale, discombobulated and non-incorporated.
blueb8llz
Last seen: 14 hours 41 min ago
Sounds intense Dale. Take it easy when you can and thanks for all you do here.
DB Custom
DB Custom's picture
Take it easy, says he. I was about 140 lbs all my life, I now weigh in at almost 210. Been taking it pretty dang easy and eating plenty! Smile
