Thanks for clearing that up that measurement, Dale.
You know, I find that I don’t really understand a concept until I’ve been utterly confused about it a few different times; it’s all part of the process.
(listening to some tunes on new dual driver headphones from XiaoMi, GearBest. $17, these things sounds like Bose or something!)
Well, almost 17 years ago I started having issues with severe spasms, eventually diagnosed as a Conversion Disorder. Stress, both physical and emotional, causes me to have spasms that might just affect my arms, or my whole body, sometimes causing my head to shake side to side violently. It’s these last episodes that crash me, sometimes leaving me walking crooked for several days. Early years, it was daily or every other day. Nowaday’s it’s more sporadic but damage has been done and each time causes more. I once had a pec muscle torn for 2 years! And once I went to shake a bottle of ketchup at the table and it caused a partial vision loss for several minutes in my left eye.
I mod for relaxation, got into it because I needed a portable light to use to take macro ring shots at weddings. Couldn’t find a light that fit the bill and started trying to create one. Found that I liked the modding part of it and before you know it I’ve got more flashlights than most stores. lol
Gettting harder to wrap my mind around things, to remember details, names, virtually anything really. Sometimes what I DO remember may be way off base, leaving me arguing a false point but convicted in the knowledge I’m right. Hard to believe, I know, but it’s true. And then I see that little detail I was missing, and the rest comes together and shows me I was on the wrong page. Whatareyagonnado? And such is life in the basement of Dr. Frankendale, discombobulated and non-incorporated.
A boost driver can be very well-designed and the efficiency can be optimized, but due to the nature of the circuitry the efficiency of a boost driver can never beat the efficiency of a buck driver, given everything else being constant except that for a buck driver has Vin > Vout.
Although running 4 batteries in series isn’t something that sound very safe, but it can sustain at the maximum output much longer and better than the TN42 (and let’s not talking about any programmed step-down feature). Correct me if I am wrong.
P.S. I am always a fans of buck driver with Vin > Vout, because instead of having a 400kcd output that can only sustain for 5 mins then quickly decrease over the time, I’d rather have that 400kcd light which can constantly sustain at this output until the batteries are almost depleted.
I think the LedRise calculator is fine, because it takes the “Viewangle” into account, which determines how floody or focused your beam is.
Thanks for the clarification and all the hard works and measurements that put into this Dale. Your works and other’s theoretical input have linked theory and field results together pretty well, and that’s feeling good.
I wish someone out there would mod this with a dedomed xpl,xpg2, or xml2.
A year ago, we would be so stoked to have a reflecter of this caliber with a xml2 or xplHI.
And we would either dedome it or drop in a dedomed xpg2.
These were the known emitters for massive throw.
I feel the xhp35hi is geared for lots of throw with great lumens.
A super amped up xpl or xml2 wouldn’t be that much less lumens, but I suppose the lux would be a lot more don’t you guys think?
My vote would be dedomed xpl . Better throw and only a small (400?) lumen loss.
Because it has better throw than xpl hi . Ofcourse xp-g2 would throw better , but it will have around 1k lumens only .
Spotlights have this kind of reflectors all the time. But are regarded as dumb. But TN put a slightly bigger reflector and all run like hell. And charge 200$. Next year they will bring 10mm larger reflector and same story. Meanwhile years before spotlights are offering the same for 30$, but in a plastic body. I dont think the body costs 170$ pardon me.
I charged up my “20 Million Candlepower” 12 inch wide spotlight that uses an automotive headlight bulb. Was going to take it with me for comparison beamshots on the mile long throw shots. Got it charged up, took it outside, it’s so pathetic I left it at home. I even have a high grade upgrade bulb in it. The Thrunite TN42 slaughters it.
The big spotlight was like $40, all plastic, bare bones with no heat sinking. Big 12V sealed acid battery. It’s not designed with any sort of quality in mind, just stick a car headlight in a plastic housing and give it a base that allows it to be propped up at an angle, gearheads’ll buy it at the Auto shop because they work on their cars at night and/or go fishing.
The cost, yeah, I have to agree I think the cost is high. AceBeam, Thrunite, Nitecore, Fenix, they all have the same type pricing. I don’t like it myself, have few of their lights. This one though, this one was introductory with a 20% discount and promised that mile… I couldn’t help it. The only mile long thrower I ever built was based on an Olight SR-90 Intimidator, a $400 light before I even started modding. At $179, it seemed like such a deal… and compared to what’s out there on the market, it is!
One thing I found was tripping me up on the ideas of distance and light is that in photography we are trying to maintain brightness for the proper exposure. With flashlights we are allowing brightness to fall to a 1/4 lux. Massive difference and one I was not taking into consideration. In photography, we’re also trying to maintain a shutter speed that allows for some movement, so the light has to be considerably brighter to provide the shot.
Incadescent or HID does not matter, lumen output does. I don’t think you have seen what 100W incadescent philips in a 20cm reflector can do. Don’t even venture into HID land, where 200W HIDs live for 100$+battery. Those millions of candles are EASILY attainable. And the “top” led thrower has 700k and people are talking like god is walking among us.
The point is, they want to milk money. All they do is put few mm bigger reflector and claim the “top” performer. Look at the Courui01 mods with 82mm reflector. Think of what an xpg3 sliced 150mm wide and 150mm deep reflector can do to this poor TN.
Not as much as all that, I haven’t seen a sliced G3 do so well.
What it boils down to though is the bird in the hand thing. I HAVE this mile thrower TN42. I don’t have anything nor have I in 3 years seen anything that will best it.
Edit: I’ll also add that while HID’s are capable of impressive results, the only ones I’ve seen had horrible tint and took forever to warm up to peak output. Not practical, they have a place for sure but it’s not something an average user would put up with.
Interesting, isn’t it? How can Simon sell the wonderfully made L6 for such a low price while other manufacturers sell at 3 times the price and don’t really do much of anything all that much better? Ok, so they have a fancier proprietary driver, but it that alone worth well over $100? I wouldn’t think so! Having been working at learning the machining on my own lathe, turning the aluminum and anodizing it is a pretty basic part of the equation, for the most part the better lights are all the same in that regard and one shouldn’t cost more than the other. Same thing with the AR glass, Chris has the ultimate AR coatings at flashlightlens.com and his lenses aren’t ridiculously priced, so again the market should be fairly equal. With a decent reflector common to most all of em, it really boils down to the driver, and I’m building my own drivers for a while now with the most complex of them not being over $20 or so to produce, this a big custom designed driver for high output at that. So, is it the warranty? The overhead of a bigger fancier face online? Or just more greed?
I know some people will buy a like/same product for more money because they’re trained to perceive the costlier product as having a higher quality by default. Perhaps that’s the target audience for some of the big names, just mark it up to appeal to those with fatter wallets and run with it. Could be that’s all there is to it.
We could have Richard and ToyKeeper design a driver for Simon, he could build a 120mm boss hog light, and he’d probably sell it for $100 or something, now wouldn’t that go over well? Reckon he could build a de-domed XP-G2 1Mcd thrower with that kind of help? Maybe we should get JDub to push in that direction, see where it goes…
Well, Richard already makes a Buck driver that will run the XP-G2 at 5.5A, I have one in an L6 making 439Kcd. So if it just takes a bigger head/reflector set-up, I can see upgrading the L6 to an L10 and using 32650’s for run time. The TrustFire 32650 is awesome, and at 6000mAh it’s the highest performing highest capacity cell I know of. I’m using 6 of em in 2 TR-J20’s, they’re unbeatable by any other cell I’ve got (I’ve got a lot of options).
Perspective wise, a 3*32650 Buck driver light with a 120mm head should be flippin awesome! Then again, Thrunite could build it too as far as that goes, maybe they’re already working for something along those lines…
I don’t think i’m the only one that wants a 400kcd + affordable flashlight . It could be a 700kcd light ….
Maybe Simon is the key as you said Dale . A light with xhp35 , 4S battery holder and the appropriate driver ? I don’t think a cheaper TN42 isn’t possible . But only some people here can make it really happen .
