4 channel Light saber driver design, may the light be with you.
Yeah, he uses a different MCU.
He uses the atiny85.
Sorry, I got my RGBW’s crossed… I was thinking of tterev3 for some reason, even though you said DR Jones. :person_facepalming:
Edit: The Dr Jones RGBW driver uses software PWM.
Ok. I wasn’t aware of the difference. Is software pwm an option for us?
Yes, if somebody writes the code. That would be TK in this case. :wink:
Ahh… So, TK…? :wink:
Or, maybe you could talk DR Jones into tweaking his firmware for this new board. He may do that for a decent price. But, an open source solution would allow us to carry it forward and make changes and tweaks to our liking and to fit future boards, etc.
I’ve been trying to get ahold of him but he hasn’t been around the forum for a while and I don’t have any other contact info for him. I would be willing to pay for a completed rgbw firmware that I could use on self built drivers. Idk if he would’ve good with that though?
His driver firmwares are proprietary code. But, he used to sell pre-flashed MCUs. I would think he’d be willing to make a tweaked version for a new board if there was enough demand. How different is your board from his self-designed RGBW driver? If it’s basically the same, or not much different, his code may already work for you. It would be nice if you could get in touch with him. But, like I said above, it would be even better if someone came up with an open source RGBW firmware that was as nice as DR Jones or tterev3 code.
Here’s the DR Jones firmware website.
Ya. For me, his existing firmware is great! If I had the choice I would change the mode to clicks configuration, but if I could get an MCU from him as, I would be thrilled. I have one of his drivers left and I plan on removing the programmed MCU to place on my own driver layout. I’m working on a multilayered driver to power 4 XML rgbw led’s as well as one xpg3 high cri led. It will control three banks of 7135s and one fet channel for the white. I’m going to parallel the xpg3 along with the four white dies. When testing, I can get 4amps to the xpg3 and 1amp to each white die when in parallel.
At first, I was planning on using an escutcheon modified BLF d80, but room was very very tight. I found a way to pack it in with a custom driver design, but I finally surrendered to the pk26 as a host. After receiving the pk26, I’m still not certain it will work out. Even if it never works out, it’s been fun thinking about a 40w rgbw pocketable flashlight. (40w for about 40sec that is :slight_smile: )
TK, if you want his driver board minus the MCU for testing, let me know.
(Edit: that is, dr jones driver board I am referring to.)
I found this instructable for software PWM. I’m not near versed enough to know what this entails, but the instructable gives a little hope for another good four individually addressable PWM controlled driver.
Wow! Thanks LightRider!
I would love to see some action here. TK? …Have you got anything to report? …TK? …Anybody?
I got kind of ninja’d by other parts of life for a few months.
Also, um, I don’t actually have any driver boards to print and build. Texas_Ace, do you have these up on oshpark? I didn’t see the saber driver listed there.
I never heard back from you on weather it was ok and what you wanted so I didn’t bother uploading it in case it needed changes. lol
If you think it will work for you I can upload it.
I think it’ll probably work. If you’re willing though, it’d also be nice to have one with a pin and pad for an e-switch instead of the voltage divider. I think I can probably use the inverted VCC method for measuring voltage, and an e-switch likely makes the interface easier to navigate.
Or I could maybe use the 4th PWM pin for an e-switch, and use only three colors. I’m not sure how much value there is in adding a 4th color channel, and it should be fairly easy to stick the switch wire into one of the vias on pin 2 or 3.
Is there no use for adding a little bit of white to the mix? You can get some bright tinted colors this way. But I must say, I have no idea how a saber is yo be used:)
The idea was that you could use the R1/R2 pads to setup the e-switch if you didn’t need the voltage divider. I went ahead and added a dedicated set of pads for the switch though.
Here is the oshpark link: OSH Park ~
Software PWM can work very well as long as you have a timer available (that is not used for anything else) and don't frequently need to suspend interrupts (such as to write to NVM) which will glitch the PWM output. It's fairly easy to implement - here's pseudocode that you would put in an 8-bit timer's overflow interrupt routine. The only overhead you'll need is a variable for the output (duty cycle) you want and a flag bit that toggles to keep track of the phase of the output.
if timer overflowed to zero (interrupt):
toggle the flag
if the flag is set:
turn on the output pin
load the timer with a value of (255 - duty cycle)
else if the flag is clear:
turn off the output pin
load the timer with the value of duty cycle
The way this works is by scheduling the following interrupt to occur in a variable amount of time. By loading the timer with a low value, it will take longer before overflowing past 255 again and the subsequent interrupt will scheduled further out, and vice versa for a high value. So as an example, say the timer runs at 1MHz and the duty cycle is set to 200 (of 255). The interrupt will fire and turn on the output, then load 55 into the timer. The timer then has to count up 200 cycles before firing the interrupt again, when the output is turned off. Then 200 is loaded into the timer, so it only has to count up 55 cycles before firing again and starting the process over. This gives a high output for 200us and a low output for 55us, so we get a ~4kHz PWM signal at ~78% duty.
This can be extended slightly to give better performance at the extremes (0 and 100%) by adding a test for 0 and 100% duty before setting the output:
toggle the flag
if the flag is set:
if duty cycle is not zero, turn on the output pin
if duty cycle is not 255, turn off the output pin
My AVR skills are rusty but I think a simple implementation would look like this, assuming you set up timer0 as an 8-bit timer with an overflow interrupt:
bool flag;
uint duty;
ISR(TIM0_OVF_vect)
flag=~flag;
if(flag){
output_pin=1;
TCNT0=(255-duty);
else{
output_pin=0;
TCNT0=duty;
