I’m just running out of ways to name all these versions. I already have Rev5.3 Bottom. What would I call this, Rev5.3 Bottompot? Do I jump to Rev5.4? It doesn’t seem like a evolutionary change, just a step to the side.
I’m trying to keep the names as easy as possible, but I know it isn’t exactly working.
Yeah, I was thinking the same thing. The names are very confusing for sure but I could not think of a better way so I kept my mouth shut. Same issue I am running into with the TA drivers.
I am trying to label each driver with a name that describes what it exists for instead of just more numbers, for example the LDO series are the same as the normal version names except with LDO added. Thus they have an LDO. It is still getting a little confusing though.
I think the best option is a clear explanation system for the different boards. Either on OSHpark or the OP.
Something that details exactly why each board was created and what it does that others do not. Also examples of what lights it fits and what dimensions are important to see if it will fit.
Thats a lot of work though.
If the 5.3 is more of less universal for the smaller tailcaps then you might consider standardizing things a bit and moving most of them to another post/end of the OP and focusing instead on just a handful of boards that cover the vast majority of mods. The more universal the parts the better for first timers, once they have done a few they will see whats important and whats not.
Yeah, but they all really have their own merits. I like 2 channels so 5.3 works for me, but a lot of people still like the 3 channel version, so I can’t really get rid of it. The ones that I felt were really redundant or unnecessary I just removed from the OP (like the first Rev5 top and Rev5.1x). I thought about getting rid of all of the original versions that don’t use the ring and only have 2 LEDs, but someone just ordered that version to use a couple weeks ago.
I tried to standardize the descriptions in the OP as much as possible. Does it still need work?
It is always hard to make things understandable to an outsider once you have become an insider. I run into this all the time.
Even now I forget with the TA drivers to make things simpler and am always having to edit things to add more details for the new comers that don’t have a clue what we are talking about. For example it took me weeks to understand what the “standard parts list” was that was always mentioned.
The op is much better then it was for sure. the only thing really missing are notes on what has not changed between versions. The reader will generally assume that more then just minor details will have changed between versions.
I usually assume the number before the dot is for major revisions and the number after the dot is for minor revisions. With some projects, they add another dot to the mix, as another subset. So, it would be MAJOR.IMPORTANT.MINOR or something like that. With options, like adding an LDO, you could do MAJOR.MINOR.OPT like 5.3.LDO and 5.3.STAR and 5.3.ESWITCH or something similar. I’ve become so accustomed to organizing my computer into sub-sub-sub-folders, this stuff is second-nature to me. Yes, I’m a NERD! :nerd_face:
Here she is. A bottom switch PCB with a single pot in the middle of the spring. Very similar to Pyro’s board, just updated to work with the header pins and ring top boards. Also added to OP
I’m currently using 4K7 resistor and still too bright. But I’ll stick into it before I receive transparent rubber cap from KD and get transparent washer.
With the ring top boards the resistors on this boards are optional, that means I can use 0 Ohm resistors, if I use this pot PCB, isnt it?
The Pot and the resistors on the top ring board are series, arent they?
I just ordered some myself. Normally I like to have the “presets” of the switch, but it’s more parts and more soldering. I just had a light this week that I wished I had one of these boards for.
Anyways, I’m almost out of springs. Many times I steal the spring from the stock switch pcb, but I can’t always do that. What springs do you guys use?
Yes. I have some that have dented the caps on my flat top batteries.
I have a few springs that even pushing until it’s painful they won’t compress more than 1 or 2 mm. I want them just strong enough to keep the cell from bashing around. Also I need to be able to push them to the side to access the switch or pot in the middle.
