HaikeLite EDC sample will come out at the end of this month too if no any delay. It’s a very special EDC light with LCD screen. I can’t public more info at the moment.
I’m liking the look of this. This light and the triple light look very promising, may not be very good on my wallet. You guys look like you have the making of a great company.
Me too. Nice thick aluminium with a lot of cooling fins. Comparing the weight to other triple XHP70 lights like the Olight X7 and TN36-UT makes me happy too
From the looks of the deep reflector, it’s sort of a TM03 enlarged, without the proprietary wedged mode ramp on the tail cap. And with more cells. And more output. And more options. And more thermal mass. And uh, pretty much the same price if you get a deal on the Tiny Monster.
All around a tad smaller than the K60, but heavier. _the_ has a review of the K60 posted here with some nice beamshots, comparing a classic thrower like the TN32: https://budgetlightforum.com/t/-/34430 . I'd expect this light's beamshot to be similar to the the K60 because of same emitter, close to same reflector size. The K60's reflector is probably a little wider, and slightly shorter, so the flood width should be a little greater with the K60.
Think'n the HaikeLite will have a little more lumens, so the throw will be in the same range as the K60, might be better. _the_ measured 158 kcd, so I'd expect in that neighborhood. This is all pure speculation if the reflectors are comparable quality and LED's are effectively the same.
The HaikeLite reflector is 72mm I.D. while _the_ measured 82 mm for the O.D., so dunno for sure how they compare. The I.D. is what matters the most.
