With coupon it has same price of hc30, but as a flood is better the H03.
Any news about coupon?
The coupon has been extended, now you can use the same coupon. I will appreciate if you can use this affiliate link although it’s not mandatory
http://www.gearbest.com/led-flashlights/pp_391921.html?lkid=10115648
If you don’t like affiliate stuff, simply use this link.
Thanks!
The coupon code is not working on the H03F (filter) model , but does work on the H03 (TIR) model. Any chance of getting the code for the H03F?
Also doesn't work on the H03R...
thank you lumenzilla, i bought it right now, and i cancelled order in banggood to the same flashlight because it isn’t into the stock yet and when i bought it for BG there was show “in stock”
Also doesn’t work on the H03R…
I’m asking it right now, I hope I can get prompt reply from them.
Well, these few days are Chinese national holiday.
Hi,
Can anyone tell me how the crelant ch10 compares to the other headlights mentioned here?
It seems to be quite a lot less lumens, but is quite a bit cheaper too, and am just wondering if it’s worth it to spend so much more money on the Skilhunt, thanks.
Nice little light. Those beamshots sold me. $33 and change after the coupon for NW TIR version. Thanks!
Hi, Can anyone tell me how the crelant ch10 compares to the other headlights mentioned here? It seems to be quite a lot less lumens, but is quite a bit cheaper too, and am just wondering if it’s worth it to spend so much more money on the Skilhunt, thanks.
The CH10 is a dedicated headlamp - look at the form factor, while the H03 doubled as a headlamp and EDC. I EDC my H15, but planning on upgrading the H15 to the H03. The H03 is only 5 mm longer but uses an 18650 instead of a 14500, no big difference in runtimes.
The CH10 is an OP reflector light, while the H03 model is a TIR lens light with a gorgeous smooth beam pattern - very different, all depends on your usage and preference.
A hot spot lights vs. flood - your choice, plus only headlamp vs. headlamp/EDC combo - these are the main features making these two different from each other.
For me, I used an older Crelant headlamp w/OP and it did not serve my purpose well - close up work on a bench, while the TIR optic flooder headlamp is much better suited.
@ Lumenzilla: I just ordered a NW H03 using your coupon code. Sweet price reduction, thanks!
You’re welcome. I’m happy if the coupon is useful.
Oh boy, I found it for 29.99 USD with coupon code: LSFDMR
Link to the shop
I hope it will be useful!
Thanks!
I’ll put link of your post into post #1.
made a runtime test with 18650B 3400mAh protected cells
All promo coupon is expired, I’ll ask the new one.
thank you! will be subscribing to your thread for the promo code…
Coupon updated on post #1
HI again,
Will the code work for the h03F?
Thanks
Thanks! :+1:
HI again,
Thanks
Unfortunately not.
I will ask them the coupon for H03F.
All of the codes seem to be expired. Any chance we could get a new one?
Try this code, I just checked and it works.
Link: http://www.gearbest.com/led-flashlights/pp_391921.html?lkid=10115648
Code: HURE
