So you need test done with 0.2 and 1 amp done. HJK is planing on doing discharges at 0.2A, 0.5A, 1A, 2A, 3A and 5A i could do 0.2 and 1 amp if you like if you dont want to wait ? i can even use the same graphs. I was thinking of doing a 6.2 amp test the maxium panisonic recomend for these cells.
The Math works out pritty close if aprox is good enough like 200 mAh, even the graphs show its with in 150 mAh thats bugger all, so the math is close for no more then 1 amp i know the math does not work well for 1 + amp discharges.
As for battery cut off when dishcarging since most batteries ive come across are 2.75 volt most batteries ive seen people buy and use of this forum are cheapies with the cut off around 2.75 volt, the diffrence between 3 volt and 2.75 volt is basicly seconds in real life usage in a torch on high with a cheap battery like the most commonly used on this site.
For people who do not understand mAh it stands for milliamp hour this means a 3100 mAh battery should be able to supply 3100 milliamps (3.1 amps) for an hour.
Another test of these cells that have been cycled 8 times now last night i fully charged them last night and today i discharged at 3.1 amps from 4.18 volt to 2.5 volt, discharged with an icharger 106B+ in lilo mode for lion batteries
Cell A discharged at 3.1 amps from 4.18 volt to 2.5
Cell B discharged at 3.1 amps from 4.18 volt to 2.5
The cells come off the charger with a resting voltage of 3.24 and 3.23v.
NCR18650A 3100 mAh battery discharged at 3 amp to 3 volt 2485 (averaged out over the two cells)
NCR18650A 3100 mAh battery discharged at 3.1 amp to 2.5 volt 2876 (averaged out over the two cells)
So they gained an extra 391 mAh aprox even with the extra 0.1 amp.
Sure i can do that they should hit 3100 mAh easy maybe a bit more, would you like a voltage VS mAh graphs as well ? i still would like to include the data tabes i normaly use also, i would really like to do 6.2 amp discharge.
It might be a couple of days off as im doing some discharges on some redilast,s 2600 blacks and playing with some graphs
[quote=2100]
Yeah Benckie, you could do a 0.5A. Then i also do mine, and then i can see how accurate is my IMAX B6.
[/quote]
Thats a good idea.
Try lilo mode, i can use lilo mode to discharge below 3 volt but not to charge to 4.2v, im waiting on a firmware update for the icharger for this
Hank, will you be taking this up with your supplier?
I have three of these on order (along with three protected Sanyo UR16650ZTs), and while I have lower draw lights, so it's not like I can't use these cells at all, I had been hoping to use them with higher ampage lights as well.
I don't blame yourself, as you can only go by what your supplier is telling you - after all, you can't pull apart every battery to check that it has been made to the desired specification - but it would be nice to get this resolved for future batches, if nothing else.
Benckie got 2940mAh down to 3V at 0.5A from the Intl-O protected NCR18650A. But it seems higher amps discharges are blocked by the obvious reasons.
old4570 got 2700mah from the Callie Kustoms at the same termination voltage and same discharging current, 3V and 0.5A. Also, old4570 got 2919mAh when discharged at 0.5A down to 2.5V
This might be related to how much they are charged. I did this test once:
Notice how small a change you need in the voltage to get a 5% change in capacity, also notice the drop in voltage when the battery is resting. You need a good voltmeter to be sure about the termination voltage and be strict with the resting time!
My test of Callies 3100 batteries gives 2885 mAh down to 3 volt and 2953 mAh down to 2.8 volt with 0.5 A discharge current.
Different battery batches (whether it is 2 years ago or 1 year ago) also makes a small diff i guess. These cells are most probably what some would call "surpluses". It depends on the age of such surpluses or batches.
