Do you think it can work well with 3xAA configuration, as in the MCU-C88? Most likely Eneloop or Energizer Ultimate batteries.
The medium-high-blink mode could make a perfect keep-in-car flashlight, but if the low isn't too low to read a map, the default mode could also be great for this use.
You don't need more tools, just the corrent tool. There's a whole thread going on for a year now, only regarding that matter. https://budgetlightforum.com/t/-/744
The same soldering iron for changing modes on the Nanjg 105C, you need also for this new driver available on KD. You don't need a screwdriver :)
I could only get 2Amps from my equipment because of resistances in battery, leads and switch. But I am confident that the driver will deliver the full current when build into a flashlight. I checked the ratio between high and mid by observing the waveform in mid mode with an oscilloscope. It gave me about 33% (specs said 35%). The current waveform in low was really ugly, just some thin spikes at 15000 Hz resulting in a current of 5 mA of which the MCU uses 2 mA.
Sorry for the basic question but I want to drive a XPE R2 at close to 2 amps so can I use the 2280mA and simply unsolder one of the 7135 chips to give approx 1930mA? TIA.
I asked that becasue you know how specs are in general, they need to be tested. Even though the 7135 "35" chips have been proved until now, these are new and not proven yet.
2A it's pretty low so far. Hopefully someone mounts it in a flashlight and we'll get a "in the field" reading of the current.
That can be done, the resulting drive current will be 2280 - 380 = 1900 mA. I think I would choose the 1520 mA type as it is not a very easy task to remove a chip if you have not tried it before and the benefit of driving the XPE that hard is little. It can be done thougt with a heat gun with a small nose and pliers or with a medium big soldering iron, but it is easy to overdo the heating.
I got the 2280 mAh version today and just finished a dropin. Mine are marked 38K and I tested the dropin on high and got 2.274 A. So good news there.
The bad news is that the low mode is just two damn low. These needed to keep the low of the 105c (60-80mA) and then have the new moonlight mode (6-7 mA on this 2280 version) as an option instead of having 4 disco modes. So close and yet so far. I'm glad I have a reserve of 105c's.
