Let me address these things…
The color:
To the best of my knowledge there is no dye used at all. I believe the metallic look is caused by the light being bead blasted prior to clear anodizing. For example, If you bead blast aluminum and then clear coat it, the result is a silver look. I am awaiting official confirmation of the details of the procedure and am also seeing if we can get a just machined look in the future which should involve nothing more than skipping the bead blasting process prior to anodizing.
Throw:
My C8 lights do out-throw my Kronos X6 though I don’t have any equipment to test the numbers. The Convoy C8 with the XPL-HI throws pretty well stock but can definitely be improved if you can get the emitter a bit further into the reflector. The simplest method I’ve heard of to achieve this (modders correct me if I’m wrong) is to sand down the centering ring to make it thinner. This allows the reflector to sit a bit lower, then replace the stock o-ring at the lens with a little thicker one to make up for the difference which will probably be 0.5mm or so. I may get brave and test this over the weekend. That would be my first real mod. LOL
Chip clip:
Thank you for the pictures! That is exactly what I needed to see. I’ve already sent them to Simon along with an explanation of what would need to change to make this home-user-flashable. I don’t know how difficult it will be for them to rearrange things on that board and I can’t make promises but I will try to make this happen. If it’s not doable does anyone know of a smaller clip or clipping method?
Edit: Once again proof that I type too slowly. I see there were two possible clip solutions posted while I was typing! :person_facepalming:
