Really, what argument? Just in throw/kcd, an XHP35 HI should beat an XPL HI if done well at high amps, but a dedomed XPL beats them both.
I just built up a Manker U21 with a dedomed XPL W2 1A from an AliEpxress store and seems like the W2 bin could be the real deal. It did a little better than my dedomed XPL V6 0D also in a Manker U21, same FET+1 driver, same setup. I measured the throw of the U21 with the dedomed W2 1A at 245 kcd (990 meters) taken at 5m, and lumens of 1,731 @30 secs. Not bad for a light shorter than a C8 and head diameter at 59 mm.
“… tiny tear in the battery wrap right at the protection board…” Does this mean you’re using protected cells? That will limit your MT-G2. Use unprotected cells and the output will be ginormous. The MT-G2 peaks at around 12A, can take 16A. In other words, you don’t have to worry about the emitter. I have seen about 16.1A hooked directly to two top cells with no driver, hard wired if you will.
It’s is late, I’ve been saying silly things. The cells I was using are not protected, the wrap did not tear at the protection board, it tore next to the positive terminal. I said protection board without even thinking about which cells I was using, whoops.
I knew that the Luminus SBT-70 is a current monster and yet is very inefficient, producing more heat than lumens, so I machined a copper replacement pill for my Z1 and maximized it for mass wherever possible. The driver is a 17mm, so I made the driver bay and retaining ring smaller to fit my 17mm FET+1 driver. Mo mass.
The SBT-70 is a 3V emitter, albeit a large one, and pulls up to 17A from a single cell. I don’t recall what this one is pulling but it’s high like that, converting most of the current to heat and only about 1300-1500 lumens.
I’ve been out of the forum for a bit and was catching up some and saw this post and comment regarding this white box not normally expected from Jaxman and wanted to say that I to just received an X1 from Jaxman that also came only in a White box with X1 and tint written on the side with ball point pen, “apparently”,
I say apparently because until now I was not really sure what my white box was because it was completely flattened and while looking at this mess in a box that I received from Jaxman I remember thinking where is the Jaxman brown box, well until now anyhow,
I wasn’t sure what that box was all about reason being that my package had been intercepted by customs and they completely disassembled the X1 and just threw all the parts along with the reflector and an additional pill Paul sent me as a gift and along with an original X1 extension all on top of that flattened white box and so I had a reflector with a pill that was rolling around inside of it when I got the package.
Talk about a gut sick feeling and then rather mad, and then really mad when I saw the reflector and just baffled about everything really and the white box was just a mystery.
I get along with the owner fairly well so I didn’t really want to make an issue out of anything other than informing him about what had happened and sent him a few pictures and just asked is there’s any way to purchase a new reflector since I could see that Jaxman had really gone to great lengths to package my light well enough even in this unusual box,
So I just didn’t ask about packaging and just asked about that reflector and how to buy a new one.
I have had a lot of messaging with the owner and it seems there are some issues going on, but not clear on what except some changes to the X1, not sure if this also means Z1 and I suppose there is some changes in packaging obviously but once I saw the tape on my shipping box saying Customs and Inspected I started snapping pictures and it is just a horrible mess and useless light without a reflector.
I did get a message from Jaxman today so I will ask about the white box,
I have seen one cloned M8 and an X1 and some of us saw the first clone that was done to this company called a Cometa, so it might possibly be a product rebuild from box up.? I do know the X1 is getting some changes and I think he said something minor to the Z1 also but can’t recall exactly but will ask tonight or tomorrow about that box anyhow and if this is what’s to be expected in the future or maybe just ran out of the nice boxes… Beats me…
This is what mine came like, well sort of if not flattened out by customs, this is not a clone, I’m just now reading through the posts here, but I did buy mine directly from the owner and I will now inquire into what’s up with this box, not to forget that the additional stuff that should have came like it would have in a brown box came in a plastic zip bag, in think, maybe Customs did that I don’t know, but that box is for real right now.
Yep, Brett I ordered just about the same time you did and this is all inline with what I got also, I have to reply to a message from Paul so I’ll ask, I doesn’t say much to often, sometimes but I do know he has some health problems and then there’s a lot of other problems BG being one, Manker being one and so on, but if I were to guess with his telling me about the changes being made that the packaging may have ran out and this is what he gets the lights from the machine shop in, my guess
T18, you mean they (customs) just threw all the loose parts in the box and called it “good” :person_facepalming: :person_facepalming: :person_facepalming:
Yep, let me put some pictures together and upload them, it was a sickening sight I’ll tell you and then the white box was an absolute mystery on top of it all, until I stumbled upon Brett’s comment here, then it was clear and frankly being I paid just what Brett did I to feel a bit ripped off sort of and really this light is completely useless with no reflector,
Here you go, if you get your package you will know immediately that it was stopped by Customs because well they make it real obvious frankly, Here have a look at how my excitement went from yippee new light to Oh F*** What **&$$****&&&&Y… F*@! Idiots…!!!
What day did Brett say he got his? Mine are date stamped and oh believe this, I was pretty darn mad that’s for sure.
Thanks Teacher,
I thought this was just my weird luck and then I see that Brett has weird luck also, but he didn’t get the Customs treatment though and that is just not fair…. ha ha ha, Yes indeed you will know immediately that Customs has just ruined your product, that tape really catches your attention… :smiling_imp: :cry: :confounded:
Thank You Brett, I wasn’t sure of anything with this white box until you thankfully posted something about it here.
As I mentioned I have been off the forum for just a bit and this thread just happens to be one I keep my eye on, so I stopped to look and see what the mad scientist have come up with lately and first thing I see is that white box… wow… I thought I was just in some weird customs thing and that they had put that box in my shipping box and kept the brown box, I really had no clue whatsoever. Certainly didn’t believe Jaxman sent that to me.
And I it didn’t even cross my mind really to ask when I told Paul what had happened.
I do know there is many problems at Jaxman and it has just been building up since that Cometa incident being that was actually the first time his lights were cloned and with BG being behind all that, that is why the Jaxman lights aren’t at BG anymore but then those cloned Z1’s were sold to us of all things.
Paul is a really great guy and I am positive there is a very good explanation for that white box,
Also knowing he’s making changes to his lights might mean he’s changing up everything about his product, there’s a lot of clone problems going on and right down to that box or so I was told, so it’s all sort of coming together now that I saw your box.
And then throw Customs in the mix and well… I am glad Paul promised to send me a new reflector with the new changed X1 when it’s done so maybe I’ll come out on the upside in the end, but what a dismal day that was when I got a box with Customs tape on it, a first and I surely hope a last, I don’t think I’ve ever heard of anyone else here having Customs do that to a flashlight, what does it look like bomb, a hamburger, or a flashlight?
Good luck with getting that reflector! I hope it works out better for you. Paul has insisted I take a $10 refund rather than a new lens for my light. You can see here
I didn’t realize yours had got nailed by customs also Brett… What luck for you two………. :person_facepalming:
What is a customs declaration?? I’ve never seen one in any of my ‘China’ stuff’… :question:
T18, I could polish that reflector for you so you can have a working light at least. It usually makes for a nice beam but it might cost a few lumens over a PVD coated reflector. Better than sitting on a parts bag waiting for new arrivals anyway. Your call…
