I didn’t realize yours had got nailed by customs also Brett… What luck for you two………. :person_facepalming:
What is a customs declaration?? I’ve never seen one in any of my ‘China’ stuff’… :question:
T18, I could polish that reflector for you so you can have a working light at least. It usually makes for a nice beam but it might cost a few lumens over a PVD coated reflector. Better than sitting on a parts bag waiting for new arrivals anyway. Your call…
The customs declaration is widely misunderstood. You can look up what “gift” means in your particular country.
For most countries the tax is higher, not lower, on items declared as a gift.
For the USA, “gift” means that you intend to give it to someone else as a gift, not that it’s a gift from the seller to you or that you’ll resell it.
There’s a minimum below which there’s no import tax — lower for gifts than sales — but either way, a single flashlight isn’t likely to cost enough to be taxed.
it’s worth remembering that the insured value — if the package is lost — is the declared value.
So by lying about the intended use (“gift”) and the value, the sender actually sets up the receiver to be in worse shape if something goes wrong.
Not that explaining this makes any difference at the sender’s end. They won’t understand it.
No, actually mine did not appear to be stopped by customs. I was just noticing that “gift” designation on the side and wondered about customs seeing that multiple times and deciding to check it out. I could be way off on this thought though.
Gift, tool, parts, I’ve seen em lie in many ways on the customs form, very seldom is the truth told.
Maybe to stop theft by postal workers…
Well hank, that might be true for the US , here in Europe they love to tax stuff
At around €22 tax is due
And that is VAT, import and fees that all in all start at €32 (~$35) to pay to the mailman. On a $25 light with an honest label not worth buying.
And one has the invoice of something so when something goes wrong along the way no seller has given me bdms about declared value.
I agree Miller, everything I have ever sent to GB or Canada, I have been asked to declare it as a gift!
Right, you have to look up your own country’s definitions to know what the words mean.
Note: Most personal shipments worth up to $200, and gift packages worth up to $100, will pass duty-free as long as the recipient does not receive multiple packages in a single day whose cumulative value is more than these amounts…. If you wish to receive automatic updates to this Q&A, select “Subscribe to Updates” …
(emphasis added)
_
Again, that’s the current US rule. Your country’s rules may differ; and they do change over time.
Jaxman Z1 with a MT-G2 Q0.
Looks great!.
Much better than the XHP50 that was in it.
Hey soverignknight I do like the looks of that. Can you tell me a little more about your mod. Did you just swap the emitter or do the driver too? Are you using the original brass pill or did you get another one? If original, how did you get the star off the brass, mine seems glued on.
I ordered a brass pill, and a stock driver from Jaxman. I basically contacted Jaxman via email for the requested parts.
do you prefer the Z1 26650 running on 1 or two batteries?.
thanks.
The XHP 50 model will only operate on two 26650s. It does not have a boost driver using the stock driver. As for one/two battery preference, I prefer two for the size.
thanks, I have a modded Z1 from CRX at 3.5A 130,000+ Kcd running on 2 x 26650’s.
good enough for me.
would there been a difference if the light from 3.5A using 2 x 26650’s to 5.5A LED4P Driver using 1 x 26650?.
KCD?.
benefits or disadvantages?.
thanks.
Jaxman Z1 Help needed.
Hi I am trying to find out the sizes of the O ring on the Tail and Body Inside the Jaxman Z1. could be 019. seem thick on the tail.
I have some on the outside ( but not sure if they even supposed to be there ), but I am sure the ones on the inside would fit the outside.
anyone with a Z1 if you could measure please.
would it be possible to swap whatever LED thi light has for the sbt90.2? or the 90.2 too large fort he light itself? or just nope
Probably yes. If you would like to use mcpcb from intl-outdoor you would have to:
• reduce the mcpcb diameter to 29mm
• drill new holes in mcpcb
• sand the pill to make it flat
• drill and thread new holes in the pill
• make a special washer (the pressure ring must rest on something and it is better not to be led)
Hi!
Is there a way to get rid of the yellow fringe of the beam?
What options you could think of?
Thanks
