Wish I knew about this one. Have any coupons for the m6 simple pack?
thx guys. i ordered it on gearbest
I measured my M3 5C stock, but using an EFEST V2 550 mAh cell and got:
lumens: 680
start, 658
30secsThen after reflowing the stock LED on a 16mm Noctigon and replacing the stock LED wires with good, shorter 24 AWG, I got:
lumens: 734
start, 724
30 secs (notice there is less drop now over the first 30secs? That’s because of the copper DTP star!!)For a CW 1A, I’d expect or guess 10-15% higher on a good IMR cell. We usually quote the 30 second time as the lumens measurement, as according to ANSI/NEMA FL1 standards.
So for a stock CW 1A M3, I’d expect to see 720-740 rated output lumens on a good IMR cell. Not sure how that compares to the supplied cell, might be close.
Of course, this assumes (big assumption) my light box is well calibrated (I think it’s decent ).
is it easy to remove the head/board?
Oh boy, I'm think'n yes. Wish I could recall how I did it . Hhhmmmm. Ok - just reviewed my pics, photobucket OnTheRoad M3, it's start'n to come back. The reflector threads in, so use a good tweezer or pointed needlenose to remove it. The pill assembly comes out the top - nothing special holding it in. Maybe some taps from the tube end are needed, I'll typically use a big nail set, well way over-sized nail set - whatever you may call it. No need to remove the side button.
You have any more deals for this light?
My M3 has a significant parasitic drain. Noticed the cell was down to 2.5A, and then measured it at ~6 mA, but the reading is erratic. I then tested other lights and all faired well - steady, much lower readings, even with an indicator LED lit up. A stock X6R measured 0.565 mA which is considered very high. Most well designed lights measure 0.020 to 0.040 mA, or even less.
In freeme's review, he mentioned 7 umA, which I don't know what it means, but thinking he means 0.007 mA, or 7 uA. So my light might have a problem with the driver. It's the only one I measured that has a consistently erratic reading. I did mod the LED, MCPCB, and used heavier gauge LED wires, so possibly I ruined something in the mod.
Tom , i did a review on M3 in a greek forum back in July , and measured 6μA (6uA) .
Ahh, good to know. Hhmm - sounds like my unit has an issue. Was hoping to do a driver replacement eventually.
It will be really nice with your Narsil , i thought of it too , but i’m quite satisfied with the light & UI.
I got the 0603 parts coming in today from Mouser, and the OSHPark 15 mm triple boards (ordered in thin thickness) from Triple_Ace should arrive in a couple days. Hoping I could jury rig in one of these since it has the full support for reliable operation of the Attiny85.
Hhmm - this would be the smallest light modded to run Narsil, if i can pull it off. I have a Skilhunt H15 14500 size light running it now.
Will you use the existing driver pcb to mount your driver ?
If it fits, yes. I did an angled mount of a trimmed 15 mm driver before, in a SolarStorm AA size light (SC01 or SC03??), and it worked out well, and that was with a thicker stock size OSHPark board.
Realized I never posted the final mod of this light, but I finished it in the end of October. Here's some pics:
Pretty great little pocket light now, nice glow from the button, easy to find on the nightstand - I used a warm white switch LED. Smooth ramping w/NarsilTriple w/ramping optimized for the 3 7135's in the 2nd channel. It seems to perform the best with IMREN 16340 here, with a solder blob on top, but does well with the EFEST also.
i´m interested in one.
ON THE ROAD M3 Pro (2018)
Type-C USB Charging Flashlight Warm White 5C & XP-L
Classic trusty OTR M3 getting new updates!
Any chance for a groupbuy?
+1 M3 Pro
I don’t see the advantage of the m3 pro over the type c U16 unless you obsess over weight or need to save space in your pocket.
I am thankful I got an m1 w/ 5c, looks like they are discontinued now.
Pricing
On the Road M3 Pro (2018) Full Pack (Cool white): $26.99 ($32.67)
On the Road M3 Pro (2018) Full Pack (Neutral white): $28.99 ($34.57)
On the Road M3 Pro (2018) Single Pack (Neutral white): $20.99 ($25.18)
*Free pocket clip with purchase of FULL Pack.
Hey, sign me up Freeme. The new M3 pro looks great!
I stopped carrying the original M3 due to no charging built in. I’ve been carrying the Jaxmnve clone for the last 6 months since it’s the same size and does have built in charging. It’s “okay”, but no where near as good as the M3.
