Pico iStick Flashlight Mod
Pico SST-20 2700K & XP-E Red 670nm - Fet+1 & 105c7135x4 - 18650 - Rv Clicky Sw - 600lm.Luminus SST-20 2700K emitter
16mm DTP copper MCPCB
FET+1 5 mode driver
OP Reflector
20mm ARC glass
Brass pill
GITD LED gasket
Reverse clicky side switch
Cree XP-E Deep Red 670nm emitter
Nanjg 105c 4x7135
Red Mule
Reverse clicky bottom switch
GITD details
Length - 90mm/ 70mm
Width - 46mm
Depth - 24mm
Weight - 175g (with 18650 cell)
Max - 600lmA friend sent me this Pico iStick vaping device. I still prefer the real thing so modded it
The side clicky switch operates the main LED and the bottom switch operates the three mode deep red side LED.
You’ve been on a roll lately…you should create a CRX daily build thread :smiley: That’s a very nice mod by the way.
What do you use as potting material?
It looks really smooth. The only thing I’ve ever used is Red RTV high temp gasket maker and it turned out sloppy so I kind of gave up on trying to pot stuff.
It’s like most things, you get better with practice & experience. That’s why i practice so much…
a man of amazing caliber
Did you stock up just for the month? Another amazing mod. :+1:
Thanks, just using parts i have in the spares box.
your mods are the ones i like most here
