The Texas Buck driver series, Q8 / Skyray King 2S/4S buck driver RELEASED!
Well here are a ton of numbers:
Caps are 10 uF 7.5% dissipation factor.
Inductor is the 15uf one previously (lower resistance than the 22)
Diode is 0.5V Vf Mosfet numbers are a bit vague, but I think at least Rdson is about right, wouldn’t trust the switching losses much at this point though. Input voltage is 16.8, output is in multiples of 3.5 for now (I may add a correction for current, especially since it matters in 1:1). The output power at 4:1 is less because I limited it to 15A for now.
I just noticed, the 5% mode on this light is going to brighter than most pocket lights (not BLF ones). I’m pretty sure we’re going to need that PWM for moonlight and even just an indoor low.
So for a true synchronous buck the freewheel mosfet is opened late and closed early to prevent reverse current, using the body diode during the transition. But I realized for this thing that works during opening, but not closing. It's already open and it closes too late.. and I guess there should be reverse current briefly then. I don't know how ideally that thing really works. A very smart IC could predict closing based on the last cycle and only have issues then during load changes.
Good data, the specs look good. Ripple is actually better then I expected. I was thinking we would have to settle for 2+ due to space constants. Less then 2 will be a big step up from what is currently available at 10% ripple.
What is the input cap ripple exactly?
3W of loss through the diode while obviously not good could be dealt with I think. If nothing else you could stack silicon cubes on it to contact the upper shelf. The synchronous IC would be a great option if it works but we might want to stick with a simple setup to start out with and make sure it works as we desire first.
Overall an efficiency of ~90% is what I was hoping for, supposedly it would beat that for 1:1 and match that for 2:1, which is all we really care about. 4:1 is simply for outlying cases that are good to consider in the early stages.
It took me awhile to come to terms with this input cap thing. It seems to assume that 100% of the AC/ripple current component is provided by an input capacitor not the battery. The size of the cap then determines the translation of that current ripple into a voltage ripple and, as there's ripple current through the cap, of course there are losses there too. Supposedly this cap should be connected as close to the high side mosfet as possible, and I guess should also be grounded pretty well to avoid inductive pickup on the ground side of the cap.
Yeah, I agree the synchronous stuff is a bit elaborate. However it takes time to get boards. If we really think this diode replacement circuit could work, could layout pads for both in a prototype board. Might need to get some breadboard and scopes involved for that kind of development though. I do have access to good scopes but not sure I would find time.
It only needs a 10uf cap to handle that kind of power? Seems kinda small?
Far as the synchronous side of things, I am not sure it is worth it, I think we would come out ahead with a larger inductor over that personally and smaller drivers sure won’t have room for it. So it kinda leaves us at square one and doing all that work for a single driver / setup. It can be done, just not sure it is worth the time and effort.
So now that we know the specs we just need to settle on exact components and finalize a design so we can try it out to see how it works.
Just discussion for fun. I think we'll have a traditional diode this round and 4% diode loss in 2:1 is ok with me, but the larger inductor doesn't actually help efficiency until ripple current saturates, so below 3.5W as 200% ripple means you hit zero current. Just means you use PWM from a little higher mark.
As for the cap, it's only handling the ripple current, and at very high frequency, so low charge (I*t) per cycle. This isn't 60hz AC. I'll check the numbers again by hand though. I did just kind of bash in the equation from that article for that one without much thought, other than following the idea about at the detail I just stated. Still I think there's a tendancy to think like the output cap is supporting power during off time, but the inductor is doing the bulk of that work, at least under optimal conditions.
Oh, one problem with diode loss, as they hot they start behaving more like resistors. That means Vf drops, that's good, but reverse leakage current also increases. That's bad. I have not even tried to estimate how much this matters if at all, but the point is yes, heat sinking the diodes well is probably needed.
Yeah, I figured they would need a large thermal pad, although since it is positive and not ground it is hard to actually transfer that heat directly to the host via copper pour.
Some silicone thermal cubes are quick and easy way of doing it but also a bit more involved for most and I would prefer that not be a requirement, just optional.
A small heat sink could also be glued onto it but with no contact to anything I doubt it would make a large difference.
A synchronous buck IC would be great but I sure have not found anything suitable, have you?
So I did check the cap ripple equation and the bottom line is those numbers were actually too high. Basically what I scribbled down looks like equations 24 and 25 on page 6 here:
http://www.ti.com/lit/an/slva630a/slva630a.pdf (fixed the link)
For output ripple, really only the capacitive part ends up mattering, so what phase angle to add the resistive part in (which creates the other detail in that paper really) is irrelevant. The cap term is just Q/C where Q is average I*t and the rising time is haf of 1/f and the average current is half of the max current and the max current is half of the peak to peak, so with three halves you get v_p2p = 1/8 * I_p2p/(f*C) as per above link.
But the powerlectronics equation doesn’t really agree with that for a couple of reasons, which seem to me to just be wrong, and wrong usually actually too high. I’ll use equation 25 from Ti now which you can see still errs on the high side compared to their simulation.
Components:
Ok I looked at caps a little again. I’m sticking to my 1210 recommendation. There are no 10uF caps on digikey in x7r with ratings 35V or higher in anything smaller (and the 50V ones have the lowest ESR). Furthermore, I looked at larger caps and they get REALLY expensive in those kinds of specs:
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=209394405
That’s a cheap one. The one’s in between cost twice as much.
and it’s not clear you can do any better. For output 10uF is enough. For input ESR is really the problem anyway and above 10uF the caps are pretty much all measured only at low frequency. Even for 10uF where they’re measured at 1khz, I’m not sure I trust extrapolation to 1Mhz well, but at least I can find some cheap ($.30)
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=209396138
and some individually specced (rare, reading through these cap sheets is a pain) up to high frequency, even if not amazingly low ESR (average).
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=209397082
I would recommend room for two or three in parallel on input though.
So I’m done with caps. If you can find something with more capacitance, less ESR, rated better for high frequency or in a smaller package, have at it, but this is the best I got. I am probably about done with diodes too once I post what I have, so a power Mosfet will wrap up the main bits.
Wait, the diode doesn't connect to ground? (or maybe just the casing doesn't?). I better review the circuit. I've seen one Ti example where everything is upside down. Suitable syncrhonous? Not really. I found some IC with like 50 pins and a billion features that yes would work in principle and could handle boost circuits too, but... And it turns out thse "Or'ing" IC's are pretty slow and yes do leak during the 1/2 microsecond when they're closing.
I'm tracking components in post 96: https://budgetlightforum.com/t/-/41130/96
But your links here don't work: https://budgetlightforum.com/t/-/41130/69 post 69.
Odd, my links work fine for me but none of your digikey links for me.
We can put a cap in the input, just goes against my principle of large traces for large current as it all has to pass through the small cap. Although paralleling them is an option as well. I doubt I could find anything better, the issue wasn’t the exact cap to use, it was wether it was truly needed and would make a noticeable difference in the final product.
I will look at the parts list and update the PCB when I get a chance.
OK, I'll try to understand the digikey thing (probably will have to use two browsers to figure it out, sounds like the links might be linked to cookies or something). I better add model numbers.
The input current doesn't pass through the input cap. It's in parallel to the battery contact, and the traces for the cap only need to handle the ripple current, not full DC current. I think it will help protect from all the stray field stuff you're worried about, among other things.
As for what's really needed, you thought 10uF was small, so I don't know what to say. x7r seems required, and I think 2X actual voltage is standard minimum and those specs lead you to 1210 or at least 1206. There's just nothing else. Plus that samsung one is really cheap.
Wow, I see, yes, paste the link in a different browser, and they don't work!
I updated the digikey links in post 96. To get a good link you have to find the share button on the digikey product page. For my own links.. sometimes I have to re-enter the product number in the search to get the share button back.
Ah, ok now things clicked (been distracted recently and never really took the time to think this aspect through). For some reason I was picturing the input cap inline with the mosfet instead of parallel. Now everything makes perfect sense and 10uf should indeed work fine.
:+1:
Interesting, I will keep this in mind.
I will be placing an order with arrow in the next few days due to the free shipping they have going right now, so I might see if they carry these items and grab a set to have on hand.
It will work. Fine, well, you can get about a 3% efficiency boost for using 3 instead of 1 maybe more if real ESR at 1MHz is worse than predicted, or less if it's better. That's why it wouldn't hurt to add places for a few if there's no downside. $.30 for a percent more efficent? Enh, you now, I might do it, just because.
LOL…………just do it!
Not if you do it first.
Yeah, in parallel is easy and there should be plenty of room, could even go with a larger form factor if there was a better option vs paralleling a few 10uf.
I will rearrange everything with the latest component list and see what the space looks like in the next few days.
