I got my s41s with xpg3 and it’s got a purple ring around it at low levels. And it gets purple center on higher levels which are visible even at distances. Why is that?
My s41 which is a xpg2 is more towards neutral white and much better colour. Also a lot brighter.
It also over heats sooo much. Only 20 seconds and I had to let go of it because it was so hor. Something is wrong. While the s41 wasn’t even warm at turbo.
Also when I try the 0.5 seconds to go a level back it simply goes to low. So whatever level I’m at and I hold for 0.5 it goes to low.
At second level. S41s on left s41 on right.
At turbo s41s on right s41 left.
After having a look. It seems two of the leds are much less bright than the other two. It’s not an angle thing. They also have a purple tint.
Something looks wrong in there. But I can’t seem to open it up to check.
I suspect the emitters (right of pic) are damaged due to excessive heat, and caused partial optics melted away. Leave it as it is if you are unable to dismantle it. Create a ticket and inform them your situation first.
I was just watching this video. During the video, there are several times where he has the front straight-on so you can see the correct view with no purple.
Also, when he took it apart he noted that the optic has only 2 legs instead of 4 legs. I’m wondering if maybe because there’s only 2 legs, that may be why they had to glue the optic to the head? Maybe they also got glue on the emitters, of maybe the glue became liquified with heat and covered the emitters?
I can’t even send a ticket as it wont upload any photos. It says “please upload a picture” and I have and it doesn’t go. Ill have to send them an email directly.
