Custom 26650 host - Build from Mag2c body
7 posts / 0 new
Hill
Hill's picture
I had this idea to make my own "pocket" 26650 host since there were not many options out there aside from cutting down a Mag2C (which I have already done).   No lathe was used here folks - all machining was done with a hacksaw, dremel, files, sandpaper, and plenty of patience.
Here is what I came up with:
  • 26650 "grooved" host - Mag2c body cut-down with front and rear threaded tailcaps
  • xm-l emitter
  • 2.8 amp 3 mode driver (shiningbeam)
  • custom aluminum pill
  • aluminum reflector (pulled from another light)
  • glass lens
  • tailclicky
Special thanks to Ma_sha1 @ CPF for his "no lathe" Mag-modding cut-em down ideas here.
Size comparison (Left to right)
Mag2c stock, Mag1c, 26650 custom host, Solarforce L2, 26650 battery
Glow ring in front
Left - this host with 5000K xm-l
Right - solarforce with 6500K xm-l
Size in hand
Edit 12/13/11
I've been asked to provide more details to this build, so here they are.
Here is an exploded view of all the components
Heatsink was made from round aluminum stock (2 sizes) cut, filed and glued together with JB weld (for strength) and arctic adhesive (for heat transfer).  It was then wrapped in copper foil to form a tight fit into the body.
The 5000K XM-L (Digikey) was reflowed onto a 16mm board (from KD) and mounted with HS paste
The bottom of the HS was ground with a dremel to recess the 2.8A driver (Shiningbeam or KD, can't remember which). The black electrical tape is to prevent shorting of the negative contact against the battery (+) terminal.
Negative contact is made by connecting the driver outer ring with the side of the HS, which is then pressed fit into the body.  The inside of the body was bored to accommodate the larger 26mm battery, which also removes the inner anno layer.
View down the bored body.  You can see the seam on the inside where I joined the two threaded halves of the mag body to permit using stock tailcaps on either end - one for the emitter/reflector and the other for the tail switch.
Light engine sliding down into body.  The fit was made tight using copper foil.  The idea was to have the fit snug enough for efficient heat transfer and good (-) contact, but not so tight it could not be removed if necessary.
Bored out tailcap (both were done the same way) using a drill bit first, then a dremel grinding tool to gradually widen it to the desired diameter.
Components of the head - GITD O-ring, glass lens, aluminum reflector, washer for proper focus and prevent shorting of the reflector onto the emitter contacts.
Tailcap and switch.  Details of this build can be found on my build at CPF here.
Finally, beamshots.  These were taken with a point and shoot camera, so I could not manually adjust settings, but this will give an idea of the output.  Distance from my 2nd floor balcony to the dumpster was ~100 feet give or take.  All lights were running full power.
Control
This build @ 2.8A.  Beam is quite floody with some throw.  Tint is very nice
Ultrafire 502B with XPE R2 dropin @ 2.6A.  Much narrow in comparison
SkyRay 1JC8 modded with XM-L @ 2.8A.  This was a little fuzzy.
Finally, a Mag2C modded with a quad XP-G R5 running @ 1.4A per emitter.
My lights here and here
Edited by: Hill on 12/13/2011 - 13:05
JohnnyMac
JohnnyMac's picture
Last seen: 1 year 12 months ago
That is really sweet! I know I'm not alone in saying that we want to see some internal shots and more information on how you made it and what internal parts you used to do it. Disassemble that bad boy and let's see it's guts! Cool
Johnny
dorpmuller
dorpmuller's picture
Last seen: 2 weeks 4 days ago
Sweeeet! I did a 1D following Masha's method also and it worked out fine.
I was looking for some kind of bezel that would fit right on the Mag head threads-wanna put a P60 in it.
Rich
"I am the flashlight king! I can light anything!"
Hill
Hill's picture
Thanks Johnny,
I'll let you guys drool over it for a bit before the "unveiling".  Then I'll spill all!
Thanks Rich -
I like the P60 drop in idea too - but it wouldn't quite fit  into the tailcap.  I would have needed to drill so much out of the tailcap to fit the ~26mm reflector I don't think there would have been any threads left Frown.
There was a post by one guy here who made a completely custom light from basic parts - you may get a bezel idea from that post.  I'll see if I can find it.
Found it - Match's homemade light with no lathe here
Chicago X
Chicago X's picture
Last seen: 6 years 4 months ago
dorpmuller wrote:
...I was looking for some kind of bezel that would fit right on the Mag head threads-wanna put a P60 in it.
Rich
Now there's an idea.  All the love of the P60, with the runtimes of the Mag.
I really need to learn how to thread....
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
Old-Lumens
Old-Lumens's picture
Last seen: 2 years 11 months ago
I had never seen this before, shows how much I search the forums. Really different approach! Love it!
Glad I got to see it.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Shadowww
Last seen: 13 hours 56 min ago
You mentioned XP-E at 2.6A - did you mean 1.6A or you really somehow managed to keep it from burning out at current that high? Or it's only suitable for short (few seconds) runs?
