LiitoKala 26650-50A 5000mah 26650 - great first impressions
Thank you very much side-cross,I’ll see.
In which other flashlights can these batteries works perfectly except Convoy L6 and Manker U21?
Unfortunately, those batteries have been “nerfed” , so typicaly for China producers…not that bad actualy yet nerfed
The capacity now is arround 5000mah( 5400-5500) before yet the int resistance rised and ofc max amp values dropped by 200-300ma
Even so its equal to Efest 4200 Pirple, yet noone can guarantee us future nerfs
It has also a new code……At least those coming from GB
These batteries work in my Manker U21.
Boy, that's some bad news... But never heard the expression "nerfed" before. I really was thinking the LK's were an upgrade to the "Powerizer" 26650 cell that for dropped by the seller couple years ago - best performing 26650 cell at the time. Me and Dale might have been the only ones into them, or least reporting on them. The labeling looks very much the same between the two, so might have been the same source.
Wonder if these from RIC are still the old style: http://cnqualitygoods.com/goods.php?id=2250
I use these LK's in pretty much all my single 26650 lights, and then some - tons of lights.
I use these LK batteries in my single cell 26650 lights too with no problem.
Never heard? Realy?
It was invented by US WoW players 10 years ago, after Blizzard constant characters “nerfs” :smiley:
By that time i used to play that game with a Paladin, a shitty character but impossible to kill too, rofl
Yeah Tom, thats how the new ones look like, you can clearly see the code difference compared to my first picture
Dang...
Tom E and sidecross please name some of yours single cell 26650 lights.
I use these batteries in the Fenix PD40 and FD40 as well as the Manker U21.
Yikes - PK26, Convoy L2, HD2010's, Thorfire JM07's, Z1, X1, Yezl Y3's, FandyFire K2, Warsun, UranusFire C818, 1405's, SupFire L5's and L6, Convoy X3, plus more unbranded or forgetting.
“Nerfed”, LoL! Remembers me of my much earlier times of playing dumba$$ online “role” playing games.
Those units seem good on the pictures Tom E but, how do we know what batch of cells they're stocking?
Potentially alternative source of “unnerffed” units: Authentic Soshine NCR26650 3.6V 5000mAh Rechargeable Li-ion Batteries
Cheers ^:)
I have had good results from Soshine 500mAh batteries I bought last year; they are protected and well under 70mm for use in series.
These cells are good, but they are bigger than specification which can be a problem.
I use them in a Manker U21 and a Cometa.Very satisfied.
Received one 26650 Liitokala from gearbest. Put it through the Lii-500 capacity test and after 19 hours it shows 5266mAh but at 3,55v...
I don't understand, is it safe to use? Also it doesn't fit in to my Shadow JM35.
altblf, may I suggest you to get a cheeeap multimeter?
https://www.aliexpress.com/item/Yellow-DT-830B-LCD-Digital-Multimeter-AC-DC-750-1000V-Amp-Volt-Ohm-Tester-Meter-Digital/32741993514.html
https://www.aliexpress.com/item/DT-830B-LCD-Digital-Multimeter-AC-DC-750-1000V-Voltmeter-Ammeter-Ohm-Tester-Meter-Digital/32744711744.html
These may not be terrifically accurate, but sure as @#$% you won't miss them much if you calibrate 'em with a fine adjuster. LoL!
Cheers ^:)
For crying out loud m8, your Li500 is in a test mode not charge mode:) it could be clearly seen in the provided photo
Update!
Test/Review of LiitoKala INR 26650 5000mAh cells. from our beloved CPF fellows
Even considering cell “C” came from a different manufacturer (PLB vs Hengji Battery), the cells are well matched.
Cheers ^:)
Ha! Yeah I forgot it doesn’t charge it after testing… Thanks :slight_smile:
