I forgot about the EN pin but that will be easy, I already see how I will do that.
The sense resistor I was not worried about, it was the input caps that I am not too sure on. Right now they are before the sense resistors per the datasheet but it sounded like you wanted them after the sense resistors as close to the FET as possible.
As it is, it should shield the sense resistors from the ripple a fair amount. It is easy to swap around, simply change the schematic in diptrace but was not sure what it was supposed to be.
I think it's right the way it is. The caps shield them from ripple voltage (it shields everything from ripple voltage) but not from the FET current. When the fet is closed, there's no current in that resistor. When it's open, there is, so it's getting that pulsing, and the sloping on current, which it should. It's in series with FET with nothing in between so it's got FET current. The battery side of the cap has current that's maybe more constant, as it recharges the cap during off time. Don't let me steer you off the baseline design too easily. I like making improvement, but changes from the baseline need a couple of days to digest. In this case it was just a momentary confusion as I didn't realize how this IC does current sensing.
I do want to review all my cap math in one sitting at some point. It's been strung out with parts selection in between and everything and a some changes, so yeah. Actually I don't think I've really thought through the input cap math at all yet, mostly just refined the output cap math. If you want to pull the trigger on a board order once you get the PWM wire in, it will probably work, but I will probably ponder it all one more time and generate a new set of numbers including sense losses, and higher power scenarios too.
Yeah, I won’t be ordering it for a little bit yet. I plan to get one when I make an order from a china house as it is WAY cheaper for large boards but I won’t have the funds for that for a little while (yeah, $10 is hard to come by lol).
I am just trying to get done what I can, when I can.
I guess the right thing to test it on at first is 4S xp-l. I don't know if that's a reasonable use case, but they should handle full voltage without dying... maybe.
Yeah, once we are happy with the design and we do not think there is anything else we can do without actually trying it out I will release everything like normal.
The cost is a turn off for me, I just don’t see me building these for lights that cost as much as the driver itself. I like modding but I am also practical.
That said I want to see this come full circle, I hate unfinished projects.
Another option is just to turn the whole buck loop upside down and low side switch it. Hang the diode and the cap off Vin, put the inductor and the fet on the ground return, (some Ti drivers work this way by default), have to think about how to charge coff.. still have to flip the gate output though I think, so still need a small fet for that, but no charge-pump controller, big re-arrangement.
I'm kind of liking this though. Why wouldn't this work? In terms of components, just replacing three giant resistors with a level-reversing transistor on the gate drive, and using the current-sensing n-channel fet. Seems like a win. What am I missing? Maybe the level reversing isn't so easy. It's not like an attiny pwm, we don't get to drop the whole controller reference voltage.
How do you want to run it? Can you deliver 4S battery to it and wire 4S xp-l/xm-l led's? I'd run it 4S battery and 2S led personally for xp-l/xm-l, but it's more dangerous while the bugs are being worked out (because if it opens up too much you're putting up to 16.8V on 7V worth of leds). 1S to 1S might be reasonable too. Some of the components should probably be tuned to your application, especially the sense resistance and maybe RoffCoff.
Just saw that current sensing MOSFET is 16mm x 10mm. Still, it would replace the existing fet and the three big resistors, but needs a couple of small components to go with it too. They're also $3 !
Well I guess an SRK with the SRK tailcap (more money) is the best. I don't know what TA has done with the battery contacts here but I guess it should work with the tailcap board to be configurable in 1S 2S or 4S battery input. Of course the BLF Q8 will be the best.
I’m not going to pretend that I understand all of this thread, although I did read it all. But if you aim for 3A to 4 XHP-35’s you’re likely to be popping emitters. It’d be best to aim for 2.8A. 3 is right on the edge with virtually no tolerance consideration.
I don’t have time to see what those high side drivers actually do, mind giving a quick readers digest version? That said we need to keep in mine that if these work out it would be nice to shrink them down to smaller drivers, so less components = good.
I thought about flipping the circuit around but I think at least for the prototype we should try to stick as close to the baseline diagram as possible the more we dig into this, that way we can see what works and what doesn’t and work out the issues from there.
The current sensing mofset being that large (and expensive) puts it into the keep it in mind if the sense resistors don’t work catogy IMHO. Fitting that on the board would be quite difficult and we would have to eliminate it for any smaller drivers anyways, might as well stick with things that are more easily scaled down IMHO.
Well this is being designed for the Q8 but since that will be awhile the next best option is a 4x SRK. Then obviously a custom shelf to handle the heat. A bit of work for sure until the Q8 comes out.
I have not even worked on the bottom side of the driver yet, but it will be like the other multicell TA drivers I have.
We are just designing it for max power right now, the power can be stepped down easily but going up is another story.
Although this driver should have MUCH less ripple then existing buck drivers (largely because of the new IC and the larger size) so it will not be as hard as some. Either way I figure finding the max amps for the XHP35 is something to be figured out later. I actually plan to order an XHP35 with intentions of finding it’s limits when I have some extra funds.
I've been thinking in some detail about flipping it around. There are three interface points:
a) coff.. This is trivial to deal with. Really I don't like how it is now anyway. You can just charge it straight off Vin, it won't be a problem.
b) the gate driver, that's your first question.. cliffs in a minute
c) The voltage sense. Will the LM3409 mind if the sense resistor is biased very near ground? It can certainly handle it at near 4 volts, within spec.
There's no other problem. Solve these and it all just works.
I've been working on b but first the reason.
That mosfet I showed you has an adjustable low-loss current sense, but it's an n-channel mosfet (better anyway).
So, b then. Need to convert off at 16.8V and on at 10 to off at zero and on at well 5 or more.
That's what those drivers can do (maybe not in the end), but actually all you need is a very small pfet. That's it. You drive the nfet from the drain of the pfet. You'll be driving the gate at 16.8V which isn't ideal (more switching loss) but WAAY better than doubling the heat through those fat sense resistors. Done. solved.
c then is my only problem. Will there be any issue sensing across a resistor with near zero offset voltage. I'm not sure yet. One way is to try it.
I don't think this anything to sneeze at. Going from 1 caps and pfet to 3 or 4 caps and nfet reduces heat from 9 watts to 1.5. That all adds up in a big way especially for performance. Sure there are some details, but I'm working through them. Nothing sinister or hidden. It's not complicated really.
It sounds reasonable, assuming the LM3409 does have any catches that would cause issues with this internally. Although how big is that gate driver? If it is too large to fit on anything smaller then the 46mm SRK then we would be doing all this work for this one single driver and have to start over for smaller versions. Seems like it would be wiser to find a scalable design that works for all of them (be it with different current capability ect).
