A bit more precise perhaps, 3535-type also implies the standard XP-footprint with the electrically neutral middle thermal pad between cathod and anode connection pads. The Nichia 119 for example is 3535-size but without the thermal pad, it will not fit an XP-type ledboard and therefore I’m not sure it should be considered 3535-type.
I was a noob once here, just passing on the courtesy I received…. Djozz is correct again in not all 3.5x3.5mm LED’s will fit, but all 219, XPL and XPG series will fit on each others boards and have the thermal path pad in the middle. This was an “Aha” moment for me when I started here…
A Dutch noob even!
Hartelijk welkom.
)Dank, thanx
I’m in for two! Thanks for offering these emitters!
When will you ship them?
Will ship it in weekend.
No new order will be accepted. I will have to count the orders, very very few left.
Ooops, oh well....
What’s the CRI in these?
90+
R9050 = CRI90+ & CRI (R9/Deep red) 50+
Do you happen to know the output bin these have and which chromaticity kit (3-step/5-step/7-step or sm403/sm405/sm407 on the datasheet) these are from?
For this batch,it is SM405 D240.
I would like 5 if you still have them, will send payment soon.
Do you have any left?
Hi,
4 pcs for the Q8 - should work as a good photo light: thermal place, narsil adjustable, cri colortemperature
Sounds perfect, do you have 4 left??
Pls wait a few hours, I will check the availability.
If you still have some I would love 5 of them.
Ya need to set up a reservation list I am trending toward warmer and would love to try a 90+ cri 219 C emitter
wanting 5
