I agree. 18650 lights may have great chip in them, higher output and other cool things, but nothing can beat a good old single AA tail clicky for emergency situations.
Why the tail-clicky, if you donāt mind my asking?
Iām happy with my twisty Jet 1 and modded MiniM*g, etc., and tail-clicky WK50. Well, the switch on the WK50 kinda bites. I guess given those 3, 2 twisties win out over the 1 clicky.
For a small form-factor, a twisty is (to me) a bitlot easier to handle.
Could you use this for blackouts? Docooler Outdoor Solar Powered LED Spotlight Lamp 6 LEDs For Pool Use- Amazon.com
The charger part and the light part have a 10ā cable between them, so it would be good to prevent total darkness in some central part of the house, for bathroom visits and general moving around without need of a flashlight, just run the cable through a window with the charger portion outdoors, it also uses a single AA battery.
And advice I give to people about that: keep the AAs outside the light (eg, scotch-taped to the side) in case they leak, and have a spare (set) also kept separately. Nasty nasty nasty when alkies leak inside a light, and then grow fur and solidify.
To my feature list I would also add micro-USB charging port.
Olight S15R was charging only 14500 as far as I remember. Donāt recall anything that could charge eneloop inside the flashlight. And itās not budgetā¦and bad tintā¦and not a tail clicky.
Wish Neal was still hereā¦ Then we would know that at least they would read it and consider it.
But if this is picked up (by Astrolux, or even āZanflareā), I hope they understand that succes of a new budget AA light is 99% related to an efficient boost driver with good user interface. Using a run-of-the-mill chinese AA driver with low efficiency, low frequency PWM and bad modes and spacing will make it another so so light at most useful as a host. Examples: Manker understood it well, they have developed some great drivers for their AA lights (but personally I do not like the designs and they are too expensive to be budget), and Thorfire did not get it (the TG06 is a very nice design IMO, but it has a very disappointing driver).
I donāt understand thereās not a whole series.
They should make AA and 18650 versions too i.m.o.
The design is pure and very simple, people love it.
I was interested in this, but I have found some relates claiming that the L10ās and L11ās will break very easily if dropped. I guess the solder points will break in impact because the body is not well designed, something like that. Iām having a lot of trouble finding a good 1xAA.
I agree. The BLF348ās Iāve gifted are well-loved and well-used. Thereās a market open and waiting for at least a AA/14500 version of this light. Neal is already being sorely missed- he was good at making things like this happen.
