Thanks for the review, and I’m sorry for you that this nice light died while trying to open it.
The newest Archer is still huge, and that is the only drawback of this great light, but a very important one IMO.
Thanks. It it is a bummer to lose the light. I wish I would have sequenced my testing diffrently. Got too confident in my in what I thought my skill level was.
Size is the price to be paid for dual switch and good knurling. I think the size is great. Much more capacity than a AAA, but much slimmer than a 18650. Length isn't an issue in my pockets. Diameter is, but I still want shape and knurl. I would have no problem with even my wife carrying this in her purse with a Li-ion cell. What light out there do you propose as an option that performs like this one, has dual switches, great knurling and shape, has a really nice UI, and doesn't need mods?
Try a blow dryer to remove the sticky bar code sticker. It worked for me when Banggood sent out the BLF X6SE packages with the sticky sticker across the tops of the nice boxes.
That may do the trick. The texture of the box seems like it will hold a stain from the glue, but I will give it a shot and report back. Thanks for the tip.
just make sure you get it hot enough before trying to peel sticker off. If it tears, keep heating. Good luck.
Got some great news. I took some heat to the light and used some seriously big-jawed, long-handled pliers (with leather protecting the finish) and got the head unscrewed. Have some really great news:
I can now say without qualification that this light really does not need any mods. This is truly the best built light I have ever put my hands on. Will post some pics shortly.
Appears to be Red Locktite. I believe red Locktite needs 400 degrees F to melt. Why do manufactures to do this?
Very nice thermal path:
Direct Thermal Path! Yay! :)
Very nice looking driver. Shelded inductor, nice looking components, was partially potted. I picked off the potting material for these pics.
Reflector is aluminum and screws into the bezel.
I'm hoping the driver still works and will be running tests on it in the next day or two. Will also get better beam shots if all goes well too.
Wow ! Nice to know it’s put together so well. And I like that it is a bit oversized than the norm. Something in the hand that hefts and points so much better than a mini version.
Great Work ! Thanks for the tear down.
Well, I did want one of these but I don’t really want to mess with the Loctite.
Looks pretty long comparing to standard AA…but anyway - nice one! Where I could get one? And the code.
I would like to buy ThruNite Archer 2A V3.
Is there any code for better price?
Thanks for the feedback guys. I think it would be too much of a conflict of interest for me to negotiate a deal for this light given I have reviewed it. Hopefully, one of our deal makers can get us a special price on these Archer line lights. I would hope they would include having the lights not glued as part of the deal.
EDIT: I'll post a couple ThruNite links for those that would like to contact ThruNite or purchase a light. I have no idea how to tell if they affiliated or not. I have no deal with ThruNite for such an arrangement. So let me know if they are affiliated.
Official Website: http://www.thrunite.com (link is external)
Amazon US: https://www.amazon.com/dp/B01FCTD9PG/ (link is external)
EDIT2: Fixed a few typos
Yay! It's still alive! Still has all the modes and great UI.
So it turns out I apparently caused the LED leads to unsolder from the MCPCB when I first attempted to open the light. Now to hook up the driver proper and get some measurements. No intentions to mod it as I think it is perfect stock. Just want to see how it is performs.
To celebrate not losing my Archer 1A V3, swapped the switch and installed a PD68 taillight PCB. My wife said I should put Orange emitters. Sounds like I may be losing the light again, but I do love it when my wife avails herself to the benefits of being married to a flashaholic.
Could have kept the stock switch, but I want to see if a reverse clickie makes any difference in this light. Probably will end up switching back to the stock switch.
I have a Archer 1A V3 that took a spill about a week ago. The fall scraped and deformed on end at the bezel. The light kept working just fine for the past week. Today it fell about 18” to the floor. Now it will not work properly with Nimh batteries. I put a new alkaline in it and it works totally fine.
Here is how it functions:
Firefly, Light on, unscrew tail cap. tighten tail cap, firefly level comes on.
Low, Light on, unscrew tail cap. tighten tail cap, low level comes on. Summary here is firefly and low seem to work normal
Transition to medium, light sort of flickers, both on/off and in light intensity. High, same sort of thing. Strobe, light strobes with full brightness for a short time (single digit seconds), then starts looking like medium/high.
Medium, Light on , unscrew tail cap, tighten tail cap, light does not come on most of the time. If I push the mode select button, light comes on in the next higher mode, behaviour as above.
It seems to slowly be improving a bit. When this first happened, I cleaned the tail cap with alcohol. It was definitely a bit dirty. Just realized I did not clean the body. So I cleaned the body and the tail cap again, no change.
I would just return it, as it is in the 30 day window still, but I doubt it would be refunded due to the damage in the first fall.
I feel like this is some sort of loose connection, or dirty connection somewhere. I tried a fully charged Nimh cell at 1.45 V, and while it is a bit improved with that, nothing works as well as the new alkaline at 1.57V. Actually, upon further inspection, the new alkaline does not work perfectly either it does seem a bit better than the Nimh cells.
Suggestions?
I am thinking of disassembling it to find the loose connection. I have a solder iron, but the tip is sort of big. At my work I have access to smaller iron tips if necessary.
For disassembly, I have the fireplace going, which is a nice hot plate. would this be an appropriate way to heat the light to loosen the glue? Then how does disassembly proceed from there?
thanks, Matt
Crisis averted. I decided to try to remove the body from the head. Set it on my heatplate (fireplace) for about 30 minutes, head and body separated fairly easily with pliers. screwed it all back together, now it works properly. I knew there was a loose connection somewhere.
Any recommendations on how to reassemble it so that I won’t need to clean the body head connection?
Hi sbslider. Congrats on diagnosing and fixing your light. I'm not sure I understand your question about not having to clean the connection. I just picked off the thread lock material, lubed the threads, and reassembled. I would recommend getting that thread lock material out of the threads as it is solidified now and may interfere with fully screwing the head back together.
Thanks for reporting your incidents and repair. That could help future 1A V3 owners.
Thank you for your insight ImA4Wheelr. I see now my post was unclear. I did manage to just pick off the old thread locker. Now I find that when I reassemble it with the head on tightly, it still behaves funny. But if I back off the head slightly, it works properly. So I think I don’t so much want to lubricate those threads, but maybe put some sort of thread locker back in to keep the head in place. I am guessing the connection between the body and head is not happy when the body tube is tightened all the way. Not sure how this connection is made, as I don’t have a magnifying glass or microscope handy at home.
I was considering just some silicone or seam grip that I have, but am open to other options and insights.
many thanks, Matt
Hmmm, maybe one of your leads is getting pinched between the top of the driver and the bottom of the LED shelf when you tighten the tube down. The LED leads attach to the top of the driver and maybe there's a cold solder joint (weak connection that can disconnect under pressure).
If not that, your idea to "lock" the head but with something weaker like silicone sounds like a good idea. Keep in mind that the most popular type of silicone is acid cure which is corrosive to copper and certain polycarbonate plastics. There are two types of cures that are more nuetral to electronics. They are Alkoxy cure and Oxime cure. IIRC, Alkoxy cures are better than Oxime cures for copper and certain polycarbonate plastics. I don't know any commonly available Alkoxy cure products. GE Silicone II's product line are Oxime cure and are readily available. Here is one of those products:
I wonder how good hot glue would work.
As far as using silicone goes, I would try to put it just on the aluminum body tube and aluminum heat case, so I wonder if the fact that it is acid would be a problem there. I have also read about folks using nail polish in other applications, or also super glue. No current flows through this connection, so it seems like anything that would not damage aluminum and is somewhat removable would work. By the way,thanks for the recommendation on the silicone, might have to try that when next time I need some around the bathroom. Then I could use it for the light head too
I am not excited about further disassembly of the head to see about pinched wires or cold solder joints, as my eyes are not the best and I don’t know how to take it apart any further. I have been wondering what materials are used for the connection between the body tube and the head piece for the cell negative connection. I can tell most of the contact area in the head appears gold plated (as all good connector pins are) but it is hard to see what is going on at the edge where the body tube connects. Did you by chance look at that when you had yours apart? I am tempted to take a look tomorrow at this under a microscope while I am at work.
Shoot, I typed a long reply and it got lost. I have to be brief because I have to get to work
I don't know if the off gassing from the silicone will cause issues. Maybe put a small piece of copper wire, a dab of silicone, and a slightly moistened paper towel in a baggie to see if the copper corrodes. The moisture is needed for the acid cure silicone to cure.
Yes, I looked at that connection and I don't see how pressure could cause an issue. Maybe a cold solder joint between one of the 3 pcbs could disconnect when the driver flattens under the pressure of the tube. I think this because you mentioned the drop and then the problem.
