XHP35: measured luminance and forward voltage
Nice work with that figuring EasyB, seems to correlate pretty well.
When you said to multiply by pi I figured I was in trouble, ate the last of the pumpkin pie just last night… :wink:
Didn’t know you had one hitting 2900 Dale. I thought 2300 was pushing it.
I’ve got one doing 2.8A in a MaxToch Shooter 2X, another in a MaxToch SN50 doing about 2.83A and the one in the L2 doing 3.13A. These are all using the LD-2 modified to work on 4 cells. The big MaxToch is using 4 18500’s, the Shooter 2X is using 4 18650’s. The L2 of course is using 4 of the 26350’s.
The TN42 is running on 2S2P Samsung 30Q’s. Been meaning to test it and see if it makes the same numbers on a lesser cell…
Edit: the one doing 2900 started out domed and I sliced it. The Shooter 2X is an HI variant and the SN50 is an HI as well.
Did the output fall after you sliced it?
I think i remember reading Dale had the XHP35 HD hitting over 2900 lumen. I think he also sliced the dome to test and lost about 600-700 lumen?
I just tested my L2 in the box, 2349 with the little 26350’s at 4.17V well rested. So yeah, about a 600 lumen’s loss in the end. But over 300Kcd so it’s still very viable.
Thanks for measuring again. I think you misremembered the throw number though. You said it was around 208kcd.
The die luminance is sensitive to the thickness of silicone left after slicing, so maybe with a HI emitter or a closer slice it could get up pretty close to 300kcd in the L2.
He may be referring to my comment of getting 300kcd in my SP03…… or he might be just being Dale and forgetting like you said :smiley:
300kcd should be possible in an SP03 with the 3 emitters.
Yeah well, doing good to remember my own name after nights like last night. With so many lights its tough to keep all the particulars separated. I know my Shooter 2X got about 322Kcd, very close to what it was as a de-domed XM-L2. Why on earth would the larger L2 be less throwy? Now I gotta go get a new reading on that too. :stuck_out_tongue:
Yep, 206.75Kcd as of 2 minutes ago. The Shooter 2X has a larger diameter and deeper reflector, as well as being powered by 4 Samsung 30Q cells instead of the short 26350’s.
Sorry, my bad.
Are those 26350’s sagging under 2.6amps? I think it must be more about the reflector and focus of the Shooter than it is the cells. Or of course the emitter itself. Are they both HI’s or is one sliced?
L2 with dedomed XPL V6 1A can reach 280Kcd. Based on my measurements, the XHP35 HI could reach ~93% of that. If the dome slice is not very close, that could take away an additional 20% to make ~208Kcd.
I built an L6 with de-domed XP-G2 S2 0D and a Buck driver that makes 439Kcd. The driver is Richards 5.5A 27.5mm. Pretty nice in the L6.
I didn’t try to get the slice super close, like to protect the bond wires a bit ya know. :wink:
Nice testing, I have an XHP35 on order to test myself. I want to see if you can drive it with a PWM from 4S cells and how that compares to a constant current in output.
The Texas buck driver is nearly done but frankly it is simply going to be too expensive for all but the most dedicated setups. So back to using a liner driver. Maybe have to rethink the whole op-amp thing.
I got the opportunity recently to mod a Lummi Short Orb. The original driver was non-functional and, if still available (which it isn’t) would be $50 for the driver itself. This little Lummi now has a 12mm FET driver with ramping firmware making from 10 to 1911 lumens. :slight_smile:
Some “proprietary” drivers get quite expensive!
Yeah, I am glad I decided to go ahead with the Texas Buck but it is looking like it will be $15 in parts alone all said and done. Not out of this world but 2-3X more expensive then most other drivers we use.
There is the possibility that price can be reduced some but not drastically while keeping the high current ability.
So that comes back to the Texas Avenger or an Op-Amp setup.
Texas_Ace, what is this op-amp setup you speak of?
Regarding your planned efficiency testing, you might check out these simple measurements I did comparing direct drive PWM to linear regulation.
Yeah, those are what made me want to do some testing of my own. Not that I don’t trust yours, I just like to do things for myself.
An op-amp is what the LD-2 uses, I have not wanted to really mess with it as I was hoping that a buck driver could be done for a reasonable price but that is not looking likely. Plus LED4power sells them and I didn’t want to hurt his sales with an open source version. That said if I was to use a driver like this myself I would want it to be open source.
Isn’t the LD-2 like $17 each? I’ve never bought one because of the cost and MOQ. If your high quality buck driver would be similar cost I’d rather have the buck (especially since I could use other FW’s). It would still need to be absolutely necessary to make the cost worth it, but I think the XHP35 is a special case.
Was thinking the same thing. Richards Buck driver is over $20. It just is what it is, component cost and complexity with dependability and reliability, well, you don’t shortcut when you’re counting on something to work, right?
