I’ve got one doing 2.8A in a MaxToch Shooter 2X, another in a MaxToch SN50 doing about 2.83A and the one in the L2 doing 3.13A. These are all using the LD-2 modified to work on 4 cells. The big MaxToch is using 4 18500’s, the Shooter 2X is using 4 18650’s. The L2 of course is using 4 of the 26350’s.
The TN42 is running on 2S2P Samsung 30Q’s. Been meaning to test it and see if it makes the same numbers on a lesser cell…
Edit: the one doing 2900 started out domed and I sliced it. The Shooter 2X is an HI variant and the SN50 is an HI as well.
I just tested my L2 in the box, 2349 with the little 26350’s at 4.17V well rested. So yeah, about a 600 lumen’s loss in the end. But over 300Kcd so it’s still very viable.
Thanks for measuring again. I think you misremembered the throw number though. You said it was around 208kcd.
The die luminance is sensitive to the thickness of silicone left after slicing, so maybe with a HI emitter or a closer slice it could get up pretty close to 300kcd in the L2.
Yeah well, doing good to remember my own name after nights like last night. With so many lights its tough to keep all the particulars separated. I know my Shooter 2X got about 322Kcd, very close to what it was as a de-domed XM-L2. Why on earth would the larger L2 be less throwy? Now I gotta go get a new reading on that too.
Yep, 206.75Kcd as of 2 minutes ago. The Shooter 2X has a larger diameter and deeper reflector, as well as being powered by 4 Samsung 30Q cells instead of the short 26350’s.
Are those 26350’s sagging under 2.6amps? I think it must be more about the reflector and focus of the Shooter than it is the cells. Or of course the emitter itself. Are they both HI’s or is one sliced?
L2 with dedomed XPL V6 1A can reach 280Kcd. Based on my measurements, the XHP35 HI could reach ~93% of that. If the dome slice is not very close, that could take away an additional 20% to make ~208Kcd.
Nice testing, I have an XHP35 on order to test myself. I want to see if you can drive it with a PWM from 4S cells and how that compares to a constant current in output.
The Texas buck driver is nearly done but frankly it is simply going to be too expensive for all but the most dedicated setups. So back to using a liner driver. Maybe have to rethink the whole op-amp thing.
I got the opportunity recently to mod a Lummi Short Orb. The original driver was non-functional and, if still available (which it isn’t) would be $50 for the driver itself. This little Lummi now has a 12mm FET driver with ramping firmware making from 10 to 1911 lumens.
Yeah, I am glad I decided to go ahead with the Texas Buck but it is looking like it will be $15 in parts alone all said and done. Not out of this world but 2-3X more expensive then most other drivers we use.
There is the possibility that price can be reduced some but not drastically while keeping the high current ability.
So that comes back to the Texas Avenger or an Op-Amp setup.
Yeah, those are what made me want to do some testing of my own. Not that I don’t trust yours, I just like to do things for myself.
An op-amp is what the LD-2 uses, I have not wanted to really mess with it as I was hoping that a buck driver could be done for a reasonable price but that is not looking likely. Plus LED4power sells them and I didn’t want to hurt his sales with an open source version. That said if I was to use a driver like this myself I would want it to be open source.
Isn’t the LD-2 like $17 each? I’ve never bought one because of the cost and MOQ. If your high quality buck driver would be similar cost I’d rather have the buck (especially since I could use other FW’s). It would still need to be absolutely necessary to make the cost worth it, but I think the XHP35 is a special case.
Was thinking the same thing. Richards Buck driver is over $20. It just is what it is, component cost and complexity with dependability and reliability, well, you don’t shortcut when you’re counting on something to work, right?
Agreed. Most of my builds I do on the cheap because I want big numbers and wow factor, but then it sits on the shelf 99% of the time. For those I probably wouldn’t spend $15-16 on a driver.
If I had a scenario where the light was used often and reliability and efficiency were a must, $20 for a good buck that I can program myself isn’t a huge deal.
Yeah, thats the same reason I never ordered any LD-2’s. If an open source version was made it should be only slightly more then our normal FET+2 setups (actually could be the same price since we don’t need the 7135’s). Plus it would be able to run Bistro / Narsil.
The buck driver right now is only in SRK size, a smaller version is possible but not sure it would be worth it when the mtnmax is already open source and works fine. It would not be any cheaper, just a bit more updated with the latest components.
The op-amp is a good idea, the only issue with it is the heat it has to dissipate. Although if you combine the current adjustment with PWM you should be able to overcome the heat issue while still allowing it to limit current. The highest heat is generated in the mid range modes.
