XHP35: measured luminance and forward voltage
Was thinking the same thing. Richards Buck driver is over $20. It just is what it is, component cost and complexity with dependability and reliability, well, you don’t shortcut when you’re counting on something to work, right?
Agreed. Most of my builds I do on the cheap because I want big numbers and wow factor, but then it sits on the shelf 99% of the time. For those I probably wouldn’t spend $15-16 on a driver.
If I had a scenario where the light was used often and reliability and efficiency were a must, $20 for a good buck that I can program myself isn’t a huge deal.
Yeah, thats the same reason I never ordered any LD-2’s. If an open source version was made it should be only slightly more then our normal FET+2 setups (actually could be the same price since we don’t need the 7135’s). Plus it would be able to run Bistro / Narsil.
The buck driver right now is only in SRK size, a smaller version is possible but not sure it would be worth it when the mtnmax is already open source and works fine. It would not be any cheaper, just a bit more updated with the latest components.
The op-amp is a good idea, the only issue with it is the heat it has to dissipate. Although if you combine the current adjustment with PWM you should be able to overcome the heat issue while still allowing it to limit current. The highest heat is generated in the mid range modes.
The integral is fine of course. The "problem" (not a big one) is that it assumes the LED is a Lambertian emitter. Just looking at typical output curves that certainly looks pretty good for HI by eye, and a bit off for HD. I checked one angle, cos 50 = 64%, looks dead on to within what I can read on their graph for the Hi version, which is what I'd kind of expect. (can use cos(60)=0.5 but there's no line at 60, still looks dead on though. There is free software that can "steal" numbers off graphs very precisely actually) The HD versions seems to be about 10% too high relative to lambertian for middle angles at least, so you'd understimate total lumens for an HD I think.
But if you really want to be accurate, that's why I said just normalize to CREE's own lumen numbers at lower output. I guess the angle profile doesn't change that much with power. Of course what you're really doing then is trusting cree to measure the absolute light output and you're just measuring the power curve and extending it out, but it's a good cross check at least, and really, I'd probably trust cree. Should I not? An intermediate way is to just trust their angle profile, use software like I mentioned and integrate it numerically (don't forget your sin(theta) factor). Of course that's more work, and you're probably within 10%, maybe quite a bit better.
I think I bought 4 of the first LD-1 run, then I bought 10 of the LD-2’s. I’m enjoying them and have 2 running the XHP-35 to good levels. There was some TINY schtuff to solder on that mod but in the end they work so it’s all good. I think I have one left. I’ve got LD-2’s in an X6, an Fenix TK22, and several other lights that I use seldom and forget what driver is in em, always get a bit flustered at 4 modes when I’m used to 7! lol
Same here PD, way too many hot rods on the shelves above me, just sitting there with charged cells waiting to go out and play but gathering dust all the same. With some 170 lights, I have a few favorites and rarely use the others. Need to sell a hundred and then some, let someone else have some fun I guess.
The MTN max buck is very different from the new buck. It converts down to a FIXED voltage (or current, I forgot which, probably voltage, or it wouldn't need those big output swings to do histeretic control).. and then it's as if you have a (very noisy, although non-sagging) battery at that voltage. The rest is done with PWM with its usual inefficiencies. That's just all that IC is capable of. So yeah, updated compontents I suppose coverers that, but one is a voltage converter with a PWM driver. The other is a buck driver. The voltage converter still has the advantage over a battery of not sagging, which can be a big deal, but is surely much less efficient than a current controlled buck driver like we're working on. To me this pwm "DAC" hack to the iadj pin and the reduced ripple voltage, are the two selling points.
To get again another generational leap, it would need to be synchronous and have a sense current amplifier, all more money, and probably won't fit in the small ones.
Wish I understood this stuff better.
Basically there are lots of ways to skin a cat.
But cooking it up so everybody likes the taste is another matter altogether…
That thought might gross some folks out, so let me say this. In the old days of this country the mountain men were hunters and trappers, had their choice of virtually every animal to eat. I’ve read in quite a few different places that the wiliest old mountain men preferred Cougar meat over all other.
I don't think that's a fair summary. It makes it seem as if it all gets to the same endpoint and that's not true.
DB custom I'll try to be a little more clear. The mtn-max basically produces one single output current (just checked). So imagine it makes 6A (you can buy for whatever you want). Then it uses a standard direct drive style control to PWM that, sending pulsed current to the LED for reduced modes. But the LED always sees 6A or nothing, just in pulses. an XML is brightest at 6A but it's not efficient at 6A, pulsed or not, it's still 6A and that's not efficient.
What you want is a buck where you can actually dynamically change the current setpoint. The LM3409 can do that but it requires an analog voltage input. What I proposed and we're doing, and I don't know maybe was already in the design too, certainly TA also always thought it should work that way, so I might not have added much except getting the cap value right for it and nudging him to get back on it, but anyway.. what this setup does is use PWM from the mcu and filter it through a cap to make a steady controlled voltage to control the IC current setpoint with. The buck should deliver a steady current for your selected mode (with a very low ripple voltage too at least in good circumstances).
That means in low mode, it's only pushing low currents through the LED, not high currents like the MTN MAX. For the very lowest modes it will probably still need some PWM to help it, but it will already be efficient at that point.
Well they do all reach the same end point, they all light up an LED without burning it up.
The same way you can deep fry, roast, broil, grill, smoke, boil a cougar to make edible meat.
Sure they will not taste remotely the same but they are still cooked meat in the end.
Most people would never know the difference between any of the drivers we are discussing from a purely technical standpoint. The only thing some might notice is the tint shift on the non-PWM versions. By eye you would not notice the difference in output with any of them.
true enough. They may notice the battery life though. I use my lights hiking and biking. 20 mins extra on that 30% mode sometimes makes a difference.
Battery run times will be longer from the more regulated circuitry and the light will probably last longer due to the more efficient nature.
Thanks Flint, I knew that but of course… forgot. I don’t deal with it much as I typically use the FET direct drive for maximum output.
I have more recently bought a few lights with regulated circuit for just those reasons. They tend to be pricey lights though. Like the small Nitecore MH20GT. Very nice little light. Pricey. I’ve also gotten a couple of review lights lately that promise regulation, the nifty Rofis TR20 with an angle head tube style design and the zanflare z1, another tube light with interesting feature set. Still have to break down and photograph the TR20 for a review, but so far I’m finding it a pretty nice light and the adjustable angle head feature is something that, paired with the strong removable magnet at the tail, could come in very handy indeed.
Regulation, gonna have to figure all that out and build me up a nice XHP-35 version. I have a few bare emitters, gotta figure out what driver to use and then decide on how to build the host. Looking at what TA is doing, have some big metal on hand so just have to design it. :wink: (Reckon I’ll have to try Narsil as well.)
I agree, assuming the pattern is Lambertian is an approximation. A very good one for domeless emitters and good one for most domed emitters. For a domed emitter I might make an adjustment based on the actual angle profile like you suggest. I actually have measured the angular profile of a lattice bright emitter domed and domeless and they were very close to the profiles for the XPL and XPL HI profiles, respectively.
I don’t think Cree’s output numbers are very very accurate. For example, I’ve measured the XPL HI V2 1A to be brighter than other V2 emitters with different color temperatures. Some of this of course could be the difference in how our lux meters sense different wavelengths. Also, djozz’s measurements are commonly above Cree’s quoted numbers. Their numbers do just represent bins after all, so I wouldn’t expect them to be spot on for all emitters.
I have couple of xhp35 lights a Ultrafire F13 with a 1A boost driver and a Jaxman X1 with a 1.5A boost driver, I like the X1 very much maybe 1800 lumens OTF and a throw of at least 700m and it doesn’t get as hot like some of my other lights.
That sounds very nice indeed.
This is from another thread
X1 XHP35 HI D4 1A, boostdriver, Keeppower 26650 protected, approximately 700m
I actually think your method might be more accurate than an integrating sphere. Integrating spheres will have some angular non-uniformities in their responses anyway.
You could of course also measure the angular profile one one power level if you're really ambitious.
Anyway 2600 lumens is defiitely impressive. So for throw that should be equivalent to about 1670 xp-l lumens just dividing by the area difference. I'm not sure how an xp-l hi at 6A does. Probably right about there I guess.
Throw per watt, the xp-l only needs to get 1336 (multiplying again by 24/30 as a rough figure) to be even. Obviously the xp-l hi can beat that handily at 6A (24 watts).
Basically, at a more sustainable power level of 10W for either, the xp-l will get a brighter spot downfield, while the xph35 will get a bigger spot downfield. At max power they'll be about the same brightness, with xhp-35 still bigger, but also draining batteries faster to produce the light in the extra area.
It all depends where your measurement errors and uncertainties are, both methods can be done less or more accurate.
An example: the method of the OP and derived fine-tuning discussed later, heavily depends on a good quality well-calibrated luxmeter and requires some thinking about what the influence is of the diameter of the detector, while on the other hand in an integrating sphere method the luxmeter’s calibration is not very relevant but the calibration light sources often are uncertain.
