So that fan doesn't seem to me to be PWM controlled or voltage controlled or throttled at all actually. Mine just turns on at 10A and turns off at 9.5. There is an n channel mostfet (SI2302, says A2sHB on it) connected to the negative lead, but that's not a PWM fan. So that fet is just turning it on or off and leaving it there.
I'd like my case fan to be on all the time probably, and that's easy. Because, being that's an n-channel switch, the positive side of the fan always has 5 volts, so just get the +5 from there and ground from the input supply ground and you have an always on external fan. I was fearing I might have to go digging for 5V on some very tiny solder connections.
What I don't know is is the 10A turn on fixed under all conditions or does it turn on lower under high power? I have a suspicion it's fixed and 10A and 20V is quite a bit of power for now fan. Anyone tried a combination like that?
My fan sure seemed to get louder as the DPS3012 started to heat up. Possible they just turn it on full blast with the 5015 due to the higher power ability though.
Come to think of it the 3012 would kick on around 6A or so IIRC so they must be set up differently.
Ok, that's good news. Well, and maybe it will ramp up to higher voltages too. Maybe I jumped the gun on this assessment and just haven't pushed it hard enough yet.
For those that want to use an ATX or other simular low voltage power supply this same company just released a new buck/boost version of the power supply module.
It outputs 0-32V and the input is 6-40V with a 5A max current.
This really opens the door for more compact and easier to build power supplies if you do not need the higher current and voltage abilities of the DPS5015
It is on sale during the introduction for $28.99 for 3 days, grab it while you can, they always do this when released and the price DOES go up after that.
Not that hard, the magenta curve shows the power loss in it. The maximum is about 10W in all the test I have done, the only significant exception is when I am very close to the current limit.
Here is the Design for the Acrylic case I made in case anyone wants to make one. It is cut out with a laser cutter from standard hardware store .08” acrylic sheet (“plexiglass”). Thicker acrylic would be stronger but costs a lot more and is much harder to find.
Proper acrylic glue will be stronger and look better but hot glue or super glue works just fine as well.
