Please PM me with your serious “I’ll take it” and for PayPal and shiping information. Thank you very much for your interest.
Ok, I have 25 lights set out, pictures taken, lumens on the highest setting measured in the light box. Lumens is with the cell that’s in it, at rest, some for longer periods than others. So none of these are fresh topped off cells output numbers, with fresh charged cells the numbers will be higher in most cases.
1. Sold $30 DQG Tiny (26650) Triple XP-G2 in WW, 1231.65 lumens
2. Sold - $25 Fenix E41 (4*AA) XM-L2 with a large defined hot spot, 489.9 lumens
3. Sold $30 Jet Beam RRT21 (18650) XM-L2 NW with a tail switch and a rotary dial, 500.25 lumens
4. Sold $40 MaxToch (2*18650) MT-G2 sliced, 2577 lumens
5. Sold -$45 Sunwayman T40CS (2*18650) LD-2 driver with XP-L emitter on 32mm Noctigon, 1248.9 lumens
6. Sold $45 Fenix TK22 (18650) LD-2 driver with XP-L V6 3D emitter, 817.65 lumens Military Grey (a clear anodized satin finish, sweet light)
7. Sold $50 ArmyTek Barracuda (2*18650) XP-L HI with hand polished reflector, very tight hot spot, 959.1 lumens and 198Kcd for 890M throw
8. Sold $40 Eagle Eye X6 (18650) XM-L2 U4 1C Triple with original Qlite converted large FET driver, 4 modes, 2677.2 lumens
9. Sold $25 Lucky Sun D80 BLF chopped (18350) XP-L HI emitter with A6 FET+1 driver, 855.6 lumens on a fairly low rested cell
10. Sold $45 MecArmy PT10 (10440) XP-G2 Triple, stock, 969.9 lumens
11. Sold $15 Romisen RC29 (14500) XP-G2 with Qlite driver and added chips, 514.05 lumens (no longer a zoomie, has 15mm reflector)
12. Sold $50 Olight M3XS UT (2*18500) XM-L2 de-domed, 1269.6 lumens (factory UI, bumped)
13. Sold $45 Lixada XML 3800 (1*18650 with a dummy) XM-L2 Triple, FET+1 driver, large copper heatsink (you can feel the weight of it!), 3356.85 lumens
14. Sold $35 Solarforce M7 (18650) XM-L2 NW Dual switch with ramping firmware on FET driver, 1187 lumens
15. Sold Olight M3X Triton (2*18650) MT-G2 at 3040 lumens
16. Sold $70 Fenix TK75 (4*18650) XM-L2 Triple, domed, 4309 lumens
17. Sold -$30 MiniMag (14500), chopped (14500) XP-G2 triple, 711 lumens with fairly low cell
18. Sold $30 Eagle Eye A6 shorty, (18350) XP-G2 triple, 1263 lumens
19. Sold $20 Xeno E03 (14500, AA) XP-G2, 421 lumens on 14500, 97 lumens on rested NiMH Eneloop
20. Sold $30 Eagle Eye X6 (18650) LD-2 driver with XP-L HI emitter, 1059 lumens
21. Sold $40 EagTac TX25C2 (18650) XP-L V6 3D at 593.4 lumens
22. Sold $50 Courui D01 (3*18650) SBT-70 emitter in high CRI daylight white at 1045 lumens
23. Sold $60 Jax X6 Hunter (2*26650) MT-G2 with reflector fitted to the large emitter, surprisingly tight hotspot at closer ranges, 4388.4 lumens
24. Sold $60 Convoy L6 (2*26650) XP-G2 S2 0D de-domed with MTN Buck driver at 5.5A, side e-switch does not function with this driver, 1142 lumens and 439Kcd
25. Sold $70 Trustfire XM-L 12 emitter big boy, (6*18650) 12 of the XP-E2 Torch emitters on Noctigons, 2998.05 lumens (a surprisingly tight hot spot even for a single emitter light, crazy from 12 emitters!)
