I think what I’ve always thought of as “memory” is Short Cycle Memory. Essentially saying that from Hi, you reset back to Low, right? As opposed to going L - M - H - M - L ?
No, you go from any mode, not just hi, to low. Changing modes always starts from the first mode.
Big update, and source code is now included. See the OP.
My NC P20 is a clicky and it has this function. I’m a noob at this firmware stuff so no idea how they do it
The P20 has a dual-switch setup. And based on reading the manual, it sounds like that MODE button may be an e-switch. If LEDs in the tailcap can blink without the light being turned on, there’s juice flowing even with the light turned off. Such is not the case in your run-of-the-mill clicky.
Cool light though! Nitecore, while expensive, does make some nice lights. My P12GT was my first intro into the li-ion world, had me a bit spoiled
A couple minor updates, see the changlog in OP
A couple minor updates, see OP for details
Can you do a setting so that it always get on at 100% another tap gets you to strobe then reversed mode toggle
Tactical configuration for self defense
I’ve never used a tactical setup. So basically just 100% and Strobe, no memory?
I’m right at the max size of the code as it is, but I’ll see if I can trim something down for some new options like that.
Yeah for tactical no memory and starting at 100% is ok group can stay as it is just reversed with hidden modes
For defence just turn light on and get max output is important
perfect firmware,thanks gchart for helping me out perfecting git even more! Quite helpull BLF fella
I tried your FW the first time today and it works fine for me. Thank you very much gchart!
It is the only one I found for Attiny13 with LVP, Batt Check, Turbo timer and without hardware modification (is there another one…?). And it can be further customized for my needs :+1:
Hello Gchart,
I hate to keep bothering you. Your version of babka based off biscotti is perfect for me. I finally got biscotti to work however, when I try to compile your babka I get several errors in reference to delay in ms:
Do you have any suggestions?
Thank you,
Frank
Hi Frank, no bother at all! It looks like the compiler isn’t finding the “_delay_ms” function. It should be in the “tk-delay.h” include file. Do you have that file in the same directory as your C file? (or nearby with the C file pointing to appropriate directory)
Also, there’s a new version that I just thought to upload, you can find it here. Highlights:
- Simplified Turbo Timer options to just Off / On (instead of Off / 3 min / 5 min)
- Lots of optimizations (smarter about INLINE functions, register variables, global vars, etc)
- Flexible-length mode groups
- Increase from 4 mode group options to 14 (can have up to 16)
- Fast Presses redundancy
- Option for turbo ramp-down instead of abrupt stepdown (set at compile time)
- Room for even more, currently compiles to ~956 bytes
Thank you gchart! I will double check when I get home from work today, and will be trying the new version!
Frank
Got the tk-delay.h issue resolved however now when I run it as copied from your page it states it is 1132 bytes and 110.5% full. Do I need to disable features or am I doing something wrong in atmelstudio? I have optimization set for –0s.
Thank you,
Frank
Wow, that’s a considerable size difference. You shouldn’t need to disable anything. I’m guessing it’s a compile option in Atmel. You say you have “–0s” selected… how about language standard C99? Make sure to use both of those.
Worked like a charm gchart. This is my favorite firmware so far thank you again for the help.
Great! You’re welcome :+1:
-Gabe
Hi, I just noticed you updated this. I copied the changes into my repository.
