Revisiting Hot Air Rework Stations - Which to buy?
The 862D+ looks pretty good right now, I like the completely separate controls for air/iron. I just can’t find any specs on the wattage ratings for each side.
I have the Aoyue 937+ with several Hakko T18 tips. It’s like a whole new solder station with the Hakko tips. They work so much better than the tips that came with the station.
You could almost buy a whole new solder station for the same price :smiley:
The ones I’m finding are a small set for $30+ :open_mouth:
The three I bought were half the price of the solder station. A cylindrical point, 2.4mm chisel tip, and a 3.2mm chisel tip. About 8 bucks each, but they sure work good.
Hello everyone,
You can go to this site and take a look around:
They have a lot of options and parts for replace. By the way, I’m a newbie here and learning a lot, thank you BLF.
bump to see if there are any more opinions out there.
Currently top of my list are:
853D, because it has a small DC power supply built it, which would be convenient and save desk space.
and
862D+, becaue it has knobs for everything instead of messing with holding down buttons.
Either unit would never do for me. I would never give up my Hakko iron - there's no wiggle room there. One time I accidentally cut through the cord to the iron - replacement cost almost as much as the full up iron - I ordered another Hakko without delay. Felt like a complete novice using my backup - totally useless. The Hakko is that good. Dale says pretty much the same thing about his. Dunno how anyone else mods without one, or something comparable.
For $97, but of course just the iron: https://www.amazon.com/Hakko-Digital-FX888D-Soldering-Station/dp/B00AWUFVY8
I have no problems with my iron, I’m just worried about having space on desk for two boxes and two power cords. That’s why I’m primarily looking at combo units.
For flashlights use i am currently working with Gordak 850, using it for 2 years already, made like 300+ drivers, dedomed zounds emitters, remade lotsa drivers and dismanteled unknown numbers of other el.components- working like a champ- bought it vs….prolly 80 usd
Meanwhile my work Weller Hot Air station failed twice, price difference is above 20x
Brands aint what they use to be…
Great Iron. I’ve been using mine more than my Weller these days. I only use Hakko tips with it, never aftermarket ones.
Here’s another version of the similar or same thing. $55
I think this is the one I’ll end up putting on my list. Solid unit, and Jet.com has a 15% discount off the already good price.
Yeah, $46.71, I may get myself one too.
I have a few different set ups.
First is a Sparkfun 303D hot air soldering station.
The hose can be a bit clumsy with knocking stuff around the bench, but it’s otherwise quite nice to use.
Next is a Weller 140/100 watt gun.
https://www.amazon.com/Weller-8200PKS-120-volt-Universal-Soldering/dp/B002YDMZF4/
I was feeling dumb a couple weeks ago when I thought it was bad. Nope, the tip wasn’t screwed down tight. It works so fast, but it’s unwieldy.
I wanted more control, so I got an Auyoe 937+ adjustable soldering station. I have doubts that this is working correctly, and I’ll be testing it soon.
https://www.amazon.com/gp/product/B000I30QBW/
I couldn’t find my soldering gun for years, so I picked up a Benzomatic butane soldering iron. That thing gets super hot, can do very thick wire, can be used for heat shrink, but I’ve had a couple of mishaps with the heat port burning things that shouldn’t be burned.
There’s a cheap soldering iron, pencil type, 30 watts. Model VEC228. This was my first soldering iron and still occasionally use.
I too would like a nice 2 in 1 station to use ocassinally.
A couple things that stand out. I’ve heard from people that the air guns that use the pump in the housing have very annoying hoses. They have to be a bit firm to prevent linking and this can knock stuff over or off your work space. So I’m thinking a air motor in the handle is the better choice.
Second is a temp display in Fahrenheit. I’m American and not used to Celsius. Fahrenheit is just easier for me.
I’m gonna do some more research in this 995d unit by Yescom. It’s a little higher in price at $86 with free shipping from jet.com, but you seem to get a lot more.
https://jet.com/product/2in1-995d-Lead-Free-Soldering-Station-Iron-Station-SMD-Rework-Station-Digital-We/c8dfca1a67994cb3bde191db38f1acad
It has a calibration function to get your temperatures more accurate. An 80w iron. A really nice display with a choice of Celsius or Fahrenheit. Iron sleep function of soldering iron in standby mode to avoid iron tip oxidation at high temperature. Auto or manual startup function of airflow temperature. Plus more neat stuff.
It sounds pretty good to me.
No on has any more input?
I think I’m gonna pull the trigger on this 995d from the company that makes it, Yescom. They have a store on Amazon. It’s $85 with free shipping. The best part is I can get a 4 year warranty for about $7 through Amazon. It’s hard to beat that.
I have been happy with this unit I bought 3 years ago: Soldering Rework Station with Smoke Absorber | 992DA | YiHua
Sure the pump in the base requires thicker tube (doesn’t bother me), but works also as a smoke absorber for the soldering iron => no more inhaling those nasty fumes!
I’ve been inhaling those nasty fumes for close to 50 years. Happy to say I still have half a brain…lol!
For hobby and general purpose that should be ok i guess. you dont need a brand name like JBC or Hakko which cost much more but if you cant afford it why not.
I have been using this for a year and no complain about it. bought it for $58 locally. Soldering and unsoldering MCU is a bliss instead of using soldering iron. Hot Air Rework Station with Soldering Iron | 902D | YiHua
there are two types of hot air gun though with pump in the handle and pump in the station housing.
I chose a year ago Aoyue 968A+ SMD. The AOYUE 968 multi-function hot air soldering station combines the functions of a hot air gun, soldering iron and smoke trap. The chimney system eliminates smoke that interferes with the soldering of small elements or when soldering under a microscope. Ceramic heaters allow you to achieve a quick temperature set. The control system will issue a warning in the event of a heater aging or failure. The station can be used to work with the entire spectrum of electronic components (DIP, SOIC, CHIP, QFP, BLCC, BGA, etc.). Information here Aoyue 968A+ SMD
