[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
Original OP Archive*…as compiled and maintained by TheMiller until 5 Jan 2018. The history of the GT is here. Note that not all details are valid anymore.*
The First post in this thread will have the latest updates and “change log” moving forward. This post will have the specs of the production light and the next post will have the list of those on the GB list.
Official GT support thread with all your post-purchase questions and the manual
Optional Samsung 35E are $40.50 if purchased with the GT.
Team:
Tom E: Narsil development
Texas Ace: PCB design
MRsDNF: Communication
Thijsco: CAD analyst production / design
Fritz15: CAD analyst production / design
M4DM4X: sales
Neal: contact in China well connected in flashlight world.
5AR: Original CAD design inspiration
JasonWW: Thread and information management
User manual
BLF-GT user manual draft13.pdf
(The first production run shipped with revision 12 of the manual. The revision 13 changes are minor.)
Chinese translation by steel_1024:
BLF-GT Chinese user manual V1.2
Joe’s excellent cheat sheet for the GT
Cheat sheet
NarsilM firmware development thread
NarsilM thread
NarsilM 1.2 source code and ready-to-flash HEX files
NarsilM 1.2 files
Texas Ace’s review of the final prototype before production started. Your light should look pretty much like this:
Prototype 2 review
Narmattaru’s review of the production light.
Click here
VOB’s Prototype Review video
VOB’s un-boxing video of the production light
VOB’s Using and Programming of the light
Specifications
  • Emitter:
    12 V Cree XHP35 High Intensity, neutral white 4000k, mounted on copper 44.5mm DTP MCPCB
    Flux: >2000 lm
  • Intensity:
    >1 Mcd (ANSI throw >2000 m)
  • Firmware:
    Tom E’s open-source NarsilM v1.2
  • User interface:
    • By default the GT is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 2.5 A TURBO mode is also provided.
    • A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 pre-defined mode-sets can be selected.
    • MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
  • Battery:
    Four or eight button-top 18650 cells (4S1P or 4S2P). Protected cells are recommended. Cells are not included.
  • Driver:
    35 W, 2.5 A regulated buck driver with conversion efficiency that exceeds 90%. Parasitic drain while OFF is ~150 μA (~250 μA with button back-light on).
  • Reflector:
    118 mm ID, aluminum, smooth finish
  • Lens:
    Glass with anti-reflective coating
  • Body:
    Aluminum with Type III hard-coat anodizing
  • Tripod socket:
    Standard 1/4 inch threaded (1/4-20 UNC)
  • Button:
    Tactile with back-lit rubber boot
  • Ingress rating:
    Equivalent to IP65, do not immerse in liquids
  • Weight:
    Approximately 1.8 kg without cells
  • Weights According to Hunter1
    BLF GT
    with batteries 2273 g (8 × 35E)
    tail-cap 91 g
    one battery holder 64 g (empty)
    one battery 48 g (35E)
    one battery holder 259 g (with 4 × 35E)
    two battery holder 518 g (with 8 × 35E)
    battery tube 285 g
    BLF GT head 1379 g (with screw 1381 g
  • Dimensions:
    135 mm Ø head x 310 mm length
    85mm fin OD at button
    56mm battery tube
    62mm battery cap OD
Got a reply from the NASA contractor that is using the GT for research today now that they have had some time to play with the GT, I will quote part of it it below
I would say that is an endorsement I can be proud of :smiley:
Reserved for Beam shots and pictures
From Steel_1024:
From Texas_Ace:
From Pok:
Left to right. Thrunite TN42, BLF GT, Astrolux MF02.
From JasonWW:
From 5ar:
This is not perfectly accurate, but is pretty darn close.
From Alux:
Full Size Picture of Above
reserved for Quotes of user tests and information about the GT.
Emitter tests from Maukka:
At maximum ramp level (2 amp) measured 4100K at a perfect tint of duv –0.0009.
(click for full size)
Runtimes with 4 cells only:
MRsDNF:
Talking about things happening here is a run time chart with the BLF GT proto Narsil running Two Amps at the end of ramping.
The runs were stopped when the low voltage kicked in for the first time.
(This is a battery comparison at 2A. Note that the 3500mah cells have extended run times after it falls out of regulation, blue line.)
MRsDNF:
This chart is a comparison running the BLF GT on high, the original Narsil at 2.5 amps and the proto Narsil at 2 amps. Both runs were with 30Q batteries. (This test is only about comparing 2A runtimes to 2.5A. The 2A red line stays in regulation much longer.)
Texas_Ace:
Also remember that those runtime tests are with the short tube 4 cell version, 45 mins from 4 cells before even dropping out of regulation! That is properly good.
So expect about double that from a long tube with a full 8 cells.
About 1.5 hours of full powered runtime and another ~1.5 hours before it hits LVP.
Thermal pics from Lawallac
Within a few seconds of turn on.
After running about 2 or 3 minutes.
Here is the official final list for the GT Group buy.
Use Ctrl + F in your web browser to search for your user name on the list.
It will show your name int he first row.
The second row will show how many you have signed up for and what numbers each of them were
The 3-5th rows show how many GT's you are / were approved to purchase from each set of PM's.
The 3rd set of payment PM's has not been sent out yet. Do not purchase any from that batch until you get a separate PM for it around mid-late January 2018
Also, do not use an old payment PM to purchase additional GT's above what you were approved for.
Names Request 2017-12-01 2017-12-09 Future Round
The Miller [1] 1 0 0
darkpenguin [ 2 199] 2 0 0
Mitko [3] 1 0 0
Nicolaas [4] 1 0 0
giorgoskok [ 5 98 99 100] 1 3 0
keithd [6] 1 0 0
mattlward [7] 1 0 0
Sonpham [8] 0 1 0
Dep668 [9] 1 0 0
KawiBoy1428 [ 10 193] 0 2 0
RobertB [11] 1 0 0
Keepitsharp [ 12 1679] 1 0 1
M78 [13] 1 0 0
southland [ 14 563 564 565 566] 1 4 0
Chicken Drumstick [15] 0 1 0
djburkes [16] 1 0 0
leroycp [ 17 348] 1 1 0
emarkd [18] 1 0 0
pommie [19] 1 0 0
Nicolicous [ 20 610] 1 1 0
staticx57 [ 21 1617] 1 0 1
Xandre [22] 1 0 0
Khuan [23] 1 0 0
casi29061965 [ 24 649] 1 1 0
lionheart_2281 [26] 1 0 0
Bonham [27] 1 0 0
electricjelly [ 28 1754] 1 0 1
nqcken [29] 1 0 0
Pegaso [30] 1 0 0
JamesB [31] 1 0 0
netprince [ 32 1678] 1 0 1
Caleb [33] 1 0 0
johny723 [34] 1 0 0
Gerrh [ 35 175 176 427 428] 0 5 0
Phoenix_FIN [36] 1 0 0
AlexGT [ 37 1353] 1 0 1
slow2go [ 39 423 424 1732] 1 2 1
Bribo [40] 1 0 0
Gerrit [41] 1 0 0
rvr [42] 1 0 0
Tom E [ 43 44 461] 2 1 0
aslpg [45] 0 1 0
Charga [ 46 500] 1 1 0
qandeel [ 47 475] 1 1 0
Wieselflinkpro [48] 1 0 0
G0OSE [49] 1 0 0
Abqjohnny [ 50 188] 0 2 0
g_sintornillos [ 51 1379] 1 0 1
wiestom89 [52] 1 0 0
Stittville Ed [53] 0 1 0
Pöbel [54] 1 0 0
hunter1 [ 55 1373] 1 0 1
Wrathbringer27 [56] 1 0 0
Eivwer [57] 0 1 0
fonfan [58] 1 0 0
chooma [59] 1 0 0
lawallac [ 61 1444] 1 0 1
antiparanoico [62] 0 1 0
kommessy [63] 1 0 0
Jeansy [64] 0 0 1
Box [ 65 631] 1 1 0
ImA4Wheelr [66] 1 0 0
Wineslurper [68 69] 2 0 0
gungoat [70] 1 0 0
troisanh [ 71 1509] 1 0 1
teachtom [72] 1 0 0
dodo [73] 1 0 0
cmflippen [74] 1 0 0
maukka [75] 1 0 0
warzi1975 [ 76 715 1522 1559 1623] 1 1 3
rajun50 [77] 1 0 0
ZozzV6 [78] 1 0 0
DBSAR [79] 1 0 0
zelee [80] 1 0 0
mhanlen [81] 1 0 0
LSX [82] 1 0 0
shimano3000 [83] 1 0 0
archimedes [84] 1 0 0
Pok [85] 1 0 0
Liber8 [86] 0 1 0
akoposilester [ 87 362] 1 1 0
Kozy [88] 1 0 0
chrisc [ 89 1620] 1 0 1
tzmxxhh [90] 0 1 0
albertopnp [91] 1 0 0
Tarvos [92] 1 0 0
BlindingL5s [93] 1 0 0
Mr.Scott [94] 1 0 0
Koaksijalac [95] 0 1 0
gorky [96] 1 0 0
Kurt_Norway [ 97 105 808] 1 2 0
bibihang [101] 1 0 0
hampshire [102] 0 1 0
gangstead [103] 1 0 0
strayz [ 104 1223] 0 1 1
sma [106] 1 0 0
Sledgestone [107 501] 1 1 0
samnavy [108] 1 0 0
Aardvark Spleen [109 215] 2 0 0
aggillator [110] 1 0 0
crx88ia [111] 1 0 0
A380 [112] 1 0 0
Tete [113] 1 0 0
malamask [114] 1 0 0
netgear68 [115] 1 0 0
gregor [116] 1 0 0
Smittymojo [ 117 1666] 1 0 1
MCT [118] 1 0 0
peabody [ 119 1696] 1 0 1
adnj [120 121] 0 2 0
Dwantink [122] 1 0 0
Kenjii [123] 1 0 0
cloggy [124] 0 1 0
WolfA [125] 0 1 0
Theodore41 [126] 1 0 0
CASHESVALLEY [127 396] 0 2 0
MortyDuck [128] 1 0 0
Anthon [129] 1 0 0
ISO [130 655] 1 1 0
Sciencetists [131] 1 0 0
walty [132] 0 1 0
viperbart [133] 0 1 0
Kurdolf [134] 1 0 0
Lfatman [135] 1 0 0
240 [136] 1 0 0
YoFlash [137] 1 0 0
Bruno28 [ 139 448 1577 1655] 1 1 2
derpilgerer [140] 1 0 0
puccio1969 [141] 0 1 0
Lund1660 [ 142 1596] 1 0 1
gamezawy [143] 1 0 0
Boaz [144] 0 1 0
apt323 [145] 1 0 0
Kodachrome40 [ 146 1415] 0 1 1
FlashPilot [147] 1 0 0
MorpheusT1 [149] 1 0 0
brightlights [150] 1 0 0
Dmitriyrus [151] 0 1 0
velocraig [ 152 1321] 1 0 1
crz6662 [153] 1 0 0
Kindle [ 154 1375] 1 0 1
Muto [155 156] 2 0 0
Aslan [ 158 1619] 1 0 1
Lyubo Yanev [159 160 657] 1 2 0
RocketTomato [161] 0 1 0
Modulor [162] 1 0 0
Caleb-v [163] 1 0 0
itsme5k [ 164 1722] 1 0 1
JockRobbins [165] 0 1 0
RotorHead64 [166] 1 0 0
J-Dub74 [167] 1 0 0
prisma [168] 1 0 0
theoldbill [169] 1 0 0
bjs55 [170 462] 1 1 0
Dutcheee [172] 1 0 0
westcoastwonders [173] 1 0 0
Sarge930 [174] 1 0 0
mrheosuper [177] 1 0 0
shogan [178] 1 0 0
caramba [180] 0 1 0
tmxod [181] 0 1 0
mdeni [182] 0 1 0
teacher [ 183 341 1627] 1 1 1
sb56637 [184] 0 1 0
NikolaS [185] 1 0 0
CheapThrills [186] 1 0 0
TheOnlyDocc [187] 0 1 0
HighCaliber [189] 1 0 0
e10sno [190] 1 0 0
DBSS [191 829 856] 1 2 0
thesciencenut [192] 0 1 0
jmpaul320 [194] 1 0 0
vol [195] 0 1 0
nfetterly [196] 0 1 0
niktak11 [197] 1 0 0
goshdogit [198] 1 0 0
abril [200] 1 0 0
treysoucie [202] 0 1 0
Martini [203] 0 1 0
Sirius9 [204] 1 0 0
Jesjes [205] 0 1 0
papaslightsaber [206] 1 0 0
Couchmaster [207] 1 0 0
Docp723 [208 209] 0 2 0
kotobuki [211] 1 0 0
NuggetMcNugget [212] 1 0 0
adirondackdestroyer [213] 0 1 0
spkzzz [214] 0 1 0
drood [216 596] 1 1 0
bossf350 [ 217 1454] 0 1 1
Cliwilnew [218] 1 0 0
LEDtec [219 758] 1 1 0
CJW [220] 0 1 0
deathless [221 915] 1 1 0
WillyD [222] 1 0 0
jack-bkk [223] 0 1 0
pooptoast [224] 1 0 0
LloydV [225] 1 0 0
FBsLights [226] 1 0 0
Norddeutscher [227 228] 2 0 0
slickpenguin [229] 1 0 0
Dralf [230 231] 1 1 0
jmoots [232] 1 0 0
downlinx [233] 0 1 0
Sukoi [234 454] 1 1 0
mizou51 [235] 1 0 0
sgt253 [236] 1 0 0
Buzzing Bulb [237] 1 0 0
enesrap [238] 0 0 1
BeardedRaleigh [239 356] 1 1 0
Kulumatic [240] 1 0 0
zeroair [ 241 1680] 1 0 1
JaredM [242] 1 0 0
battletross [243] 1 0 0
plaidshorts [244] 0 1 0
Nortson [245] 1 0 0
The_Driver [246] 1 0 0
Northwoods [247] 0 1 0
thslw8jg [ 248 1416] 1 0 1
knudsengj [250] 0 1 0
alex1234 [ 251 1573] 1 0 1
needmorlts [252 306] 0 2 0
MagPap [253] 1 0 0
Mindaugass [254 266] 0 2 0
light junkie [255 593 630] 0 3 0
Angel Martínez [ 256 262 400 1019] 1 0 3
DarthTader [257 888] 1 1 0
dhsvcs [258] 1 0 0
praveendk [259] 1 0 0
shirnask [260] 1 0 0
Masejoer [261] 1 0 0
666fixed [264] 1 0 0
Ricflair [267] 0 1 0
iron potato [268] 1 0 0
kntx [269] 1 0 0
DasEtwas [270] 0 1 0
Dustynell [271] 1 0 0
jkbam [272] 1 0 0
Shadowfax [273] 1 0 0
specialk [274] 1 0 0
Icarus [ 275 1701] 1 0 1
Lights-Out [276 277 282 283] 2 2 0
MaleNurse [278] 1 0 0
bd52 [279] 1 0 0
Abe87 [280] 1 0 0
osb40000 [281 440 441] 1 2 0
yclongthrow [284] 1 0 0
scdaf [285] 0 1 0
Jvrthp321 [286 394] 0 2 0
Bill_tong [287] 0 1 0
juaquin [288] 1 0 0
jama [289] 1 0 0
slackwolf [290 291 355 671] 0 4 0
noob [292] 0 1 0
FlashMax [293] 1 0 0
Frankie Baby [294] 0 1 0
kaybi [ 295 1499] 1 0 1
vestureofblood [ 296 1081 1615] 1 0 2
smokuxx1987 [297 753] 1 1 0
Jimmy007 [298] 1 0 0
jerrod [299] 1 0 0
amplificus [300 503] 1 1 0
DarkerInSol [301 302] 1 1 0
thommy [303] 1 0 0
Majoroverkill [304] 1 0 0
Jaza [ 305 1618] 1 0 1
rag [307] 0 1 0
aremihc [308] 1 0 0
Fredylee [309] 0 1 0
twodollarbill [ 310 1654] 1 0 1
PrinceValorum [311] 1 0 0
steel_1024 [ 312 1043] 1 1 0
magnet [314] 1 0 0
jscan [315] 1 0 0
LessDark [316] 0 1 0
Roberrt777 [317] 0 1 0
tru3s1lv3r [319] 1 0 0
NightLight [320] 1 0 0
shrick [321 322] 2 0 0
eric800 [323] 0 1 0
TNT [324] 0 1 0
gloomywarfreak [325] 1 0 0
Saigon [326] 0 1 0
carmantl [ 327 521 1691] 1 1 1
san san [328] 1 0 0
BanglaBob [329] 1 0 0
saabluster [330] 0 1 0
moridin [332] 1 0 0
whooda4 [333 391] 1 1 0
yasenf [334 725 840 885 979] 1 4 0
R.D. [335] 1 0 0
Schkü [336] 1 0 0
Van [337] 1 0 0
marsalla [338] 1 0 0
itsonlyme [339] 0 1 0
gravelmonkey [ 340 1501] 2 0 0
lightlight22 [ 342 1743] 1 0 1
Bupyc [343] 1 0 0
Mkduffer [344] 1 0 0
thegameisrigged [345] 1 0 0
vamper [346 699] 1 1 0
BOMBAY [347] 1 0 0
KW [349] 1 0 0
Lopan [350] 1 0 0
firedome [351] 0 1 0
AirBreaker [352] 0 1 0
Eraursls1984 [353] 1 0 0
jingleberry [354] 0 1 0
Mecallie [357] 1 0 0
cavorite [358] 0 1 0
foton [359] 0 1 0
JPLight [360 361] 1 1 0
borealis [363] 1 0 0
jaynick [364] 1 0 0
Shur [365] 1 0 0
Kourtinoksylo [366] 0 1 0
mrstealyourgains [367] 1 0 0
Jalben [368] 1 0 0
james y [ 369 1725] 1 0 1
Sullysat [370] 1 0 0
Joey Adams [371] 1 0 0
j0sh [374] 1 0 0
FreeMagenta [375] 1 0 0
zeremefico [ 376 1646] 1 0 1
deye223 [377] 0 1 0
turboBB [379] 1 0 0
nodoubt [380 383 894] 0 3 0
korpzgrinda [381] 1 0 0
famous36 [382] 0 1 0
Eggun [384] 1 0 0
Speed4goal [385] 0 1 0
ARsee [386 473] 1 1 0
Zeratull [387] 1 0 0
blueb8llz [389 390] 1 1 0
Umpi2000 [392] 1 0 0
bkling [393] 0 1 0
zipelgas [395] 1 0 0
tatasal [397] 1 0 0
trume_3454 [398] 1 0 0
igeigeige [399] 0 1 0
Ronen98 [401] 0 1 0
wkhchin81 [402] 1 0 0
gigbyt [403] 1 0 0
AdrianWA [405 416] 1 1 0
Flash-O-Maniac [406] 1 0 0
fuzun [407 685] 0 2 0
xray291 [408 608] 1 1 0
ilovejesuschrist [409] 0 1 0
greg [410] 1 0 0
octav [411] 1 0 0
keengeorge [412 413] 1 1 0
Yourrid [414] 1 0 0
turpulator [417] 1 0 0
BT100 [ 418 485 862 1322] 1 2 1
viper1138 [419] 1 0 0
joseabul [420] 1 0 0
romanus [421] 0 1 0
Rick [422] 0 0 1
DOCFAR [425] 1 0 0
pepinfaxera [426] 1 0 0
Kafar [429] 0 1 0
mk4off [431] 0 1 0
KaiserSosa [ 432 1656] 1 0 1
Ilellero [433] 0 1 0
Silent_Star [434] 1 0 0
southcovekayak [435] 0 1 0
Bo4ka [ 436 571 1625] 1 1 1
Keisari [437] 1 0 0
Jensa41 [438] 1 0 0
piotrek966 [ 439 1510] 1 0 1
Slayer1 [442 469] 1 1 0
nofear87 [443] 0 1 0
clinicdoc [444] 1 0 0
samsung913 [445] 1 0 0
Pulsar [446] 1 0 0
lichtpfadfinder [447] 1 0 0
cypher1024 [ 449 704 1474] 1 1 1
shooterschmidty [450] 1 0 0
solRNY [452 620] 1 1 0
gehrmo [455] 0 1 0
I_like_lamb [457] 1 0 0
Jerommel [458] 1 0 0
Stoneface [459] 1 0 0
scotlarock [460] 1 0 0
BobbyMK [463] 1 0 0
Buzzy243 [464] 1 0 0
djozz [465] 1 0 0
michael.k [466] 1 0 0
BDM [467] 1 0 0
BorisBar [468] 1 0 0
ARMS.AARON [470] 1 0 0
CrashOne [471] 1 0 0
sp5it [472] 1 0 0
olivedrab [474] 0 1 0
nnmnu1 [476] 1 0 0
MBuitendorp [477] 1 0 0
Essexman [478] 1 0 0
xCentrino [479] 1 0 0
Awdtsi [480] 0 1 0
scianiac [481] 1 0 0
Mikael [482 555] 1 1 0
abhinit90 [483] 1 0 0
Dydi92 [ 484 1758] 1 0 1
The_crx [486] 1 0 0
Kalihi [487] 1 0 0
sac02 [488] 1 0 0
noetik [489] 1 0 0
freeme [490] 0 1 0
Ag76 [491] 1 0 0
ClaudeMBallz [492] 1 0 0
IndyArcher [ 493 1450] 1 0 1
techieman33 [494] 1 0 0
Tjhosan [495] 0 1 0
bella-headlight [ 496 1093] 1 0 1
Texas_Ace [497 498] 1 1 0
l1mb0 [499] 1 0 0
optntdr13 [502] 1 0 0
ChibiM [504] 1 0 0
Morgy [505] 1 0 0
pscal [507] 1 0 0
X0R [508] 1 0 0
shan6oob [509] 1 0 0
chokobo [510] 0 1 0
zachary6227 [511] 1 0 0
zoysiamo [512] 1 0 0
macktastic [513] 1 0 0
darthmater [514] 1 0 0
mstephens22 [515] 0 1 0
Joat [516] 1 0 0
DJUnreal [517] 1 0 0
Kit Latura [518] 1 0 0
Walker Klondike [519] 1 0 0
MACS0647 [520] 1 0 0
jescereal [522 523] 1 1 0
Randolph [524] 1 0 0
clange50 [526] 1 0 0
Innerlight [527] 1 0 0
Curetia [528] 1 0 0
amaretto [529] 0 1 0
tonylim [ 530 1716] 1 0 1
Flanny [531] 1 0 0
TechnOMatriX [532] 1 0 0
Hundelampe [533] 0 1 0
koyotee [ 534 1647] 1 0 1
Guns712 [535] 1 0 0
unit311 [536] 1 0 0
Duke [537] 1 0 0
Modden [538] 1 0 0
Maiden666 [539] 1 0 0
tomas.hrubovcak [ 540 1206] 1 0 1
wapd2 [541] 1 0 0
xtrosity [542] 1 0 0
WuTang [543] 1 0 0
Oal [544] 1 0 0
flaschi [545] 1 0 0
samis [546] 1 0 0
FrankFlash [547] 1 0 0
nitrader0 [548] 1 0 0
Sonofspectrum [549] 1 0 0
MountainMan [550] 1 0 0
krutone [551] 0 1 0
heatwaves [552] 1 0 0
adsum [553] 1 0 0
Phantom1 [554 575] 1 1 0
WaylonJennings [ 556 1374] 1 0 1
DiscoJoe [557] 1 0 0
Ilmatic [558] 1 0 0
Lipfit2000 [559] 1 0 0
JM87 [ 560 1459] 1 0 1
patmet [561] 1 0 0
DOHC20 [562] 1 0 0
asnidi2 [567] 1 0 0
Suncoaster [568] 1 0 0
jimmy23 [569] 1 0 0
kevinfc [570] 0 1 0
Swennie [572] 0 1 0
Franz [573] 1 0 0
xxx [574] 1 0 0
R10500 [576 646] 1 1 0
StarCity [577] 1 0 0
polarweis [578] 1 0 0
Nathan42 [579] 1 0 0
ColdFusion [580] 1 0 0
Rxich [581] 1 0 0
Crazyeddie [582] 1 0 0
SteveMidwest [583] 1 0 0
jerrytx [584] 1 0 0
Bozlight29 [ 585 1516] 1 0 1
vinte77 [586] 0 1 0
mezzmen7 [587] 1 0 0
darrenm [588] 1 0 0
Henk4U2 [589] 1 0 0
maildroid [ 590 1378] 1 0 1
joel95ex [591] 1 0 0
ant0 [592] 0 1 0
light up [594] 1 0 0
spotlighter [595] 1 0 0
Megabassie [597] 1 0 0
Manimok [598] 1 0 0
pleply [599] 1 0 0
pilotdog68 [600] 1 0 0
D10ten [601] 1 0 0
Jeffstanton [602] 0 1 0
Natasha [603] 1 0 0
johnjohn [604] 1 0 0
BrianK [605 727] 1 1 0
martook [606] 1 0 0
Wennn [ 607 1708] 1 0 1
JayWallis [ 609 1503] 1 0 1
bwl123 [611] 0 1 0
dsiddens [612] 1 0 0
wilwok [ 613 1397] 1 0 1
rizky_p [614 640] 1 1 0
dentillozie [615] 0 1 0
fed893 [616] 1 0 0
PabloVerde [617] 1 0 0
Terry White [618 619] 1 1 0
Gj [ 621 1361 1445 1668 1669] 1 0 4
Geese [622] 1 0 0
Dregs [623] 0 1 0
byarnell05 [ 624 1462] 1 0 1
Offgridled [625] 1 0 0
Edness [ 626 1737] 0 1 1
geepaw [627] 1 0 0
Newlumen [628] 1 0 0
Nguyen [629] 1 0 0
flybird [ 632 1698] 1 0 1
leaftye [633] 1 0 0
gleamer [634] 0 1 0
MAD777 [635] 1 0 0
chops728 [636] 1 0 0
eekazum [637 707 708] 1 2 0
Sky [638 759] 1 1 0
Lone Eagle [639] 1 0 0
Ozythemandias [ 641 1717] 1 0 1
suratyu [642] 1 0 0
wimmer2121 [643] 1 0 0
jack83 [644] 1 0 0
pirate joe 22 [ 645 653 1190] 0 2 1
XXX-Man [ 647 1645] 1 0 1
unknown00101 [ 648 1399 1400] 1 0 2
KuanR [650] 0 1 0
Yokiamy [651] 1 0 0
tmx009 [652] 1 0 0
tino79 [654] 1 0 0
M3L8BQMjr2m [656] 1 0 0
bobdotorg [658 659] 1 1 0
NotSure [660] 0 1 0
Epsilon748 [661] 1 0 0
w4rkry [ 662 1119] 1 0 1
GroinOfSteel [663] 1 0 0
Dadpool [664] 1 0 0
bdm82 [665] 1 0 0
Hezekiah [666] 1 0 0
wolfstyle [667] 1 0 0
will34 [668] 0 1 0
digitalMessiah [669] 1 0 0
JJMcGee83 [670] 1 0 0
what_are_birds [672] 1 0 0
Nine9n1ne [673] 1 0 0
AppA [674] 1 0 0
T18 [675 676] 1 1 0
zortan [679] 1 0 0
JorisFRST [680 825] 1 1 0
patmurris [ 681 1672] 1 0 1
TheLonelyLumen [682] 1 0 0
boostedsubie [683] 1 0 0
pelle470 [684] 1 0 0
chasm22 [686] 1 0 0
srwaite [687] 1 0 0
Mr.Poppy [688 745 746 871 872] 1 4 0
KnifeNutsJake [689] 1 0 0
GameOfDeath [690] 1 0 0
Tuigali [691] 1 0 0
lelantosthrow [692] 0 1 0
Evo1986 [693] 1 0 0
Alux [694] 1 0 0
bigrick [695] 1 0 0
prepro [696] 1 0 0
Tally-ho [ 697 1370] 1 0 1
TorinoFermic [698] 1 0 0
cccpull [700] 1 0 0
MRsDNF [ 701 1020] 1 1 0
jatle [702] 1 0 0
Cawi [703] 1 0 0
JIGHEADWORM [705] 1 0 0
davidkappelt [706] 1 0 0
Svensk [709] 0 1 0
drjamesfox [710] 1 0 0
WestBam [711] 1 0 0
flasky [712] 1 0 0
st33lboy [713] 1 0 0
terry b [714] 0 1 0
Hardware [716] 1 0 0
SamHaLeKe [717] 1 0 0
Turningbluechips [ 718 1546] 1 0 1
Gladimir_Gluten [719] 1 0 0
zifzif [720] 1 0 0
mjgsxr [721] 1 0 0
arditty [722] 1 0 0
b1i1l1l1y1 [723] 1 0 0
harty73 [724] 1 0 0
DooMMasteR [726] 1 0 0
djypo [728] 1 0 0
FmC [ 729 1556] 1 0 1
nordlicht [730 731] 1 1 0
Luminental [ 732 1138] 1 0 1
nydude [733] 0 1 0
Itsme [ 734 1343] 1 0 1
ElginAgain [735] 1 0 0
jsmn4vu [736] 1 0 0
tkmckay [737] 1 0 0
Nickke [738] 1 0 0
illusum [739] 1 0 0
Bdubelyew [740] 1 0 0
Myers [741] 1 0 0
SubSailorVet [742] 1 0 0
xertian [743] 1 0 0
manxbuggy1 [744 785] 1 1 0
twoleftfeet [747] 1 0 0
martytown [748] 1 0 0
SteelyPhil88 [749] 1 0 0
airack [750] 1 0 0
lightknot [751] 1 0 0
fantomR [752] 1 0 0
Dewalt101 [ 754 1677] 1 0 1
LandoLakes [755] 1 0 0
candor [ 756 1389] 1 0 1
Ssthis [757] 1 0 0
Rah_BE [760] 1 0 0
Litefighter [761] 1 0 0
Tclementi1 [762] 1 0 0
Bbop [763] 0 1 0
Captain_Joe [764] 1 0 0
Pablogy [765] 1 0 0
cressdrvr [766] 0 1 0
square74 [767] 0 1 0
ErrolRS [768] 1 0 0
Boldo [769] 1 0 0
nitro [770 770] 1 1 0
Tender [771] 0 1 0
Nnugkcin [772] 0 1 0
Gunslinger686 [773 774] 0 2 0
DeepCCoug [775] 0 1 0
WillBeatz [776] 0 1 0
Marcello [777] 0 1 0
ledalex [778] 0 1 0
mickscott [ 779 1355] 0 2 0
mickscot [780] 0 0 1
Blenman37 [781 782] 0 2 0
jtedder1967 [783 987] 0 2 0
wishiwereaskibum [784] 0 1 0
theanghv [786] 0 1 0
LuminousIgnis [ 787 1707] 0 1 1
Hombreluhrs [788 789] 0 2 0
jamaya [790 909] 0 2 0
backup41 [791] 0 1 0
Cutchya [ 792 793 1470] 0 2 1
PabstyLoudmouth [794 950] 0 2 0
Superslicknick [795] 0 1 0
blampen [796 861] 0 2 0
Nichia [797] 0 1 0
TheConsultant [798] 0 1 0
gyros-pita [799] 0 1 0
JPM3 [ 800 1558] 0 1 1
izkidd [801 802] 0 2 0
blackbalsam [803 932] 0 2 0
NCled [804] 0 1 0
mattardel [805] 0 1 0
Kdoggy94 [806] 0 1 0
octopus7750 [807] 0 1 0
dummytim [809] 0 1 0
Narwhals [810] 0 1 0
inphinity [811] 0 1 0
cheesecheeks [812] 0 1 0
DoNkEyConN [ 813 826 1703] 0 2 1
Patriot36 [814] 0 1 0
BigTrout [815] 0 1 0
1C3 MAN [816] 0 1 0
EDCPlus [817] 0 1 0
BVH [ 818 819 886 1526 1527 1528] 0 3 3
anitasanger [820] 0 1 0
rpscuba [821] 0 1 0
dmsoule [ 822 1653] 0 1 1
Glenn7 [823] 0 1 0
Calmaja [824] 0 1 0
Seelevel [827] 0 1 0
RapidLux [828] 0 1 0
Rossano95 [830] 0 1 0
Tom_182 [831] 0 1 0
rejsr [832] 0 1 0
LenZ [833 834] 0 2 0
Britlightbruce [835] 0 1 0
Tdh66 [836] 0 1 0
jveneziano [ 837 1102] 0 1 1
JasonB1993 [838] 0 1 0
BLFBob [839] 0 1 0
ReManG [841] 0 1 0
cellguy [842 843] 0 2 0
justanotherguy [ 844 1409] 0 1 1
Subiext73 [845] 0 1 0
Light Years [846] 0 1 0
AmericanEDC [ 847 1670] 0 1 1
BEARS ARE PEOPLE TOO [848] 0 1 0
TitaniumLight [849] 0 1 0
PickleFuzz [850] 0 1 0
Brett [851] 0 1 0
flasher96 [852] 0 1 0
caddylover [853] 0 1 0
slimkango [854] 0 1 0
Brian Metcalfe [855] 0 1 0
ConcreteTurtle [857] 0 1 0
ryanferg [858] 0 1 0
keithober [859] 0 1 0
schlichtie [860] 0 1 0
Coughitup [863] 0 1 0
jtechl [864] 0 1 0
Mongoose49 [865] 0 1 0
beanhill911 [ 866 1302] 0 1 1
BigusLightus [867] 0 1 0
adamshoward [868] 0 1 0
Minty [869 870] 0 2 0
bogdanr [873] 0 1 0
ersecu [874] 0 1 0
Archangel72 [875] 0 1 0
sledge0816 [876] 0 1 0
caelanseth [877 878] 0 2 0
lcortez321 [879] 0 1 0
Sycamore [880] 0 1 0
shanefletch [ 881 1652] 0 1 1
Hardusvd70 [882 891 897 927] 0 4 0
biczownia [883 884] 0 2 0
FritzHID [887] 0 1 0
juddvong [889] 0 1 0
gastonpatagonico [890] 0 1 0
flashlightfrenzy [892 893] 0 2 0
DENGOH [ 895 1402 1616] 0 1 2
shakeym [896] 0 1 0
crackrat [898] 0 1 0
BingoThink [899] 0 1 0
Lamboboy732 [900] 0 1 0
OneLumen [901 902 903] 0 3 0
SampleSizeOne [904 905] 0 2 0
05131996 [906] 0 1 0
species8472 [ 907 1235] 0 1 1
donnieol [908] 0 1 0
egrep [ 910 1723] 0 1 1
froz [911] 0 1 0
JasonWW [912] 0 1 0
EagleShield [913] 0 1 0
Jmiddlebrook [914] 0 1 0
blgrssby [916] 0 1 0
turgid_fervor [917] 0 1 0
Mapster [918] 0 1 0
Samuel AUDIBERT [919] 0 1 0
Toppe [920] 0 1 0
AngryFish [921] 0 1 0
Kkelleher [922 923] 0 2 0
wstrachan [924] 0 1 0
nvanlaar [925] 0 1 0
CodyWolfeMusic [926] 0 1 0
robertglenanderton [928] 0 1 0
rebuswind [929] 0 1 0
777 [930] 0 1 0
fuzzyvader [931] 0 1 0
kyleharleyanderton [933] 0 1 0
makapuu [934] 0 1 0
Ben_Varney [935] 0 1 0
BobTB [ 936 1420] 0 1 1
Caseit741 [937] 0 1 0
dariman3 [ 938 1662] 0 1 1
mugs [939] 0 1 0
Marcopolo86c [940] 0 1 0
Threadneedle [941] 0 1 0
Xombie86 [942 951] 0 2 0
ashwally [ 943 1502] 0 1 1
erick_151 [944] 0 1 0
VRT [945] 0 1 0
Asmartik [946] 0 1 0
Far Thrower [ 947 1443] 0 1 1
Yammie [948] 0 1 0
Knox8992 [949] 0 1 0
MarkoNW [952] 0 1 0
HughQ [953] 0 1 0
sybersonix [954] 0 1 0
KlementinSwede [955] 0 1 0
Prodeje79 [956] 0 1 0
Hayseed [957] 0 1 0
michaellee64 [958] 0 1 0
yenkoz [959] 0 1 0
Maliblue [960] 0 1 0
mattyd58 [961] 0 1 0
bking [962] 0 1 0
Mattfox27 [963 985] 0 2 0
Sundance [964] 0 1 0
Pasakulu [965 966] 0 2 0
vonuscyg [967 986] 0 2 0
ILIKEFLASHLIGHTS [968] 0 1 0
Yanlee13 [969] 0 1 0
possumwater [970] 0 1 0
Cranky64 [971] 0 1 0
Jouna [972] 0 1 0
Flying Luminosity [973] 0 1 0
jturn480 [974] 0 1 0
Johny [975] 0 1 0
Shelf Queen [976] 0 1 0
dukeface13 [977] 0 1 0
mrod67 [ 978 1667] 0 1 1
alejandrov [980] 0 1 0
kahvitahra [981] 0 1 0
GlinnDamar [982] 0 1 0
rick1944 [983] 0 1 0
Ares1744 [984] 0 1 0
Jkatalik4 [988] 0 1 0
dimitris [989] 0 1 0
kebal_omega [990] 0 1 0
BrianV [ 991 1014] 0 2 0
hikearound [ 992 1001] 0 2 0
JonnyC [ 993 1131] 0 1 1
Rat [994] 0 1 0
OldSee [995] 0 1 0
Mastorakos [996] 0 1 0
SPAMBOT [997] 0 1 0
CCl3NO2 [998] 0 1 0
COWBOY306 [ 999 1000] 0 2 0
Dannyboyy [1002 1003] 0 2 0
Wedgetarian [1004] 0 1 0
Blane [1005 1053] 0 1 1
Neomis [1006] 0 1 0
Greener [1007] 0 1 0
Paladinaus [1008 1525] 0 1 1
Jarms [1009 1010] 0 2 0
IronManMosier [1011 1012] 0 2 0
Arildb [1013] 0 1 0
Plan-B [1015] 0 1 0
Jorgen [1016 1017 1612 1613] 0 2 2
220daniel [1018] 0 1 0
malcolmb [1021] 0 1 0
F.i.l.a.s [1022] 0 1 0
R-Lo [1023 1024] 0 2 0
charnchai [1025] 0 1 0
offroadatnite [1026 1045 1452 1453] 0 2 2
JanS [1027] 0 1 0
Count Zero [1028] 0 1 0
Greenterror2112 [1029] 0 1 0
Seeker1 [1030] 0 1 0
Hemietr06 [1031] 0 1 0
tommydadog [1032 1033 1398] 0 2 1
Andreiw210 [1034 1035] 0 2 0
travis a [1036] 0 1 0
Tombird83 [1037] 0 1 0
ZempOh [1038 1039] 0 1 1
D-DUB [1040] 0 1 0
xseven [1041] 0 1 0
SCNole [1042 1542] 0 1 1
recumbent [1044] 0 1 0
oolong [1046] 0 1 0
GrumpyCoffee [1047] 0 1 0
Mallow [1048] 0 1 0
Kingjohn [1049 1338] 0 1 1
mradeck [1050] 0 0 1
proq [1051] 0 0 1
kml1987 [1052] 0 0 1
I73770k [1054] 0 0 1
freethink [1055] 0 0 1
Viking 3XL [1056] 0 0 1
TreyGhost252 [1057] 0 0 1
Swordfish [1058] 0 0 1
seben [1059] 0 0 1
amorph [1060 1671] 0 0 2
bgondee [1061] 0 0 1
Garfield189 [1062] 0 0 1
Flybar [1063] 0 0 1
no1muzzy [1064] 0 0 1
fusion_m8 [1065] 0 0 1
uqs1000 [1067] 0 0 1
Frost1235 [1068] 0 0 1
r1derbike [1069] 0 0 1
Zweemil [1070] 0 0 1
podo [1071 1072] 0 0 2
henningap [1073] 0 0 1
Perdu [1074] 0 0 1
Darkestarc [1075] 0 0 1
GHOSTSS [1076 1077] 0 0 2
Revarious [1078] 0 0 1
Alamo [1079 1080] 0 0 2
Giovanni Delle Foglie [1082] 0 0 1
degringolader [1083 1328 1329] 0 0 3
patchman [1084] 0 0 1
moomoosan [1085] 0 0 1
fluffman86 [1086 1432] 0 0 2
Khameleon [1087] 0 0 1
Pugna [1088] 0 0 1
BlackAdder [1089] 0 0 1
pmtech [1090] 0 0 1
strongtower1 [1091] 0 0 1
Attackhorse [1092] 0 0 1
thnxtank [1094] 0 0 1
ZMANZ71 [1095] 0 0 1
MRDOOLEY [1096] 0 0 1
KCSmith [1097] 0 0 1
RockHugger [1098] 0 0 1
gtxxl [1099] 0 0 1
sandro [1100 1101] 0 0 2
Andy sto [1103] 0 0 1
k125bw [1104 1441] 0 0 2
nbjly [1105] 0 0 1
Oh it is [1106] 0 0 1
sebastiang [1107] 0 0 1
eigenmeat [1108] 0 0 1
Birddog [1109] 0 0 1
ShadowMerchant [1110] 0 0 1
congo [1111] 0 0 1
Scope17 [1112] 0 0 1
Mops1 [1113 1437] 0 0 2
Subwoofers [1114] 0 0 1
Bhevo47 [1115] 0 0 1
Sniper [1116] 0 0 1
Aimi92 [1117] 0 0 1
Syncronisator [1118] 0 0 1
Precision777 [1120] 0 0 1
scannerguy1968 [1121] 0 0 1
ML1 [1122] 0 0 1
lumenhunter [1123] 0 0 1
cardman625 [1124] 0 0 1
moretorque05 [1125] 0 0 1
Rarrar [1126] 0 0 1
rsac [1127 1252] 0 0 2
Dragonatorrr [1128] 0 0 1
Mord_Fustang [1129] 0 0 1
gman7228 [1130] 0 0 1
PVCC [1132 1395] 0 0 2
Kbdrake07 [1133] 0 0 1
Teknofiliak [1134] 0 0 1
Elephant007 [1135] 0 0 1
Toppel [1136] 0 0 1
BigBird [1137] 0 0 1
mazda96hatch [1139] 0 0 1
flinders_72 [1140] 0 0 1
krazypoloc [1141] 0 0 1
Mr McLumen [1142 1279] 0 0 2
Kjosn [1143] 0 0 1
Glov [1144] 0 0 1
Larryd888 [1145 1146 1147] 0 0 3
dstuhr [1148] 0 0 1
Hugh Johnson [1149] 0 0 1
Robert007 [1150 1151] 0 0 2
hoekjor [1152] 0 0 1
darowi [1153] 0 0 1
koenigsegg [1154] 0 0 1
h5550 [1155] 0 0 1
Buttkicker [1156] 0 0 1
solsol [1157] 0 0 1
basslovin808 [1158] 0 0 1
Youville [1159] 0 0 1
chaswolf [1160] 0 0 1
budman [1161] 0 0 1
JAthe1ST [1162] 0 0 1
Qwibbles [1163] 0 0 1
TeeZocker [1164] 0 0 1
ArmedRN [1165 1173] 0 0 2
hazG [1166] 0 0 1
jazzyone1212 [1167] 0 0 1
Blazer296 [1168 1429] 0 0 2
Transient [1169] 0 0 1
a_idiot [1170] 0 0 1
donttellmywifeiambuyinganotherlight [1171] 0 0 1
BoxCarWillie [1172 1360] 0 0 2
Peter Wijono [1174] 0 0 1
torqu3e [1175] 0 0 1
MartWilliams [1176] 0 0 1
squidaudio6872 [1177 1178] 0 0 2
mphlorin [1179] 0 0 1
fonLED [1180] 0 0 1
Falconda [1181] 0 0 1
sunfire [1182 1576] 0 0 2
Warenzevon [1183] 0 0 1
Illuminati [1184] 0 0 1
blf-mode [1185] 0 0 1
hron61 [1186 1575] 0 0 2
dunklerfox [1187] 0 0 1
Nav88 [1188] 0 0 1
Xenovora [1189] 0 0 1
Aussi [1191] 0 0 1
Giancarlo [1192 1555] 0 0 2
cj_86 [1193] 0 0 1
Dennis Bieniek [1194] 0 0 1
vex_zg [1195] 0 0 1
IH8MYX [1196] 0 0 1
SG3 [1197] 0 0 1
mxyzptlk [1198] 0 0 1
dthrckt [1199] 0 0 1
tucsonmike [1200] 0 0 1
Kemikos [1201] 0 0 1
renegade87 [1202] 0 0 1
istrayli [1203] 0 0 1
Hovsky [1204] 0 0 1
Chasealmighty [1205 1512] 0 0 2
SirMehsAlot [1207 1391] 0 0 2
spade413 [1208] 0 0 1
Plat [1209] 0 0 1
Kendo [1210] 0 0 1
jtq [1211] 0 0 1
Fighterplane1956 [1212 1213] 0 0 2
csteene [1214 1371] 0 0 2
ammofox [1215 1216 1762] 0 0 3
meti [1217] 0 0 1
Oborowatabinost [1218] 0 0 1
ViperAUG [1219] 0 0 1
Delta_Frog [1220] 0 0 1
Romey310 [1221] 0 0 1
Oamaruvian [1222] 0 0 1
weklund [1224] 0 0 1
texmaster [1225] 0 0 1
BC4Lyphe [1226] 0 0 1
Sabowan [1227] 0 0 1
elrcpilot [1228] 0 0 1
NorthCentralPos… [1229] 0 0 1
cheffernan [1230] 0 0 1
validum [1231] 0 0 1
christoph [1232 1315] 0 0 2
Kasi55 [1233] 0 0 1
bigm [1234] 0 0 1
JesperW [1236] 0 0 1
Yousir [1237] 0 0 1
derbi [1238] 0 0 1
mgorshe95 [1239 1240 1362] 0 0 3
Metallurgist [1241] 0 0 1
Patuperkel [1242] 0 0 1
DELLBERTS [1243] 0 0 1
celler [1244] 0 0 1
Badhombre [1245] 0 0 1
DisLilLiteOfMine [1246] 0 0 1
mtsuther [1247] 0 0 1
DTS Savannah [1248 1249] 0 0 2
JPG [1250] 0 0 1
khr [1251] 0 0 1
SteveRocks [1253] 0 0 1
OKCOREY [1254] 0 0 1
Flusher [1255] 0 0 1
comeintothelight [1256] 0 0 1
Billy X [1257] 0 0 1
notn41 [1258] 0 0 1
Patt [1259] 0 0 1
steve404 [1260] 0 0 1
druidmars [1261] 0 0 1
The Swabian [1262] 0 0 1
aoakeson [1263] 0 0 1
stayintheshadows [1264 1748] 0 0 2
NLivsey [1265] 0 0 1
fberna [1266] 0 0 1
somnambulism [1268] 0 0 1
Moelns12 [1269] 0 0 1
alifpb98 [1270] 0 0 1
feilox [1271] 0 0 1
lennshow66 [1272] 0 0 1
phoenixphil [1273 1274 1275] 0 0 3
td1042k [1276] 0 0 1
Mustang90 [1277] 0 0 1
Schlaucher [1278] 0 0 1
northbeard [1280] 0 0 1
Jryeping [1281] 0 0 1
Tomogchi [1282] 0 0 1
sulaco [1283] 0 0 1
Fjrjim [1284] 0 0 1
Iktinos [1285] 0 0 1
surasakkongtha [1286] 0 0 1
Don.valk [1287] 0 0 1
HAWK [1288] 0 0 1
spacemanspliff [1289] 0 0 1
Bad_Reaction [1290] 0 0 1
JohnCalvin [1291] 0 0 1
Coyotehawk [1292 1293 1294] 0 0 3
KOSTA88 [1295 1296] 0 0 2
Krisz1100 [1297 1324] 0 0 2
JLM86 [1298] 0 0 1
Prairie-oysters [1299] 0 0 1
Asbestos [1300] 0 0 1
Gerald Wright [1301 1511] 0 0 2
Maggats2 [1303 1388] 0 0 2
hardlybowing [1304] 0 0 1
feetball [1305] 0 0 1
gtaguy235 [1306] 0 0 1
Flashalot111 [1307] 0 0 1
apartlow [1308] 0 0 1
uncleJ [1309] 0 0 1
Nev [1310 1611] 0 0 2
nick91900 [1311] 0 0 1
mazer0001 [1312] 0 0 1
Noopjl [1313] 0 0 1
rsmith7226 [1314] 0 0 1
muthagoose [1316] 0 0 1
pcctex [1317] 0 0 1
Wekr [1318] 0 0 1
Nocturnel [1319] 0 0 1
Natasha Bernardo [1320] 0 0 1
okreddirt [1323] 0 0 1
williamscott999 [1325 1326 1327] 0 0 3
Rj2 [1330] 0 0 1
ManWithoutShadow [1331] 0 0 1
Chito [1332] 0 0 1
Tredd [1333] 0 0 1
Rokypop [1334] 0 0 1
FHAREN [1335] 0 0 1
Casper2000 [1336] 0 0 1
Touchofred [1337] 0 0 1
fabiomars [1339] 0 0 1
mgracia85 [1340] 0 0 1
Mwsilverado09 [1341] 0 0 1
dabaum_85 [1342] 0 0 1
Boschlite [1344] 0 0 1
10fold [1345] 0 0 1
torchmanSp1111 [1346 1682] 0 0 2
338LM [1347 1348 1349] 0 0 3
MikeH [1350] 0 0 1
Hootbubba [1351] 0 0 1
O26Rcr [1352 1586] 0 0 2
Gwest [1354 1446] 0 0 2
RT— [1356] 0 0 1
Skookmb [1357] 0 0 1
Flasher2 [1358] 0 0 1
JETMOTO21 [1359] 0 0 1
The Groundsman [1363] 0 0 1
pete21 [1364] 0 0 1
Billcosbysplug [1365] 0 0 1
quijibo [1366 1367 1368] 0 0 3
Quickstrike2 [1369] 0 0 1
morning_wood [1372 1628] 0 0 2
Shawnlayman25 [1376] 0 0 1
GozonM [1377] 0 0 1
King201002 [1380] 0 0 1
Pocket Torch [1381] 0 0 1
orbitalforest [1382] 0 0 1
Biffe-22 [1383 1384] 0 0 2
wintermute76 [1385] 0 0 1
DeadSquirrely [1386] 0 0 1
dougjones31 [1387] 0 0 1
cgcollege [1390] 0 0 1
mmalive [1392 1517] 0 0 2
azj [1393] 0 0 1
Th8tredude [1394] 0 0 1
rhburke [1396] 0 0 1
GF357 [1401] 0 0 1
Superspprt327 [1403] 0 0 1
phunqe [1404] 0 0 1
Robosaur [1405] 0 0 1
xanderolo [1406] 0 0 1
Marvin8 [1407] 0 0 1
cittroman [1408] 0 0 1
Hoosierrunner [1410] 0 0 1
DIPSTIX [1411] 0 0 1
xcpilot [1412] 0 0 1
ulfm1 [1413] 0 0 1
CYRIL [1414] 0 0 1
RsquaRed [1417] 0 0 1
uwould [1418] 0 0 1
funkycowboy [1419] 0 0 1
SILIWANGIPARAHYANGAN [1421] 0 0 1
Total Package [1422] 0 0 1
Myrdden [1423 1424 1471] 0 0 3
Suxelebut [1425] 0 0 1
Pssymon [1426] 0 0 1
Mike9028 [1427 1763] 0 0 2
Juusto [1428] 0 0 1
GoMeR [1430 1461] 0 0 2
Mt.B [1431] 0 0 1
Lepricahn1955 [1433] 0 0 1
psinha [1434] 0 0 1
breenommy [1435 1436] 0 0 2
jmm244 [1438] 0 0 1
Hiperdart [1439] 0 0 1
albertosm [1440] 0 0 1
Promio [1442] 0 0 1
ohbreeeezy [1447] 0 0 1
riggz [1448 1449] 0 0 2
Scavman [1451] 0 0 1
Rozzy [1455] 0 0 1
Hunter29078 [1456 1457] 0 0 2
Clovis Point [1458] 0 0 1
tanaka- [1460] 0 0 1
evgen2004 [1463] 0 0 1
chrispc [1464] 0 0 1
KayakMikeP [1465] 0 0 1
orbit308 [1466] 0 0 1
Nooner [1467] 0 0 1
Fred Fortney [1468] 0 0 1
hippotomato [1469 1663] 0 0 2
cerberos [1472] 0 0 1
m000 [1473] 0 0 1
delight [1475] 0 0 1
Papalumen [1476] 0 0 1
RoloFresh [1477] 0 0 1
bk1020 [1478] 0 0 1
akawaterman [1479] 0 0 1
DriftMonkey206 [1480] 0 0 1
BadGround [1481] 0 0 1
ohhhtravis [1482] 0 0 1
angler1088 [1483] 0 0 1
JOHN PYRAMID [1484 1485] 0 0 2
velarpinch [1486] 0 0 1
Boonie_Hunter [1487] 0 0 1
realtree [1488] 0 0 1
heikman [1489] 0 0 1
CASEY7777 [1490] 0 0 1
VernonDent [1491] 0 0 1
Al747 [1492 1515] 0 0 2
pmsignal [1493 1494] 0 0 2
mlodyulek [1495] 0 0 1
two fifty [1496] 0 0 1
lolcat [1497] 0 0 1
Gman [1498] 0 0 1
Willy89 [1500] 0 0 1
EggsnBacon [1504] 0 0 1
bh46118 [1505] 0 0 1
mustig [1506] 0 0 1
ecobalans [1507] 0 0 1
mikelights [1508] 0 0 1
Smarquis [1513] 0 0 1
Rafał [1514] 0 0 1
Luminosity [1518 1519 1740] 0 0 3
Jiffy [1520] 0 0 1
jamio [1521] 0 0 1
beastlykings [1523] 0 0 1
bananainmypocket [1524] 0 0 1
musso1 [1529] 0 0 1
carljammers [1530] 0 0 1
silverecco [1531] 0 0 1
cody [1532] 0 0 1
Mainstream [1533] 0 0 1
destro [1534 1753] 0 0 2
brimstn [1535] 0 0 1
Ratus [1536] 0 0 1
MichaelA [1537] 0 0 1
Kinniver [1538] 0 0 1
NickG [1539] 0 0 1
seanok [1540] 0 0 1
ejschmitt [1541] 0 0 1
mack303 [1543 1544] 0 0 2
ImagioX1 [1545] 0 0 1
hksmatrix [1547] 0 0 1
repollo [1548] 0 0 1
kvnyay [1549] 0 0 1
Migacz112 [1550] 0 0 1
Bob_W [1551] 0 0 1
No-2-Ageing [1552] 0 0 1
j8048188 [1553 1747] 0 0 2
danallen [1554] 0 0 1
PancakeMan [1557] 0 0 1
Blue2 [1560] 0 0 1
18000bph [1561] 0 0 1
TopAs [1562] 0 0 1
Thewrights11 [1563] 0 0 1
rob799 [1564] 0 0 1
lenniehawk [1565] 0 0 1
simplex [1566] 0 0 1
Dan9571 [1567] 0 0 1
Juandre [1568] 0 0 1
Buckeye [1569] 0 0 1
diligenthunter [1570] 0 0 1
Phlipp [1571] 0 0 1
Lumen_Dodger [1572] 0 0 1
Momo [1574] 0 0 1
megathrower2017 [1578] 0 0 1
arficus [1579] 0 0 1
MichielSanders [1580] 0 0 1
bhtune [1581] 0 0 1
Tejasandre [1582 1739] 0 0 2
howlin4you [1583] 0 0 1
Vlad Vasiliu [1584] 0 0 1
jonathandowers [1585] 0 0 1
jasaero [1587] 0 0 1
frissonic [1588] 0 0 1
lewc [1589] 0 0 1
blastzone [1590] 0 0 1
flashaholic1 [1591] 0 0 1
sherman2k [1592] 0 0 1
mnautox [1593] 0 0 1
Fubs261 [1594] 0 0 1
seery [1595 1693] 0 0 2
OleMissRbl [1597 1598] 0 0 2
hjalti [1599] 0 0 1
Kristmann [1600] 0 0 1
Hully86 [1601] 0 0 1
Longtom [1602] 0 0 1
Thin Man [1603] 0 0 1
SikSemper [1604] 0 0 1
JoeRodge [1605] 0 0 1
Umcookies [1606] 0 0 1
Flashem [1607] 0 0 1
hex1979 [1608] 0 0 1
sportlampa [1609] 0 0 1
2Grumpy [1610 1759] 0 0 2
wdkingery [1614] 0 0 1
Sebastianzon [1621] 0 0 1
lightsoff [1622 1683] 0 0 2
elpaulo [1624] 0 0 1
blitzlinger [1626] 0 0 1
Crushfield [1629 1630] 0 0 2
crayton [1631] 0 0 1
Fldub [1632] 0 0 1
moptrf [1633] 0 0 1
vxlomegav6 [1634] 0 0 1
Lexel [1635] 0 0 1
Jbraman [1636] 0 0 1
JumpingJackflas… [1637] 0 0 1
nickdude [1638] 0 0 1
Akozub [1639] 0 0 1
Rob1563 [1640] 0 0 1
josephhendrix [1641] 0 0 1
blinker [1642] 0 0 1
YummyBacon [1643] 0 0 1
ticketme [1644] 0 0 1
POWER MIKE [1648] 0 0 1
toddlearound [1649] 0 0 1
Denalirotts [1650] 0 0 1
mattar12 [1651] 0 0 1
Iselldrugsforgolf [1657] 0 0 1
Irvinh8767 [1658] 0 0 1
Paul brabus [1659] 0 0 1
k2-bk-bl-rd [1660] 0 0 1
marius21 [1661] 0 0 1
FlashIight [1664] 0 0 1
chi2 [1665] 0 0 1
LeatherJacket [1673] 0 0 1
p_dedy [1674] 0 0 1
artwal [1675] 0 0 1
Goatkeepers [1676] 0 0 1
Sirawatka [1681] 0 0 1
Jhicks2018 [1684] 0 0 1
Hunter [1685] 0 0 1
Cyzan [1686] 0 0 1
Upper_tanker [1687] 0 0 1
Coheed1121 [1688] 0 0 1
Bucky the killer [1689 1762] 0 0 2
Goodtobeking [1690] 0 0 1
object_in_space [1692] 0 0 1
mtrsteadman [1694] 0 0 1
litenutz [1695] 0 0 1
Clarence222 [1697 1702] 0 0 2
a_idoux [1699] 0 0 1
Maverick1947 [1700] 0 0 1
Griley89 [1704] 0 0 1
itchy96 [1705] 0 0 1
uncle_muscle98 [1706] 0 0 1
tronx [1709] 0 0 1
claywalker0929 [1710] 0 0 1
run4jc [1711] 0 0 1
stanmore [1712] 0 0 1
Lips [1713] 0 0 1
Venomdefense [1714] 0 0 1
KDM [1715] 0 0 1
nitekayak [1718] 0 0 1
Light11 [1719] 0 0 1
Chemicalkraken [1720] 0 0 1
Defiars2 [1721] 0 0 1
YouFunnyGuys [1724] 0 0 1
jlemond [1726] 0 0 1
BILLMC89 [1727] 0 0 1
camelight [1728] 0 0 1
FMcamaroZ28 [1729] 0 0 1
Xonkorvich [1730] 0 0 1
B1reed [1731] 0 0 1
ace0001a [1733] 0 0 1
bugman1972 [1734] 0 0 1
George7806 [1735] 0 0 1
psumo [1736] 0 0 1
JStyle [1738] 0 0 1
Jump909 [1741] 0 0 1
Modestep [1742] 0 0 1
pwm40hz [1744] 0 0 1
pcmunson [1745] 0 0 1
chives12 [1746] 0 0 1
Romp23 [1749] 0 0 1
junkman88 [1750] 0 0 1
Wesleyflores [1751] 0 0 1
LongN159 [1752] 0 0 1
Erwin18 [1755] 0 0 1
Redlyne22 [1756] 0 0 1
thumper36 [1757] 0 0 1
Kent Lake [1760] 0 0 1
f1rstb81 [1761] 0 0 1
Nice! Was about time though
And ofc i am interested
XHP35Hi high CRI vs a good W2/3…especialy since it would be a long term project…aint sure about that, especialy with those new coming xpl2 and future xpl2 hi
in a 94mm the picture under so-so reflector a dded V5 deals nearly 650k cds at 5 amps
I have still to dismantle the TN42 to test it out with a nice w2
Nice idea! But 8 cells?
It’ll work with 4 :slight_smile:
120mm? geez….
What’s the price target? $100?
I’m ok with 8 cells, but it better be one hell of a thrower!
You guys planning on cracking the 1Mcd with that 12 cm reflector?
If the price is decent…I’m in!
Cheers
Nico
Great !
I think too 8 cells are a lot . 4 are ok :wink:
Also , count me in too , for any help the team needs .
Edit : Please don’t start an interest list , it will turn into chaos with the expected results
High CRI!
Count me in.
Dang dude, you are really pushing the limits here. Two custom and unusual light projects at the same time! Heck yeah, I am in!
Keep this up and make the work… you will generate some real BLF envy.
I am in
Im in this one as well! :smiley:
The debate is lumen vs throw. It will be a big light so will we be happy with a 1400 lumen XP-L HI and try to hit 1Mcd?, or will we settle for 700kcd with a 2000+ lumen XHP35?, or go 4000 lumen / 300kcd with a XHP70? (numbers are a very fast guess)
My first feeling is that in a light this big I expect more than 2000 lumen, even though that implies that maximum throw for the reflector will not be reached.
I’m in for a couple high quality hosts IF you can get them made first, before the multitude of requests and idea’s and other BS start’s flowing in, I have the drivers, boards and LED’s already.
It can’t be that hard just copy the TN42 with a bigger reflector and keep the carrier 4S, easy peasy, then just slap BLF on the side? If you have too?
Let the games begin! :person_facepalming:
I need to blind my neighbors a half mile across the lake. I’m in
Christmas 2017?
:+1: :+1:
Oh yeah, I’m in! Shine on.
Wow, I am in. Depending on price.
