The new version of the TP4056 & advices.
I do not really care if the thing I receive is considered a “clone” as long as it is well built and performs in no lesser way than I’d expect. Period.
Cheers :blush:
Only way to know is to test.your next batch from the same seller may be completely different though.btw the ones I get from ic station work perfectly.and have across 4 batches.
Hello Barkuti,
Mine arrived too. They are good. I checked two of them. They charge 2200mAh 18650 cell in or little more than 4 hours.
I got the 18650 spring loaded battery cases too. They go well with these modules. Just two-way-tabe it at the back of the case. :slight_smile: .
Hi! :-)
Got that 50-pack, lithiumlegend?
You should be able to combine the modules' charging outputs without issues. It was already done by pilotdog68.
With regards to the overcurrent protection, should work well as long as you properly set in parallel all of the load outputs (OUT-s).
Cheers ^:)
Original post date: Fri, 05/06/2016 - 09:47; assorted fixups.
I connected tp4056 protection board with one 18650 to some motor…it take about 6A. The board is dead in a moment. I tried another board…dead the same… not charging anymore, only heating, no output.
How this overcurrent disscharge works? I belive that is not working.
svicar1, 6A is a massive amount of current for one of these tiny 8205A FETs to handle, which may be the reason you are seeing magical smoke. :FACEPALM:
How are you connecting your stuff?
First, please make sure that is the maximum amount of current your motor needs to handle; if it is higher, then go with the higher number, better safe than sorry. :THUMBS-UP:
Now, please consider the fact that most battery protection boards with a single 8205A specify a maximum 2A of continuous operating current (the FET will drop ≈0,05V by itself at that current flow).
Thence, if I were to be called upon for advice on an application like yours (max 6A?), I'd recommend to make use of no less than 5 of these boards. Battery cathode connected to each B- pin with a short, equal and not overly thin sized lead/wire. Likewise, load negative pole should be symmetrically connected to each OUT- through equal sized leads/wires.
With regards to charging the battery, just connect its anode to the amount of boards you plan on using for charging. If you are fine with ≈1,7A, connect the battery anode to just a couple of boards, the same ones getting the 5V input for charging.
Cheers ^:)
helo
I will tell you exactely what I need
I have hand vacuum cleaner.
https://cache.osta.ee/iv2/auctions/1_1_8495647.jpg
Originaly it has 3x1.2AA bateries in series. All the time charging it kiled batteries.
I take off the “charger” (few resistors, diode,…)
I decided to put inside only two 18650 (from old laptop) in paralel. And manualy charge the cleaner when it will be necesarly.
Now I need charging (not a problem) and low voltage protection board…the booard tp4056 seem perfect…but there is a problem current.
The motor take 6A constant current and 14A pick current.
How to modify the tp4056 board in the output that will pass this current?
relay??
change FET?
aditional FET??
Or connect motor directly to battery and use out from boart to some buzer or warning led (that the bateries has low voltage and need to charge)?
Please for help.
Considering the low cost of these boards, just buy a 5-pack (or more):
5pcs Micro USB 5V 1A 18650 Lithium Battery Charging Board Charger Module New @eBay
As I said before, connect the battery pack cathode to all of the boards B- pin inputs, and the vacuum cleaner's motor to all of the OUT- pins, minimizing and balancing path resistance(s). When the boards are in operation under normal circumstances, their FETs are closed conducting electricity, and current flows between OUT- and B-. Since you say the thing can draw up to 14A, you may want to use 6+ boards in parallel to minimize the chances of a FET cascade opening, as each FET is controlled by its own “brain” (DW01 chip) and, with just 5 boards (5 × 3A peak current flow), we may find the protection kicking in from time to time if we often get near those 14A and our current paths aren't perfectly balanced (shouldn't be much of a problem, though).
Connect the battery pack anode to the boards B+/OUT+ (its the same thing) pins, so all of the DW01 monitoring chips are powered. Only the boards getting input power at their IN+ pins will charge the battery(es). Edited and fixed.
Alternatively, use TP4056 board(s) for charging, and leave the battery management duties to a more adecuate product: Battery BMS Protection PCB Board for 1-cell Li-ion / Li-Polymer Battery (7A) @FastTech (I'd wire two of those in parallel).
Hope this helps.
Cheers ^:)
Original post date: Fri, 11/04/2016 - 12:54; error fix.
helo
If I understend you to use multiple boards
the charging can be from one board only…
but how will DW01 chips on other boards work without B+??
Ooops! Yes, forgot the DW01s are powered through the B+/OUT+, dumb me. :FACEPALM:
Interconnect all of the B+/OUT+ pins to the battery pack anode. Only the boards receiving input power at the IN+ pin will charge the battery pack.
Cheers ^:)
so like this
what if I put 3V relay on out??
thank you for help.
That's right, svicar1. Still, I warn you to use no less than 5 boards, 5 × 8205A FETs. At 14A peak current flow, no less than 3,5A will try to flow on each FET and it'll trip the protection…
Also, you ought to know it is safe to use more than 1 charging board in parallel, even if your “charger” (PSU) isn't powerful enough (though don't blame me if you're using some sort of cheap knockoff). The boards just throttle themselves. Look at this pic:
Custom hand-crafted powerbank I made for a friend. That board uses a single TP4056 charging chip. After some analysis, I improved the charging engine with the addition of a TP4056 charging/protection board in parallel. His phone charger, a 1A unit, delivers up to 1,2A, but it hasn't burned out yet while feeding the powerbank (which now requests 1,7+A).
Cheers ^:)
P.S.: Relay? No, thanks. Those FETs do such a task very well already. Modern solid state relays are made with FETs. ;-)
Need help to resolve the problem while using this tp4056 with protection charger. In my circuit I have taken the ground of protected circuit to my circuit. I am not getting the voltage when I give the input what is happening when I shorted the battery ground and protected circuit ground then only I am getting the voltage will it cause any problem to my battery. I am very confused and in danger zone will it charge if I short both the grounds
Gibberish machine translation problem. :|
Step by step:
1) “In my circuit I have taken the ground of protected circuit to my circuit. …”
What are you calling “circuit”? I see such word mentioned 3 times in your first sentence, and it seems to me each one refers to a different subject. Let me try to clarify reword it: “In my TP4056 board I have connected OUT- to load circuit. …” This is just a guess, and let me explain something: OUT- = IN-, OUT+ = B+.
2) “… I am not getting the voltage when I give the input what is happening…”
Dafuq? What voltage? Should I presume some sort of cell is connected somewhere? There's also no mention of how the load circuit is being (!) powered.
3) “… when I shorted the battery ground and protected circuit ground then only I am getting the voltage will it cause any problem to my battery. …”
I believe this should be rephrased into “… only when I short B- and OUT- load circuit gets voltage, will it cause any problem to my battery? …”
Looks like the protection is triggered by the load :???: circuit. This can happen with ≈5A of draw or less, as a single 8205A MOSFET is rated for just up to ≈2.5A continuous (typical 8205A's RDS(ON) is slightly below 30mΩ when at ambient temperature, while the typical DW01A detection voltage is ≈0.15V).
4) “… I am very confused and in danger zone will it charge if I short both the grounds”
You just bypassed the protection circuitry. If your load circuit cannot overload or overdischarge :???: the battery, I see no problem and the thing runs a little less dampened.
Cheers ^:)
I will clear everythung. Actually I am using this tp4056 to charge my battery through solar. I connected battery to B+ and B- taking output from OUT+ and OUT- but I am getting only 1.2v (battery is fully charged LI-ION 3.6v 2600mah battery)
Why I am not getting the voltage. I shorted B- and OUT- to get the desired voltage
I have a Suboos 2x18650 hanging camp lantern that is a very handy design save for its UI and emitter choices. So it’s basically a host.
Considering replacing the driver and charging circuit and was wondering if this board would be acceptable for charging 2 cells in parallel?
a bit late but yes.
i have a 70’s table lamp i converted with 12p 18650.
at 1a into about 28ah it takes a while.
i jb weld epoxied a small heatsink to the board to help with thermal throttling.
esp since the solar panels output at 1a load in full sun approaches 6v.
I’m about to buy a pack of TP4056.
The Type C variant from the link below:
https://www.aliexpress.com/item/32647690858.html
But seeing there are clones out there I wonder whether I can assume they are fine or maybe I should be worried?
Also, I see that there are variants with protection circuit, f.e.:
https://www.aliexpress.com/item/1800678916.html
The circuit does not help against reverse polarity (which would be useful) but against overcharge, overdischarge and overcurrent.
Really I fail to see what use would that protection have in a charger (which is supposed to terminate, to not short and never discharges). But these circuits are there for some reason so I likely miss something.
Suggestions?
Agro that isn't hard to figure out. By integrating protective circuitry the board can also prevent over-discharge and etc., so it can be easier to li-ion convert something.
Newer, more compact size version:
https://www.aliexpress.com/item/32967650561.html
https://www.aliexpress.com/item/32966356149.html
No type-Crap yet LoL.
Ah, I see.
I used to view the boards as just chargers that lack cases rather than parts of other devices. Even though I’ve seen them used in flashlights. :slight_smile:
Type-Commendable input is a must for me. :slight_smile:
