Sanyo NCR18650BF 3350mAh (Red)
Official specifications:
Rated capacity: min. 3200mAh
Nominal capacity: min. 3250mAh, typ. 3350mAh
Nominal voltage: 3.6V
Charging method: CC/CV
Charging voltage: 4.20V
Discharge voltage: 2.50V
Charging current: std. 1625mAh
Ambient temperatyre: Charge: 0°C ~ 45°C, discharge: –20°C ~ +60°C, storage –20°C ~ 50°C
Weight (max): 46.5g
A high capacity cell from Sanyo/Panasonic, this version is improved over the NCR18650B version, but the specifications are the basically the same (My discharge curves are not).
The chart looks good with fairly good tracking between the cell (Sorry about missing one 7A track).
The cell has a reasonable temperature at 7A.
Conclusion
A fairly good high capacity battery, but superseded by the NCR18650GA
Notes and links
Compare to 18650 and other batteries
