I’m highly sure it will lower the CRI significantly and change the tint to cool white since the phosphors would likely to stuck to the silicone dome. Unless we can carefully separate the phosphor from the silicone dome. Or….make a clean slice and leave only thin silicone over it. Will try it later or…. ehm….Djozz?
Yes, I can do a shave on one of them, but do not expect miracles, the light intensity and throw increase will not be as spectacular as a full dedome, and on top of that, the ‘photon recycling’ process works better with cool white leds that remain a strong blue component after passing the phosfor layer.
Damaging the phosfor layer will of course be bad for tint and CRI.
However, if the phosfor layer stays intact, dedoming does not decrease CRI enormously, a good dedome will shift the tint to warmer, but from what I have found, a nice CRI led will never get a bad tint upon dedoming.
Yes, I know all of this. I am interested in the effects it has on this specific led. For example does photon recycling reduce the yellow spot effect? Does the light quality change in unexpected ways (the dome has extra phosphor in it?).
Thanks for your efforts ;).
From the picture, it seems the phosphors isn’t mixed in the silicone dome. Slicing won’t remove the phosphors
sm305 Ra9050 vs sm653 Ra7000
As PM-ed as well, I checked at 1400mA (and so did clemence), the ‘spiegelei’ problem (funny that you know the dutch word for egg sunny side up ) is not current related, so it must be uneven phosfor deposition during production. It is seen in several 6V high CRI 144A sample leds that clemence has received, but not the 12V ones. Clemence is checking with Nichia about it.
Hopefully this is only sample defect. So far only the AME (6V) has the egg yolk problem. It’s not cool to import hundreds of egg yolks all the way from Japan, we have plenty down the local market already.
Of course I know what is spiegelei (spee-hae-leey) :laughing: , dutchmen were in my country for 350 years. Many words in Bahasa language derived from Dutch too. I’m also 12,5% Dutch (according to Mendel’s theory).
HAHAHA, you guys are killing me.
That sm305 Ra9050 Spiegelei looks tasty though!
It’s the sm575 Ra9050 beamshot Chouster, will test the sm305 later. I don’t really remember what it was like.
Now you made me realize the macro pic of the sm305 indeed makes me hungry
Yup, it’s the macro pic and that tasty looking spiegelei color of that sexy looking Nichia sm305 Ra9050… Also the X pattern appears to be hidden better with that thicker phosphor layer…
Shpee gull eye (German pronunciation)
GOOD NEWS: The new batch of 6V 144A don’t have the spiegelei problem/donut/”X” artifact
Testing the Red
And lastly: An Emitter Porn for you
Cool, no more egg yolk. :+1:
Good to see that the issue was just a sample problem.
@djozz: I would be really interested in a de-doming test of the 144A, preferrably a high-cri variant.
@djozz: can you please test to reflow the 114A to a XM Sinkpad / Noctigon? Perhaps the + or - on the terminal pad and - or + to one normal +/- pad. That should work I think.
Why? I’m sure I will get that to work, but I guess you want to know the performance like that? I’m not going to do another 144A test soon, but my guess is that it will perform close to the test on my N119 board: the DTP-pad will make it heatsink a bit better, the too small pads will make it heatsink a bit worse.
Ok, thanks for your forecast.
It would be interesting for costom multi LED MCPCBs. And i hope to get similar Performance like virence MCPCB.
Additional beamshots:
The contenders
Gaggione LLC07N
Click here for FULL size
Gaggione LLC07N + 5 deg. Luminit Diffuser
Thanks for all the pictures! Looks nice.
This photo is private.
Oops! You don’t have permission to view this photo.
Here’s a link back to your home page.
SORRY,I CAN’T get the FULL size
