4 li ions would (26650) put out maybe 25 amps, say 90 watts, which would more or less fully drive about 12 big leds, so maybe 9000-15000 lumens.
for about 5 minutes.
and will be boiling hot in about 2 minutes.
I can assure you the light the op is looking at is nowhere near 9000 lumens !
The potential is there - given some huge mods. But most certainly not in stock form. :+1:
Why not though? It has 24 LEDs, seems like it could do that before the batteries died or the head melted.
Wait, 24 amps from these giant batteries, would be 6 fully driven leds, so 6000 lumens maybe?
Because the drivers in those flashlights do like 300ma per LED or something ridiculously low. The LEDs light up, and there are many of them, but they are all working far below their rated output.
this one…
…claims to have 24 XML-T6s though… his link is to a generic search page so we may be talking about 2 different lights.
this one costs $133
wle
If it was even 9000 lumens it would be a good deal but ask any of the sellers for a data sheet of the driver and none of them will give it to you.
That is the exact light he’s looking at. I linked it further up this thread, not him, and he confirmed it was that first one on the page.
I will repeat what I said prior - it is not 9000 lumens, but with the RIGHT MODS it could be. Stock, as also mentioned, will be waaaaaay under-driven.
Please buy one and do some tests !!! you will be disappointed!
It has Latticebright LEDs in the listing.
However, it very well could be 9000 lumens. There was a random generic ## LED flashlight, it may have been 12 or 15 LEDs I can’t recall exactly, similar Plunger design. In stock form it had essentially a direct drive driver and actually met or came close to the seemingly ridiculous specified output (Stock bypassed springs too iirc).
Granted that was 1 generic light among… a lot… The safer bet is definitely to spend money on flashlights that have been comprehensively reviewed.
If that light is purchased and confirmed to be 9000 otf lumens, I will eat my words, and my shoes!
I purchased one just for fun. Different brand but still with the 24 T6's. Will post pics when I get it in about 4-6 weeks. I have a 6500 lumens LED work light and also a 13,000 lumens LED shop light, so I will get a fair idea about the lumens of this flash light when I get it. I'm guessing it will be around 4,000 max but probably less, but I only paid $54 so it's worth the money if it works. It's big enough to use for self defence if nothing else
It should be here this week and I will post some pics of it's light output compared to my L6. I'm guessing it will not even be as strong as the L6, but it does run on 4 x 26650, so I'm kind of of curious. One thing I don't like is that it has 24 LEDs, so only 24 things could go wrong if they were not assembled correctly lol.
Chinese flashlight? You will probably get ~10% of the rated lumens
another thought is, what they may be trying to imply is “this light has as much light as a 250 watt incandescent bulb’’, which i think would be about 2000-3000 lumens…
i have seen 1xAAA lights listed as ‘9 watts’, which is of course total BS in terms of how much juice you can get out of a AAA battery.
the manufacturers or sellers cannot tell you, someone made up the ad copy and no one knows if they are trying to be dishonest, or just not telling you what the weird spec means.
wle
I know their lumens etc is bogus, but since the flashlight itself is hefty with cooling fins, couldn't I put a much better driver in it and get around 9000lumens out of it? Obviously using Latticebright LED, but I have a $5.00 flashlight with Latticebright LED and it is very bright. It is also underdriven. I'm all new to this and my best flashlight is my L6, but this one looks fun to play around with just for kicks. Still makes a good Christmas gift if nothing else.
Here is the one I ordered. It takes 4 x26650 as recommended batteries. Flashlight 24 LEDS
They say in their description "with 24* XM-L T6 LED, the maximum Output bright can achieve to to be 30000 lumen" but obviously that is not what it really outputs as they are only stating what max output "could" be. Just hoping it's not going to be a dud with something like 2000 lumens or less
Just buy a Klarus XT11GT, Convoy L6, Olight R50 or other light that pushes 1500 or more lumens
They are compact and with groupbuy coupon not more expensive as those crappy multi emitter lights
I have two L6's.
If it’s big and has a decent reflector(s) then it’s got potential. “Bright” is relative, $50 should get you something bright”er” than an A6. Beam shape also affects apparent brightness since the same lumens in a tight spot will appear brighter than those same lumens in a floody beam.
That's very true, it is relative depending on so many factors. Still curious how it lights up. Finally got the seller to contact the manufacturer to get some real specs about the driver and LED.
I got the 24 led multi flashlight today. L6 is brighter by about 20% give or take. The multi seems to be around 3000 lumens. I was guessing it was around 3000 before I got it but was hoping for about 5000+. L6 is a much more solid looking flashlight too. Way better built, rugged, refined and just an all around winner but I won't knock the multi as it looks in it's own way very cool, just not as bright or in the league of an L6 all around.
20% brighter to your eyes us more like 44% more lumens
The L6 has 3800 LED lumens on paper OTF it has about 3000 lumens
So your 12xT6 has around 2200 lumens
Just check the tailcap current multiple by 4V per cell and 80% efficiency of the driver
Most likely the driver runs each emitter only with 1A and dont have real Cree T6 inside so the efficiency is lower than the 120 L/W you would get from a real T6 XML
