For battery side, I don't understand all the issues there with battery configs and you do so that's fine. I thought bringing it off the midline like the mcu via might work, but I don't know. I thought scratching is a risk on that side (because of bashing and spinning batteries).
The last one I was talking about was splitting it off from the hot side of C1 on the component side, and winding it between LED+ and the switch, under the around Roff and under u1 to pin 1, so not around the outside.
Ok, maybe it doesn't save as much as I think. I thought Cf could then push out behind the Rsense, minor, but all together then U1 can move out quite a bit, or out even more and also up a bit, or out a bit less and down a whole bunch (I'm removing both UV resistors too in my idea because we just don't need them, so that's two resistors, a jumper and cap gone from that space and more use of the curvature). Looked to me like in the U1 down-and-out option you have a ton of room to move rsesne down (opening some space or options top right), and probably to move roff and CF2 up then at the same time adding clearance there.
Anyway, just ideas in case they're helpful, just ignore them if they're not. If there's enough room as is, then maybe no need for any of it either.
For now though I am speccing Ruv1/2. So what voltage cuttoff do people like? 2.7V and 0.2V hysteresis ok?
I'm trying to find options to do everything with E24 series resistors, fewer values being bonus points. I'm not sure how important that is. We have to work out R1/R2 though. I have no idea how calibration works, and I'm not sure I know how the OTC works either. I don't know where standard values exist, or if they would be setup for the same mcu voltage as us anyway, which I think matters for battery sensing.
If we are removing the low voltage resistors then that is a bit different and I might be able to figure out a way to do it (mostly because that would make it a worthwhile amount of space savings for the effort).
I think the mis-understood idea from you of using a via from the sense resistors is the best idea. The batteries can not be inserted like a normal SRK with this driver, they MUST be inserted from the rear or they wills hort out.
Still not ideal but a viable option.
Leaving low voltage control to the MCU is best like we said before, that way it can be adjusted to each persons likes later. I like mine a bit higher at around ~3.1v step down and ~2.75V cutoff.
It's a pretty big savings. Worthwhile? Depends what if anything it's needed for and how much effort it is. It does create a new problem, figuring out what best to use it for, and I don't even know the answer. bigger diode? More input caps? just more clearance and copper between things? I should learn diptrace a little someday to at least have appreciation of the effort side.
But how is mcu voltage cuttoff adjust? In software recompile? In software UI? By changing R1 and R2? Where can get up to speed about R1 R2 and R5, low voltage and OTC?
At the very least it preps the driver for small footprints later. I will give it a go at some point.
The LVP in the ATtiny is based around a simple voltage divider. The internal reference is 1.1v IIRC, so it simply needs to have the output of that voltage divider be less then that. For all the details on the ATtiny I would look at the data sheet, good luck, it is a long one.
MTN lists 36k/4.7k for 3s/4s usage IIRC. Easiest way is to simply find what others have used and go with that. The fine tuning is done in the software calibration anyways as long as the voltage on the input pin is less then 1.1V.
OTC is not needed for the e-switch anyways and it would not effect the buck side of the driver. It is simply a 1uf cap that the MCU monitors the voltage of. When the power is turned off the cap slowly drains over the course of a few seconds. The MCU checks the voltage when it turns back on and if it is above X value it is a short click, Below X and it is a med click, below Y value and it is a long click.
Pretty simple really, once again it is calibrated in the software so it doesn’t have to be very precise, just consistent.
Ok, well the basics are the same as what I figured. I missed the 1.1V though. It seems there are three references possible, 1.1, 2.56, vcc, or an external reference, so my information was based on vcc.
So 16.8*4.7/(36+4.7)= 1.9
At 2.5V per cell, Even 10*...= 1.15
So I'm guessing MTN is using the 2.56 internal reference, not the 1.1.
I guess we should target this for particular software (bistro?) and better get to the bottom of where that needs to be set. Fine tuning is fine, but 2.56 and 1.9 and 1.1 are all pretty different. Software calibration means before flashing or some kind of user interface adjustment?
Indeed they claim 19.1K for 1S and 36K for 2S-4s. That comes in at 0.83V at the mcu pin for 4.2V 1S and 1.94V at the pin for 16.8V. So in at least some of those driver variants they must be using either the 2.56V reference, or Vcc, not 1.1.
This stuff smells of weird historical baggage. 19.1? What? So you can have any of these different voltages and someone chose 19.1K? As if the OTC is going to be noticeably different if it's 18, 20, or even 22K instead? Very strange. Must be someone's favorite number.
Anyway, I guess we'll go with 36K and just assume someone will work out the software? It does seem to me that 36 can work, with the right voltage reference selected in the software.
It is historical baggage. But, I don’t think it’s weird. Driver design started around here as tiny mods to existing drivers, and worked its way up to what you see going on today. A lot of us don’t really know what we’re doing. We just know (from “history” ) what works and we do that. Some people have switched to other values like 22K because those work better in their designs. So, it’s moving, changing, accelerating. But, it takes time when we’re just poking at things with sharp sticks. We’re grateful when somebody like you comes along and gives us a push in the right direction.
Sure, I didn't meant to criticize. I've got a bunch of work with weird historical baggage. Most of it never really had a good reason, but it had a reasonable way of coming to be. I suspect 22 became popular because it's a standard value, and yeah, maybe someone liked a little slower OTC.
Well with 36K presumably settled, I've got everything specced. I just need to add all the resistors to a shopping cart and write it up. Will do soon.
I honestly do not know what reference is used but I would plan on using the 1.1V reference since the firmware is already setup for that IIRC. I am guessing 4x the resistance should be roughly correct for 4x the voltage.
The 19.1x vs 22k doesn’t make a big difference but it is noticeable as about an extra .5-1 second for the long click to activate. It can be recalibrated for the 22k naturally but it ends up right at the very edge of the range.
19.1k puts it closer to the upper middle of the range which is nicer to work with.
All calibration is done before compiling the firmware.
We built the first FET drivers based on the Qlite 3.04A design and board. It used 19.1 and 4.7K resistors for the LVP. We still use those, for the most part, as they’re commonly available and many of us that bought parts bought by the 100’s for price reduction. So now when we build new drivers, we use the components at hand that are proven to work. No need to rethink something that’s been working for years.
I and some others started using a 22K so we could use an 8.4V 2 cell system with the Zener modification to 6V drivers, mainly, then, the MT-G2. Along came the XHP-70 and 50, and things are taking off. Mostly though, the off time cap works well with the 19.1/4.7K setup, so it hasn’t been modified for consistency reasons.
I’ve built HUNDREDS of these drivers, have quite a few more FET boards and a fair stock of most components. So that’s how it comes to be historical baggage. Comfychair started putting an Vishay 70N02 MOSFET on the Qlite board, replacing the 7135 chips, even flipping the huge MOSFET upside down to make it work. I was amongst those that implemented this at the time, and a lot of others picked it up. Wight started designing new boards, along with MattAus and several others, I found the SIR800DP through hours of eyeballing charts on DigiKey and Mouser, and here we are.
For the record, we had to keep numbers in the ATTiny13A firmware under 255, so the 22K was about the highest value we could use at 245 to keep the LVP with 8.4V cells. I would use 124/112 settings with an 3V emitter, 245/228 with 8.4V set-ups.
It might be of some importance to note that Wight designed but didn’t really build the drivers. He’d put the new designs up on OshPark and let us flesh em out. I went through quite a few revisions this way. And MattAus got so burned out designing for the hot steady flow of requests that he dropped out of the forum altogether. He was a critical component to these FET drivers when it all took off. Wight has been gone as well, for the most part. So our teams that designed and tested have fallen apart under the stress of the rapid growth and of course, they had jobs. MattAus is an Aerospace Engineer working at an airport, not sure about Wight.
Yes, some of the builds didn’t work well, like the Knucklehead. I still have a box of components from building those, to no avail.
I guess some people around here think I got 13000 posts by saying things like hey, cool light! hahaha
We went back and forth at an amazing pace, for quite a while, just like you guys are doing in this thread.
That, and of course, I talk too much.
LOL, I had over 30k posts on one forum and over 20k on another plus over 10k on a few more. Few people talk as much as I used to.
When I take on a new hobby/forum I tend to go all the way in. Flesh out everything I can do in that hobby and then when there is nothing left or something else is more interesting I move onto something new.
Part of why I want to make sure I finish all these projects I have been working on before I find something new to do.
We used to have Scaru breaking new ground with multi emitters before anyone else did it, ChicagoX was making big lights, light bars, designing boards, way back before FET drivers. OL was building MagLites, filing his mark on the tubes and random finishes. The forum has changed a LOT since I came in over 3 years ago. We’ve lost a lot of good folks too. Foy used to be hilarious withhiswayofrunningwordstogethersigningoff. Some of the big group buys brought a lot of people in from other sites, which changed the face of this forum as well.
Now The Miller is breaking new ground, as is TomE and Pilotdog68. I’m still just a hack slamming lights together to find out what they do before the magic smoke appears…
Yeah, I get it. It works and stuck. Again, not criticicizing, just like to understand what's needed and what is just established and why. After all we are makingsome changes anyway probably, particularly the ldo voltage, so I can't just assume that won't have any effects. Now though I know, we aren't referencing of LDO (but I think not 1.1 either).
22 is a bit different from 19.1 (about 15% different OTC times). My point was more why not 20. I suppose people will need to order an LM3409 anyway, so adding a non-standard resistor value to the order doesn't really matter in the end. It's just a funny number. That's all, especially since almost all the rest are standard values.
At TA, yeah, 1.1 won't work without much higher resistance values than we're discussing. 2.55V (2.56 I think but whatever) is right as DB says (thanks for that feedback DB), and anyway, yeah, it's not vcc so that's the main thing because that's what I changed and wanted to make sure wouldn't impact anything. So 36K has worked and we'll use it.
Just for the record,
22k was introduced when driver boards were created where R1 was changed to a position before the diode D1. This allowed for more precise voltage measuring (while introducing OTC timing problems…).
22k instead of 19k1 compensated for the loss of the ~0.25V drop over D1, so existing firmware (mainly STAR back then) could be used on these newer drivers while maintaining the same LVP voltages.
Those were the days…
Yes, and it was a lot of try and error, some dead ends… and a lot of fun. Just like today, really.
It’s just that in these years BLF as a whole has developed an incredible base of hardware and firmware. And it still moves on.
To me some weird historical baggage is how the E48 and E96 series don't include the E24. Sure you can get 2% spacing with fewer resistors by starting over, but then you still ALSO need the E24 resistor values on hand anyway(if you want to be stocked up), so it's actually more in the end. I suppose it makes sure nobody accidentally uses 10% resistors when 1% is needed. In practice it doesn't really work out that way since 1% tolerance E12/24 values still get used at least as often as not, probably because people don't have to look them up. How often do you see a 1% 47.5 specced? Probably almost as often as a 48.7, but not nearly as often as a 47.0.
